Home » Modeling » GMF (Graphical Modeling Framework) » Failure to export GMF/RCP using a Prdouct Configuration file.
Failure to export GMF/RCP using a Prdouct Configuration file. [message #533277] Wed, 12 May 2010 21:32
Originally posted by:
I have a Product Configuration I want to use to export my GMF projects.
I specified RCP in the code generation, and all this works perfectly
when launching the diagram application. I can also launch the
application from the Product Configuration, again all OK.
In the dependencies tab I have the three EMF/GMF projects, then click
Add required Plug-ins.
Now to export the plugin based application I want.
I have a problem I cannot work around. During the export one or more
dependencies cannot be resolved. On investigation I always find that
the 'missing' plugin is perfectly valid and sitting right there in the
Galileo plugin directory.
The most common culprit is: org.w3c.dom.smil, needed by one or more
batik plugins...
It's impossible for now to export an application....
Any help appreciated
Previous Topic:Open sub diagram from a link
Next Topic:To extend gmfmap model & customize gmfgen generation
Current Time: Mon Mar 19 09:09:18 GMT 2018
Powered by FUDForum. Page generated in 0.01577 seconds
