Home » Modeling » TMF (Xtext) » Invoking Code Beautifiers with mwe2
Invoking Code Beautifiers with mwe2 [message #532775] Tue, 11 May 2010 08:26 Go to next message
Stefan Missing name is currently offline Stefan Missing nameFriend
I recently switched from working with Xtext 0.7.2 to the latest milestone release M7. In the stable release and using mwe I can invoke the beautifier from within the org.eclipse.xpand2.Generator component just fine:
<beautifier class="org.fornax.utilities.formatter.xml.XmlFormatter"/>
The syntax, obviously, has changed in mwe2 and since my search for any examples on using beautifiers with mwe2 failed to yield anything helpful, the best I could come up with was
component = org.eclipse.xpand2.Generator {
		metaModel = org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel {}
		expand = "templates::ScxMain::main FOREACH model"
		outlet = {
			path = targetDir
		fileEncoding = fileEncoding
		beautifier = org.fornax.utilities.formatter.xml.XmlFormatter
The keyword "beautifier" is not marked as an error (so i assume it is correct), however, the specified XmlFormatter is. The formatter should be correctly added to the build path and thus referencable from within the project (same set-up as the working 0.7.2 project).
The provided error message says it's not:
Couldn't resolve reference to Referrable 'org.fornax.utilities.formatter.xml.XmlFormatter'
How do I invoke the code formatter correctly?
Thanks and best regards
Stefan
Re: Invoking Code Beautifiers with mwe2 [message #532783 is a reply to message #532775] Tue, 11 May 2010 08:38 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Stefan,
there is a syntax error in the workflow. You have to use braces behind
class references. Otherwise they are interpreted as local variables
(Referable).
beautifier = org.fornax.utilities.formatter.xml.XmlFormatter {}
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 11.05.10 10:26, schrieb Stefan:
> just fine:
> outlet = {
> path = targetDir
> fileEncoding = fileEncoding beautifier =
> Stefan
Re: Invoking Code Beautifiers with mwe2 [message #532785 is a reply to message #532783] Tue, 11 May 2010 08:53 Go to previous messageGo to next message
Hi Sebastian,
thank you for the fast response. Unfortunately, if I add the braces, I get another error:
A value of type ' org.fornax.utilities.formatter.xml.XmlFormatter' can not be assigned to the feature setBeautifier
The same error arises when I try the JavaBeautifier delivered with Xtext instead, so it shouldn't be due to some incompatible implementation of the fornax formatter.
Stefan
Re: Invoking Code Beautifiers with mwe2 [message #532803 is a reply to message #532785] Tue, 11 May 2010 09:31 Go to previous messageGo to next message
Hi Stefan,
you are stumbling accross
https://bugs.eclipse.org/bugs/show_bug.cgi?id=310429
As setBeautifier(List) is not compatible to an XmlFormatter, you have to
register it as a post processor. Sorry for that.
Sebastian
Am 11.05.10 10:53, schrieb Stefan:
> Hi Sebastian,
> get another error:
> Regards
> Stefan
Re: Invoking Code Beautifiers with mwe2 [message #532819 is a reply to message #532803] Tue, 11 May 2010 10:02 Go to previous messageGo to next message
Hi Sebastian,
thank you again. The inevitable question now is: How do I register the beautifier as a postprocessor? The Xtext User Guide tells me i can implement my own postprocessor in "<MyDsl>PostProcessor.ext", but this looks more like model processing than actual file processing to me. How, if at all, can I invoke the beautifier from within this Extend file?
Additionally, mwe does seem to have a postprocessor attribute, but trying to use it like
postprocessor = org.fornax.utilities.formatter.xml.XmlFormatter {}
only gets me
Couldn't resolve reference to JvmFeature 'postprocessor'
Regards Stefan
Re: Invoking Code Beautifiers with mwe2 [message #532834 is a reply to message #532819] Tue, 11 May 2010 11:01 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hello Stefan,
have you configured the postprocessor within the outlet? e.g.
		expand = "templates::Template::main FOREACH model"
		outlet = {
			path = targetDir
			postprocessor = org.eclipse.xpand2.output.XmlBeautifier {}
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @chrdietrich
Blog : christiandietrich.wordpress.com
icon14.gif  Re: Invoking Code Beautifiers with mwe2 [message #532844 is a reply to message #532834] Tue, 11 May 2010 11:10 Go to previous message
Hi Christian,
no, I did not ... should have seen this myself.
The workflow is now running and the beautifier beautifying. Thanks a lot to both of you!
Stefan
Previous Topic:problems with the generated Parser (in M7)
Next Topic:classpath-URLs in generated ecore file
Current Time: Tue Feb 20 16:04:45 GMT 2018
Powered by FUDForum. Page generated in 0.02083 seconds
