Home » Language IDEs » ServerTools (WTP) » Re: JavaScript highlighting in CDATA content
Re: JavaScript highlighting in CDATA content [message #533204] Wed, 12 May 2010 14:13 Go to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Xemox,
I'ld assume that you are in the wrong newsgroup. Xtext is a framework
that allows to define arbitrary languages and develop IDE support for
them. Unless you want to implement your own Xtext based JavaScript
language, I'ld guess the Eclipse wtp (cc'ed) is a better place to ask
this question.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 12.05.10 15:30, schrieb xemox:
> Hi People,
> We have a lot of xml files with embedded JavaScript code in CDATA
> content of XML documents. Because of CDATA it display the JavaScript
> without syntax highlighting.
> How can we enable Javascript highlighting in CDATA in Eclipse?
> Thanks!
Re: JavaScript highlighting in CDATA content [message #533276 is a reply to message #533204] Wed, 12 May 2010 21:02 Go to previous message
xemox  is currently offline xemox Friend
Hi People,
We have a lot of xml files with embedded JavaScript code in CDATA content of XML documents. Because of CDATA it display the JavaScript without syntax highlighting.
Thanks!
Previous Topic:Cant find my service listed in Axis2
Next Topic:Smart Insert Close Element does not work for StructuredTextViewer if embedded as composite in dialog
Current Time: Fri May 25 09:23:01 GMT 2018
Powered by FUDForum. Page generated in 0.01468 seconds
