Home » Archived » M2M (model-to-model transformation) » [Xtend] Debugging Irritation
[Xtend] Debugging Irritation [message #523849] Mon, 29 March 2010 15:39 Go to next message
Ludwig Straub is currently offline Ludwig StraubFriend
(I hope this ist the correct location for my question.)
I'm running a M2M Transformation from a ecore model (created via Xtext) using Xtend (Helios M6) and a mwe (not mwe2) workflow.
All works fine and the result is just as it is mentioned to be.
Unfortunately I am not able to get the debugger running in a predictable way.
If I try to enable a breakpoint by double-clicking on the bar left of the Xtend-editor, sometimes no breakpoint occurs and sometimes the breakpoint is moved to the first line of code of the file but not where it was meant to be. I am then however able to step forward to the desired line of code, even if it is located within a deep sub-method.
Another issue I came across is that the debbugger crashes whenever I try to pass a input parameter to the workflow (via the -p or --param option).
Console output:
0    ERROR WorkflowRunner     -
java.lang.reflect.InvocationTargetException
	at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner.java:207)
Caused by: java.io.IOException: Couldn't establish connection to Debugger on port 0
	at org.eclipse.emf.mwe.internal.core.debug.processing.DebugMonitor.init(DebugMonitor.java:82)
	... 5 more
If I run the same configuration without debugging, all works fine:
0    INFO  WorkflowRunner     - --------------------------------------------------------------------------------------
16   INFO  WorkflowRunner     - EMF Modeling Workflow Engine 1.0.0, Build v201003150825
16   INFO  WorkflowRunner     - (c) 2005-2009 openarchitectureware.org and contributors
16   INFO  WorkflowRunner     - --------------------------------------------------------------------------------------
16   INFO  WorkflowRunner     - running workflow: XXXXX.mwe
What could be the reason for these problems?
My eclispe installation is rather plain, based on the modelling distribution. I just added subclipse and Xtext support so far.
Thanks a lot in advance!
Ludwig
Re: [Xtend] Debugging Irritation [message #524483 is a reply to message #523849] Thu, 01 April 2010 07:00 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Ludwig,
the observed behavior clearly indicates some bugs in the debugging
support of Xpand. Would you please be so kind and file new tickets for
the issues that have not yet been filed as a bugzilla?
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 29.03.10 17:39, schrieb Ludwig Straub:
> Hello,
> way.
> Console output:
> 0 ERROR WorkflowRunner - java.lang.reflect.InvocationTargetException
> at org.eclipse.emf.mwe.core.WorkflowRunner.main(WorkflowRunner. java:207)
> Debugger on port 0
> at
> org.eclipse.emf.mwe.internal.core.debug.processing.DebugMoni tor.init(DebugMonitor.java:82)
> ... 5 more
> v201003150825
> contributors
> Ludwig
Re: [Xtend] Debugging Irritation [message #524504 is a reply to message #523849] Thu, 01 April 2010 08:08 Go to previous message
Ok,
New ticket for "passing parameters to workflow while debugging":
https://bugs.eclipse.org/bugs/show_bug.cgi?id=307823
Existing and extended ticket for breakpoint-issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=267779
Previous Topic:[ATL] Consolidate multiple input elements into one output element
Next Topic:[ATL] atl.launch ant task: Cannot find reference model x
Current Time: Sat Apr 21 17:46:09 GMT 2018
Powered by FUDForum. Page generated in 0.01642 seconds
