Home » Eclipse Projects » Eclipse Platform » Is it possible to stop an editor from being restored if it is open when the workbench is closed?
Is it possible to stop an editor from being restored if it is open when the workbench is closed? [message #528271] Mon, 19 April 2010 21:52 Go to next message
Alan Boxall is currently offline Alan BoxallFriend
I have an editor that is open on a file when the workbench is closed and I do not want it to re-open
on workbench startup.
I don't see anything obvious in the reference help.
Re: Is it possible to stop an editor from being restored if it is open when the workbench is closed? [message #528503 is a reply to message #528271] Tue, 20 April 2010 18:14 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
> I do not want it to re-open on workbench startup.
It's not the editor that determines re-open, it's the editor input.
org.eclipse.ui.IEditorInput.getPersistable() and exists(), for example.
In the IDE case, I'm not sure how you could make sure those editors
close and aren't persisted, unless you provide your own IEditorInput to
them.
In an RCP app you might be able to close editors that you don't want
persisted in org.eclipse.ui.application.WorkbenchAdvisor.preShutdown()
or one of the other advisor methods (maybe window preClose()).
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Is it possible to stop an editor from being restored if it is open when the workbench is closed? [message #528546 is a reply to message #528503] Tue, 20 April 2010 21:49 Go to previous message
> them.
I am able to supply the editorinput so I tried what you suggested.
FileEditorInput says it is not to be extended so it looks like I'll need to implement an
IFileEditorInput that behaves like a FileEditorInput but returns null for getPersistable().
I ran a quick test by extending FileEditorInput and overriding getPersistable() and it did what I
wanted. Files open at IDE shutdown are not re-opened at the next startup.
Thanks for pointing me in right direction.
Previous Topic:What is the NG to ask questions re. the JavaScript editor?
Next Topic:Customized eclipse product
Current Time: Fri May 25 22:56:26 GMT 2018
Powered by FUDForum. Page generated in 0.02056 seconds
