Home » Eclipse Projects » Rich Client Platform (RCP) » Refreshing View (I want to make a real time digital clock using RCP )
Refreshing View [message #533694] Sat, 15 May 2010 16:48 Go to next message
No real name is currently offline No real nameFriend
I am very new to RCP .
I want to make a real time digital clock using RCP .
For that i have to refresh the view every second .
So , how to achieve that ?
Can anyone please help me on this issue .
Re: Refreshing View [message #533905 is a reply to message #533694] Mon, 17 May 2010 12:48 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
You need to call setTime(*) on your view either at regular intervals or
when it should actually change.
You can use org.eclipse.swt.widgets.Display.timerExec(int, Runnable).
that will run in the UI thread, but it won't keep accurate time.
Otherwise, use some Thread based or Job base pattern, and use
Display.asyncExec(*) to actually update the view time on the UI thread.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
icon7.gif  Re: Refreshing View [message #533968 is a reply to message #533905] Mon, 17 May 2010 15:09 Go to previous message
Thank you very much Paul for reply .
I used Display.asyncExec(*) inside a thread which did the trick for me.
Previous Topic:Editor close event and clean up of messages
Next Topic:Associating an Action with a key binding
Current Time: Mon Feb 19 02:31:28 GMT 2018
Powered by FUDForum. Page generated in 0.01970 seconds
