Home » Newcomers » Newcomers » [newbie] Plugin installation(Can't install Oribe XML)
[newbie] Plugin installation [message #526457] Sun, 11 April 2010 07:59 Go to next message
Ivan  is currently offline Ivan
Hi everyone,
I'm trying to intsall Oribe on Eclipse (Mac OS X 10.6.3) but it doesn't seem to work. This is supposed to be XML editor plugin with standard and simple installation. I've unpacked it into 'plugins' folder and it showed up in Eclipse Preferences but xml files are still opened in plain text editor. Plugin website suggests starting Eclipse with '-clean' option but I wasn't sure if I did it right so I've just added this plugin to a clean Eclipse installation just in case but it didn't help. Any suggestions?
Thanks!
Re: [newbie] Plugin installation [message #526459 is a reply to message #526457] Sun, 11 April 2010 08:42 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Ivan,
Does it appear in your Open With menu? Can you choose it as the default
in Windows->Preferences->General->Editors->File Associations?
Ivan wrote:
> Hi everyone,
> http://www.cumminsonline.com.ar/eclipse/xml/index.htm on Eclipse (Mac
> Thanks!
Re: [newbie] Plugin installation [message #526476 is a reply to message #526459] Sun, 11 April 2010 11:52 Go to previous message
Thank you, Ed! It worked, apparently xml was not associated with this plugin so setting up files associations fixed it.
Previous Topic:Bizarre restriction in workspace name
Next Topic:disable "Progress" completely
Current Time: Fri May 24 03:07:16 EDT 2013
Powered by FUDForum. Page generated in 0.01519 seconds
