| CreateNativeQuery ResultSet mapping [message #531509] |
Wed, 05 May 2010 05:40  |
Pavel Zelenka Messages: 61 Registered: July 2009 |
Member |
I have problem running native query. The getSingleResult fills only datum filed and the ks field is always null. No exception is thrown. Can anybody help?
Pavel
private Stat getExpediceData(Vykladka vykladka, Date datum)
queryString = "select datum, ks from vykaz v join expedice e on v.idexpedice=e.idexpedice where e.datum = ? and v.idvykladka=?";
Query q = em.createNativeQuery(queryString, Stat.class);
q.setParameter(1, datum, TemporalType.DATE);
q.setParameter(2, vykladka.getIdvykladka());
Stat stat = (Stat) q.getSingleResult();
return stat;
@Entity
public class Stat implements Serializable {
@Id
@Temporal(TemporalType.DATE)
@Column(name = "datum")
private Date datum;
@Column(name = "ks")
private Integer ks;
@Column(name = "remitenda")
private Integer remitenda;
@Column(name = "cas_zavozu")
private String casZavozu;
getters and setters
FUDForum. Page generated in 0.01920 seconds
