Home » Modeling » Epsilon » EglTask broken?
EglTask broken? [message #528677] Wed, 21 April 2010 12:54 Go to next message
Steffen Zschaler is currently offline Steffen ZschalerFriend
--------------030409060407040905000901
Hi Louis, Dimitrios,
I'm probably doing something really stupid, but I have a problem using
EGL from an ANT workflow. I have the following task invocation:
<epsilon.egl src="templates/BlockFactory.egl"
target="${dir}/tetris/BlockFactory.java">
<model ref="tetris" as="Tetris" />
</epsilon.egl>
But instead of simply loading the template and generating to the
specified file, I get the following exception:
java.lang.ClassCastException: java.lang.String cannot be cast to org.eclipse.epsilon.egl.EglFileGeneratingTemplate
at org.eclipse.epsilon.workflow.tasks.EglTask.examine(EglTask.j ava:32)
at org.eclipse.epsilon.workflow.tasks.ExecutableModuleTask.exec uteImpl(ExecutableModuleTask.java:118)
at org.eclipse.epsilon.workflow.tasks.EpsilonTask.execute(Epsil onTask.java:41)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
Now, I know that the whole template and target handling of EglTask has
recently been overhauled quite a bit, so I just wonder whether this
might simply be a regression somewhere? Or is there something I'm missing?
Steffen
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=ISO-8859-1">
</head>
Hi Louis, Dimitrios,<br>
<br>
EGL from an ANT workflow. I have the following task invocation:<br>
<blockquote>
<pre>&lt;epsilon.egl src="templates/BlockFactory.egl"
target="${dir}/tetris/BlockFactory.java"&gt;
&lt;model ref="tetris" as="Tetris" /&gt;
&lt;/epsilon.egl&gt;
</pre>
</blockquote>
specified file, I get the following exception:<br>
<blockquote>
<pre>java.lang.ClassCastException: java.lang.String cannot be cast to org.eclipse.epsilon.egl.EglFileGeneratingTemplate
</pre>
</blockquote>
missing?<br>
<br>
Cheers,<br>
<br>
Steffen<br>
</body>
</html>
--------------030409060407040905000901--
Re: EglTask broken? [message #528678 is a reply to message #528677] Wed, 21 April 2010 13:02 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
That's a regression indeed. Could you please file a bug and post the
link here? This happens only when a target is specified in the
epsilon.egl task so as a workaround you could remove the target and use
another template to call your (now) main one and store its result from
there.
Dimitris
> </epsilon.egl>
> at
> at
> at
> at
> Cheers,
> Steffen
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: EglTask broken? [message #528681 is a reply to message #528678] Wed, 21 April 2010 13:14 Go to previous messageGo to next message
Thanks for the quick reply. Here is the bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=309948
Steffen
> use another template to call your (now) main one and store its result
> from there.
> Cheers,
> Dimitris
>> using EGL from an ANT workflow. I have the following task invocation:
>> </epsilon.egl>
>> at
>> at
>> at
>> at
>> EglTask has recently been overhauled quite a bit, so I just wonder
>> whether this might simply be a regression somewhere? Or is there
>> Cheers,
>> Steffen
Re: EglTask broken? [message #528701 is a reply to message #528681] Wed, 21 April 2010 14:09 Go to previous message
Hi Steffen,
I've fixed this in the SVN and rolled out a new interim version
(v0.8.9.201004211415).
Dimitris
> Cheers,
> Steffen
>> from there.
>> Cheers,
>> Dimitris
>>> </epsilon.egl>
>>> at
>>> at
>>> at
>>> at
>>> Cheers,
>>> Steffen
Re: EglTask broken? [message #588500 is a reply to message #528677] Wed, 21 April 2010 13:02 Go to previous message
there.
Dimitris
> </epsilon.egl>
> at
> at
> at
> at
> Cheers,
> Steffen
Re: EglTask broken? [message #588518 is a reply to message #528678] Wed, 21 April 2010 13:14 Go to previous message
Steffen
> from there.
> Cheers,
> Dimitris
>> </epsilon.egl>
>> at
>> at
>> at
>> at
>> Cheers,
>> Steffen
Re: EglTask broken? [message #588528 is a reply to message #528681] Wed, 21 April 2010 14:09 Go to previous message
Hi Steffen,
Dimitris
> Cheers,
> Steffen
>> from there.
>> Cheers,
>> Dimitris
>>> </epsilon.egl>
>>> at
>>> at
>>> at
>>> at
>>> Cheers,
>>> Steffen
Previous Topic:EglTask broken?
Next Topic:adding markers to eugenia based editor after applying evl constraints to emfdiff model
Current Time: Wed Feb 21 13:31:51 GMT 2018
Powered by FUDForum. Page generated in 0.02383 seconds
