Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Ecore Tools] Integration with EMF Validation and/or MDT OCL
[Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #530861] Sun, 02 May 2010 00:44 Go to next message
Juan Cadavid is currently offline Juan CadavidFriend
Member
Hi Ecore Tools dev team,
First of all I want to congratulate you for the tool which keeps getting better every time Smile
I'd like to ask you about the plans to integrate Ecore Tools with MDT OCL. Is this going to be done through the offered components in EMF Validation or is the component going to provide its own validation mechanism to work with OCL? You mention in the wiki plans to provide integration with EMF Validation, but I don't see any open bug for that; however 297650 talks about integration with org.eclipse.ocl. What is the goal of this integration? Is this documented anywhere?
Thanks a lot for your help!
-Juan
[Updated on: Sun, 02 May 2010 00:44]
Report message to a moderator
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #530873 is a reply to message #530861] Sun, 02 May 2010 09:39 Go to previous messageGo to next message
--------------060100020905060507010101
Content-Type: text/plain; charset=UTF-8; format=flowed
Juan,
Probably the new validation support added to EMF along with the OCL
project's exploitation of it will be of interest:
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701>
I think Ed Willink documented how to take advantage of that, but I
couldn't find it on the OCL wiki, so I've added the OCL newsgroup to the
"to" list of the reply.
Ed
> getting better every time :)
> that; however https://bugs.eclipse.org/297650 talks about integration
> -Juan
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Juan,<br>
<br>
project's exploitation of it will be of interest:<a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701"><br>
</a>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701">https://bugs.eclipse.org/bugs/show_bug.cgi?id=216701</a><br>
</blockquote>
the "to" list of the reply.<br>
<br>
Cheers,<br>
Ed<br>
<br>
<br>
Juan Cadavid wrote:
<blockquote cite="mid:hrihss$kmn$1@build.eclipse.org" type="cite">Hi
<br>
<br>
<br>
<br>
however <a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/297650">https://bugs.eclipse.org/297650</a> talks about integration with
<br>
<br>
<br>
<br>
-Juan
<br>
</blockquote>
</body>
</html>
--------------060100020905060507010101--
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #531127 is a reply to message #530873] Mon, 03 May 2010 19:44 Go to previous messageGo to next message
Ed Willink is currently offline Ed WillinkFriend
Hi Ed, Juan
The write up is at http://wiki.eclipse.org/MDT/OCLinEcore
The first representation part is still valid.
The second editing part is not. It was written about six weeks ago since
when things have moved on a lot.
MDT/OCL 3.0.0M7 (on Wednesday) will include Xtext-based 'example'
editors for
- CompleteOCL which provides a OCL document to complement a meta-model
- OCLinEcore which provides a compound Ecore and OCL textual language
that may optional be loaded from/saved to an *.ecore file
- EssentialOCL a single expression for use in pop-ups
- OCLstdlib to define the OCL standard library
Watch this space/the Wiki for a revised write-up.
NB. The examples do not ship in the Helios Modeling EPP bundle, so you
need to load them from the MDT/OCL Update Site. Hopefully by Helios we
will have sorted out visibility through the Modeling Discovery UI.
Ed Willink
On 02/05/2010 10:39, Ed Merks wrote:
> Juan,
> Cheers,
> Ed
>> -Juan
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #531698 is a reply to message #531127] Wed, 05 May 2010 20:00 Go to previous messageGo to next message
Member
Thanks a lot Ed & Ed! There's quite a few things of new that I need to catch up with Smile
-Juan
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #532139 is a reply to message #531127] Fri, 07 May 2010 09:53 Go to previous messageGo to next message
Heiko is currently offline HeikoFriend
Member
Hi Ed,
today I try to follow your wiki entry.
But I fails in the beginning.
After installing Eclipse 3.6M7 and MDT/OCL 3.0M7 I generate the Library
Example and try to open the ecore model with the OCLinEcore Editor.
I've got an event loop exception:
eclipse.buildId=I20100429-1549
java.version=1.6.0_17
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
Error
Fri May 07 11:39:02 CEST 2010
Unhandled event loop exception
java.lang.AssertionError: Cyclic resolution of lazy links :
TypedTypeRefCS.type->TypedTypeRefCS.type
org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObjec t(LazyLinkingResource.java:76)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObje ct(ResourceSetImpl.java:219)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java: 202)
at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java: 262)
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eResolveProxy(Ba sicEObjectImpl.java:1483)
org.eclipse.ocl.examples.xtext.base.baseCST.impl.TypedTypeRe fCSImpl.getType(TypedTypeRefCSImpl.java:96)
org.eclipse.ocl.examples.xtext.base.scoping.TypedTypeRefScop eAdapter.createContents(TypedTypeRefScopeAdapter.java:36)
org.eclipse.ocl.examples.xtext.base.scope.AbstractScopeAdapt er.getInclusiveInheritedContents(AbstractScopeAdapter.java:1 18)
org.eclipse.ocl.examples.xtext.base.scope.FilteredAccesses.a ddElementsOfScope(FilteredAccesses.java:58)
org.eclipse.ocl.examples.xtext.oclinecore.scoping.ClassScope Adapter.addInheritedContents(ClassScopeAdapter.java:67)
org.eclipse.ocl.examples.xtext.oclinecore.scoping.ClassScope Adapter.createContents(ClassScopeAdapter.java:59)
at org.eclipse.ocl.examples...........
Is it a bug, or what do I make wrong?
Greetings
Heiko
Am 03.05.2010 21:44, schrieb Ed Willink:
> Hi Ed, Juan
> editors for
> Regards
> Ed Willink
>> Juan,
>> Cheers,
>> Ed
>>> -Juan
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #532266 is a reply to message #532139] Fri, 07 May 2010 18:02 Go to previous message
Hi Heiko
I'm afraid that installing the Xtext editors is fraught with many
difficulties.
The underlying Xtext APIs changed between M6 and M7 so that an MDT/OCL
M7a is imminent to ensure M7 coherence.
Last night the M7 plugins were not yet in the staging area so installing
the trial M7a grabbed incompatible Xtext M6.
The load of *.ecore is limited to rather simple (no references to
another model) Ecore files. Bug already fixed, but not in M7a, which was
enough of a build trial without fixing bugs.
I'm afraid that in M7 the editors are a bit of a taster for treats in store.
Ed Willink
On 07/05/2010 10:53, Heiko wrote:
> Hi Ed,
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Greetings
> Heiko
>> Hi Ed, Juan
>> editors for
>> Regards
>> Ed Willink
>>> Juan,
>>> Cheers,
>>> Ed
>>>> -Juan
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #622549 is a reply to message #530873] Mon, 03 May 2010 19:44 Go to previous message
Hi Ed, Juan
editors for
Ed Willink
> Juan,
> Cheers,
> Ed
>> -Juan
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #622827 is a reply to message #531127] Wed, 05 May 2010 20:00 Go to previous message
Member
Thanks a lot Ed & Ed! There's quite a few things of new that I need to catch up with :)
-Juan
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #622853 is a reply to message #531127] Fri, 07 May 2010 09:53 Go to previous message
techteam is currently offline techteamFriend
Member
Hi Ed,
Error
Greetings
Heiko
> Hi Ed, Juan
> editors for
> Regards
> Ed Willink
>> Juan,
>> Cheers,
>> Ed
>>> -Juan
Re: [Ecore Tools] Integration with EMF Validation and/or MDT OCL [message #622859 is a reply to message #532139] Fri, 07 May 2010 18:02 Go to previous message
Hi Heiko
difficulties.
Ed Willink
> Hi Ed,
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Greetings
> Heiko
>> Hi Ed, Juan
>> editors for
>> Regards
>> Ed Willink
>>> Juan,
>>> Cheers,
>>> Ed
>>>> -Juan
Previous Topic:Getting Exception when attribute of EDate is created.
Next Topic:Sample on how to add EAnnotation the Ecore diagram
Current Time: Sat Apr 21 16:11:14 GMT 2018
Powered by FUDForum. Page generated in 0.02423 seconds
