| Applying a ChangeDescription to a different model [message #526581] |
Mon, 12 April 2010 07:01  |
Scott Dybiec Messages: 67 Registered: July 2009 |
Member |
I have written some code that captures changes to an EMF Resource
(capture-side) and applies those changes to a remote replica copy
(apply-side).
Since the ChangeDescription captured by a ChangeRecorder contains URI
references to the original capture-side model, the easiest thing to do
seemed to be to replace these URIs using a ResourceSet's URI Converter.
Here's the code I used:
// Convert the proxy hrefs in the ChangeDescription to point to the
replica file
URIConverter converter = new ExtensibleURIConverterImpl() {
URI replacementURI = resource.getURI();
public URI normalize(URI uri) {
if (uri.fileExtension().equals("rml")) {
return replacementURI;
} else {
return super.normalize(uri);
// Put the change description and model in the same ResourceSet, then
apply the changes
ResourceSet resourceSet = getResourceSet(); // This ResourceSet already
contains the model to apply changes to
resourceSet.setURIConverter(converter);
resourceSet.getResources().add(changeDescription.eResource() );
changeDescription.apply();
It works, is there a better way to attack this problem?
$cott
| Re: Applying a ChangeDescription to a different model [message #531957 is a reply to message #531868] |
Thu, 06 May 2010 11:07  |
Ed Merks Messages: 24691 Registered: July 2009 |
Csaba,
Using applyAndReverse you can achieve the inverted set of changes and of
course you can do it again to get back to the final state.
Alternatively you could copy the model and the change description
(EcoreUtil.copyAll) and then invert that copy.
Csaba Koncz wrote:
> Scott Dybiec wrote on Mon, 12 April 2010 07:01
>> (apply-side).
>> $cott
> I would like to do the same thing, but I can not. The
> ChangeDescription created by ChangeRecorder contains the old state of
> the model, so I can only use it to undo the changes. What I need is to
> keep two model instances in sync. Is there a dedicated change model
> and recorder for this?
> Thank you,
> Csaba
FUDForum. Page generated in 0.02119 seconds
