Re: Convert hex to ascii [message #528700 is a reply to message #528676] |
Wed, 21 April 2010 14:11 |
On 4/21/2010 7:05 AM, Christer Nilsson wrote:
> In my report I have one column with a hex string. I want to convert that
> string to ascii so everyone can understand that column in the report.
> Can anyone help me with that?
Google is your friend. I searched for "java convert hex ascii" and found
lots of sources for help on this.
Re: Convert hex to ascii [message #528948 is a reply to message #528868] |
Thu, 22 April 2010 13:23 |
On 4/22/2010 2:53 AM, Christer Nilsson wrote:
> Thank You for your answer.
> That is my problem. There is to many. Is it Java script I am looking
> for? And where do I put the script in Eclipse?
Answering this puts me a little out of my depth, but basically, you
should be doing a web app (Dynamic Web Project) and putting your .js
files down under WebContent (this Eclipse WTP's default name; you might
call it web or webroot, etc.). Mine have been on the path
<project-name>/WebContent/scripts. From there, you refer to them from
your HTML/JSP pages.
Russ
Re: Convert hex to ascii [message #529226 is a reply to message #529181] |
Fri, 23 April 2010 14:08 |
On 4/23/2010 4:16 AM, Christer Nilsson wrote:
> Still need help!
I think the lack of information is inhibiting our giving advice. Is this
a JavaScript that's supposed to work on the client (browser)? Why can't
it be done in Java on the server side? Etc. Please describe your
application.
FUDForum. Page generated in 0.07816 seconds
