Home » Eclipse Projects » Subversive » Trying to export to runnable .jar but Finish button doesn't work
Trying to export to runnable .jar but Finish button doesn't work [message #527128] Wed, 14 April 2010 08:08 Go to next message
Aureola is currently offline AureolaFriend
Hi everyone.
I'm new to Eclipse and Java as well, but have been doing some smaller applications in processing; one of which I'm trying to export to a runnable jar-file using Eclipse.
I have corrected all problems with external stuff (libraries etc) and the program runs perfectly both as java applet and application. But the export just won't work.
I select the project folder, click on File - Export... Runnable .jar file. Selecting the java application that's in the project folder named xxxx.java in the Launch configuration dropdown, rename the Export destination (also tried different locations and names here). The "Extract required libraries inte generated JAR" is selected. Then I click the Finish button, but absolutely nothing happens. I have no idea how to solve it. Hope somebody knows what to do.
Thanks in advance!
/Aureola
Re: Trying to export to runnable .jar but Finish button doesn't work [message #528326 is a reply to message #527128] Tue, 20 April 2010 07:51 Go to previous message
Igor Burilo is currently offline Igor BuriloFriend
This is Subversive but not general purpose newsgroup, you should post this
message to specific for your topic newsgroup or check Eclipse Help at first.
> Hi everyone.
> just won't work.
> Thanks in advance!
> /Aureola
Previous Topic:import -> existing project and .svn information?
Next Topic:can't commit a missing status file
Current Time: Mon Jan 22 08:40:24 GMT 2018
Powered by FUDForum. Page generated in 0.01730 seconds
