| Re: non ui thread [message #528474 is a reply to message #528465] |
Tue, 20 April 2010 12:12  |
Andreas Hoegger Messages: 137 Registered: February 2010 |
The best way to work async in Eclipse is to use the job API. See
http://www.eclipse.org/articles/Article-Concurrency/jobs-api .html
To avoid the exceptions use the following code:
Label l;
Job j = new Job(){
public IStatus run(IProgressMonitor monitor){
while(!monitor.isCanceled()){
l.getDisplay().syncExec(new Runnable(){
public void run(){
if(l != null && l.isDisposed()){
l.setText("some updates")
somewhere else:
l.addDisposeListener(new DisposeListener() {
public void widgetDisposed(DisposeEvent e) {
j.cancel();
Hope it helps
Andreas
Lidder wrote:
> Hello,
> I am using a non UI thread to do some work in the background as follows:
> Thread.run method
> while(true)
> // do some checks and redraw the UI if need be.
> PlatformUI.getWorkbench().getDisplay().syncExec(new Runnable() {
> public void run() {
> // do some work on UI items -> MyItem.redraw()
> I want the thead to run for the lifetime of my application. The problem
> is that if I close my application, I get a null pointer exception in the
> thread. I tried putting in null checks for workbench, display and
> everything inside the run method. But my application still crashes. What
> is a good paradigm here to make sure that the application is still
> running before invoking the run syncExec from the non UI thread. Also
> once it is invoked and the application closes, will I not get the null
> pointer exception?
> Thanks.
FUDForum. Page generated in 0.02166 seconds
