Home » Language IDEs » ServerTools (WTP) » Smart Insert Close Element does not work for StructuredTextViewer if embedded as composite in dialog(Smart Insert Close Element for xml files (auto inset of ending tags) does not work as expected when StructuredTextViewer is embedded as a composite in a dialog)
Smart Insert Close Element does not work for StructuredTextViewer if embedded as composite in dialog [message #532124] Fri, 07 May 2010 09:12 Go to next message
Ankit Goel is currently offline Ankit GoelFriend
Hi:
I am trying to embed StructuredTextViewer in a dialog for editing XML code. But in this case the Smart Insert Close Element functionality (automatic insertion of ending tags) does not work as expected.
Here goes the problem:
If my dialog is launched with a WTP XML editor open in the background than the ending tags are inserted automatically.
But if the dialog is launched alone (with no WTP XML editor in background) ending tags would not be inserted.
I did little debugging on this and realized that StructuredAutoEditStrategyXML class causes this problem. Whenever a key is pressed the method customizeDocumentCommand(IDocument document, DocumentCommand command) is called. This is responsible for inserting the ending tags etc. But before doing the functionality it checks which editor is active and exits without doing anything if appropriate editor is not present.
Any help on how to get this working will be highly appreciated!!!
Ankit
Re: Smart Insert Close Element does not work for StructuredTextViewer if embedded as composite in di [message #533319 is a reply to message #532124] Thu, 13 May 2010 10:20 Go to previous message
Logged a bug for this - Bug 312381
https://bugs.eclipse.org/bugs/show_bug.cgi?id=312381
Previous Topic:Re: JavaScript highlighting in CDATA content
Next Topic:Undescribed error
Current Time: Thu Apr 19 10:12:34 GMT 2018
Powered by FUDForum. Page generated in 0.01863 seconds
