Home » Archived » IAM (Eclipse Integration for Apache Maven) » Dependency on test classes in another project
Dependency on test classes in another project [message #527287] Wed, 14 April 2010 16:36 Go to next message
No real name is currently offline No real nameFriend
I'm using Eclipse IAM: 0.11.0.201001181900 on eclipse 3.5.2
First project has a package.Foo class in src/test/java
Second project depends on that one via:
<dependency>
<groupId>group</groupId>
<artifactId>artifact</artifactId>
<version>0.0.1-SNAPSHOT</version>
<type>jar</type>
<scope>compile</scope>
<optional>false</optional>
</dependency>
<dependency>
<groupId>groupg</groupId>
<type>test-jar</type>
<scope>test</scope>
</dependency>
Creating a JUnit class in the second src/test/java that uses Foo. It compiles fine. But if I run it, it fails with:
java.lang.NoClassDefFoundError: package.Foo
at bar.SomeTest.someTest(SomeTest.java:11)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall( FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(Refl ectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(Fr ameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate( InvokeMethod.java:20)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:76)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit 4ClassRunner.java:50)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java: 52)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java :191)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java: 42)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java: 184)
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:46)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:197)
Caused by: java.lang.ClassNotFoundException: package.Foo
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
... 23 more
I go to the debug perspective right click on terminated process, properties, and look at classpath on the command line. It doesn't include the first project's test-classes. Why?
[Updated on: Wed, 14 April 2010 17:04]
Report message to a moderator
Re: Dependency on test classes in another project [message #527755 is a reply to message #527287] Fri, 16 April 2010 11:24 Go to previous messageGo to next message
Carlos Sanchez is currently offline Carlos SanchezFriend
is your src/test/java folder a source folder in the "artifact" project?
IAM adds a link between projects, and Eclipse should honor those
settings while running in Eclispe
> <dependency>
> <type>jar</type>
> </dependency>
> <dependency>
> <scope>test</scope>
> </dependency>
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> Execution.java:38)
> at java.security.AccessController.doPrivileged(Native Method)
> ... 23 more
Re: Dependency on test classes in another project [message #527810 is a reply to message #527755] Fri, 16 April 2010 14:49 Go to previous messageGo to next message
Carlos Sanchez wrote on Fri, 16 April 2010 07:24
Yes, src/test/java is a source folder. And if I manually edit the launcher and add the first project to the classpath it will work. For some reason it is not adding the test-classes to the classpath of the launcher or something. Obviously, manually editing all the launchers to add that to the classpath is a real nuisance and shouldn't be necessary--something isn't working right.
Re: Dependency on test classes in another project [message #528085 is a reply to message #527810] Mon, 19 April 2010 09:16 Go to previous messageGo to next message
from what you say you don't have the 1st project on the 2nd' classpath,
can you check that in the Maven Classpath Container? you may have a
dependency to the jar in the local repository instead.
IAM will automatically add that link if the dependency
group/artifact/version match
Re: Dependency on test classes in another project [message #528166 is a reply to message #528085] Mon, 19 April 2010 15:01 Go to previous message
Carlos Sanchez wrote on Mon, 19 April 2010 05:16
The project does show up in Maven Classpath Container. And, target/classes for the other project does show up in the classpath in the launcher. Just target/test-classes doesn't.
At least that's what it was doing. I tried again today and now it's working. I had added the project explicitly to the run config as a workaround. I recreated it, and created a new one and now it's working. I don't know if it was restarting eclipse, rebuilding... whatever that might have kicked it into working... oh well.
Re: Dependency on test classes in another project [message #572783 is a reply to message #527287] Fri, 16 April 2010 11:24 Go to previous message
> <dependency>
> <type>jar</type>
> </dependency>
> <dependency>
> <scope>test</scope>
> </dependency>
> ssorImpl.java:39)
> Execution.java:38)
> ... 23 more
Re: Dependency on test classes in another project [message #572801 is a reply to message #527755] Fri, 16 April 2010 14:50 Go to previous message
Re: Dependency on test classes in another project [message #572823 is a reply to message #572801] Mon, 19 April 2010 09:16 Go to previous message
Re: Dependency on test classes in another project [message #572851 is a reply to message #528085] Mon, 19 April 2010 15:01 Go to previous message
Previous Topic:Dependency on test classes in another project
Next Topic:Incremental Build runs continually
Current Time: Sat Apr 21 23:24:49 GMT 2018
Powered by FUDForum. Page generated in 0.02323 seconds
