Home » Archived » Test and Performance Tools Platform (TPTP) » WebLogic - Profiling Button disabled(WebLogic - Profiling Button disabled)
WebLogic - Profiling Button disabled [message #531710] Wed, 05 May 2010 20:58 Go to next message
Paul Galbraith is currently offline Paul GalbraithFriend
Eclipse 3.5 and TPTP 4.6.2 are installed, I want to profile an application in weblogic but in the servers window, the "start the server in profiling mode" button is disabled, how can I find out why? Do I need to run the standalone agent locally and connect to it, I thought that was not needed anymore for local profiling...
Re: WebLogic - Profiling Button disabled [message #532956 is a reply to message #531710] Tue, 11 May 2010 16:53 Go to previous messageGo to next message
I'm inclined to think this is a defect, is nobody else profiling weblogic apps with tptp, who's got this working?
Re: WebLogic - Profiling Button disabled [message #532992 is a reply to message #531710] Tue, 11 May 2010 19:15 Go to previous message
Jonathan West is currently offline Jonathan WestFriend
Member
Hi Paul,
WebLogic support does not implement WTP profiling support, and hence the WebLogic profile will have to be done manually. You will need to specify the profiler's JVM arguments manually in the Weblogic configuration files. I am not specifically familiar with Weblogic configuration, however, here is a general presentation/tutorial on how to do so with Tomcat:
http://www.eclipse.org/tptp/home/documents/conferences/eclip seCon2009/712_ProfilingTestingTPTP.pdf
The principles are the same: locate the environment variables/configuration files used to specify the JVM arguments for which Weblogic runs, insert the required TPTP JVMTI profiler JVM arguments, set the appropriate environment variables, and then attach using 'Attach to Agent' from inside Eclipse. Hope this helps!
Previous Topic:Getting Started Documentation
Next Topic:Profiling web app deployed on remote Tomcat server
Current Time: Wed May 23 03:40:31 GMT 2018
Powered by FUDForum. Page generated in 0.01769 seconds
