Home » Eclipse Projects » BIRT » platform startup and shutdown(It seems that when the platform shuts down and the engine is destroyed , data in the permgen space isn't unallocated)
icon5.gif  platform startup and shutdown [message #524246] Wed, 31 March 2010 10:21 Go to next message
Alessio Lai is currently offline Alessio LaiFriend
Hi ,
using BIRT version 2.2.2.
We have integrated the report engine in our web application.
We have recently built a page where is possible to monitor the status of the report engine and/or start it or shut it down with a mouse click.
I've used the same API call suggested in this link .
If I profile the webApp when I start the report engine ,using Platform.startup(config) and factory.createReportEngine(config); I notice that the used permgen increases by some space, and that's ok , it's expected. When I destroy the report engine and shutdown the platform , the permgen increase again .
If I force a gc after platform shutdown the permgen doesn't decrease.
And now there is the real issue : If I start again the report engine the permgen increase again the same of the first time I've started it up.
If I repeat the operation for a lot of times I fill the permgenspace with the classic error , despite its size.....
What I am doing wrong ?
Thanks for any response.
Alessio
Re: platform startup and shutdown [message #524424 is a reply to message #524246] Wed, 31 March 2010 20:54 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Alessio,
Can you test this with BIRT 2.5.2?
or email me the code to test?
Jason
Alessio Lai wrote:
> Hi , using BIRT version 2.2.2.
> http://www.eclipse.org/birt/phoenix/deploy/reportEngineAPI.p hp
> Alessio
Re: platform startup and shutdown [message #524509 is a reply to message #524424] Thu, 01 April 2010 08:23 Go to previous message
Hi Jason , thank you for your response.
I've tried with version 2.5.2 as you suggested , and the problem is vanished. All data also in the permgen space is succsfully dereferenced.
I've tried with the below working example.
Thanks again.
Alessio
import java.awt.BorderLayout;
import java.awt.Dimension;
import java.awt.FlowLayout;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.WindowEvent;
import java.awt.event.WindowListener;
import java.util.logging.Level;
import java.util.logging.Logger;
import javax.swing.JButton;
import javax.swing.JFrame;
import javax.swing.JPanel;
import javax.swing.JTextArea;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.core.framework.IPlatformContext;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.core.framework.PlatformFileContext;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
* @author Alessio
public class BirtShutdownTest {
private IReportEngine reportEngine;
private JTextArea log;
private String engineHome;
public BirtShutdownTest(String[] argv) {
if (argv.length != 1) {
System.out.println("Usage : BirtShutdownTest pathToReportEngine");
System.exit(0);
initSwingComponents();
//path to the report engine
engineHome = argv[0];
public static void main(String[] argv) {
new BirtShutdownTest(argv);
private void initSwingComponents() {
JFrame frame = new JFrame("Birt shutdown test");
JPanel northPanel = new JPanel();
JPanel centerPanel = new JPanel();
northPanel.setLayout(new FlowLayout());
centerPanel.setLayout(new FlowLayout());
JButton start = new JButton("Start Report engine");
JButton stop = new JButton("Stop report engine");
JButton gc = new JButton("Suggest a garbage collection");
frame.getContentPane().setLayout(new BorderLayout());
northPanel.add(start);
northPanel.add(stop);
northPanel.add(gc);
northPanel.setVisible(true);
frame.add(northPanel, BorderLayout.NORTH);
frame.addWindowListener(new WindowListener() {
public void windowOpened(WindowEvent e) {
public void windowClosing(WindowEvent e) {
System.exit(0);
public void windowClosed(WindowEvent e) {
public void windowIconified(WindowEvent e) {
public void windowDeiconified(WindowEvent e) {
public void windowActivated(WindowEvent e) {
public void windowDeactivated(WindowEvent e) {
start.addActionListener(new ActionListener() {
public void actionPerformed(ActionEvent e) {
EngineConfig config = new EngineConfig();
config.setEngineHome(engineHome);
IPlatformContext context = new PlatformFileContext(config);
config.setPlatformContext(context);
log.append("Trying to start BIRT Platform...\n");
try {
Platform.startup(config);
IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
reportEngine = factory.createReportEngine(config);
log.append("BIRT Platform successfully started.\n");
} catch (BirtException ex) {
log.append(ex.getMessage() + "\n");
Logger.getLogger(BirtShutdownTest.class.getName()).log(Level .SEVERE, null, ex);
stop.addActionListener(new ActionListener() {
if (reportEngine == null) {
return;
reportEngine.destroy();
Platform.shutdown();
reportEngine = null;
gc.addActionListener(new ActionListener() {
System.gc();
log = new JTextArea();
frame.getContentPane().add(log, BorderLayout.CENTER);
frame.setSize(new Dimension(600, 400));
frame.setVisible(true);
[Updated on: Thu, 01 April 2010 14:49]
Report message to a moderator
Previous Topic:Data sources
Next Topic:BIRT 2.5 Integration Webinar Examples Problem(s)
Current Time: Tue Jan 16 10:01:45 GMT 2018
Powered by FUDForum. Page generated in 0.01367 seconds
