Home » Eclipse Projects » BIRT » How to make BIRT reload data properly?
How to make BIRT reload data properly? [message #522812] Wed, 24 March 2010 00:04 Go to next message
Miles Parker is currently offline Miles ParkerFriend
1. Make change in BIRT data source.
2. Go to chart / table / cross-tab.
3. Chart uses old data.
Why?
Re: How to make BIRT reload data properly? [message #522960 is a reply to message #522812] Wed, 24 March 2010 11:00 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Miles,
Are you making changes to the structure of the datasource or just the data?
Jason
> Why?
Re: How to make BIRT reload data properly? [message #522997 is a reply to message #522960] Wed, 24 March 2010 17:31 Go to previous messageGo to next message
Jason Weathersby wrote on Wed, 24 March 2010 07:00
Miles,
Jason
Hi Jason,
Sorry, I shouldn't have had such a terse explanation. To the DataSet in a library. I recall that there was something about this, but when I make the change in a Library, save it, and then go back to the target chart, I get a "save" changes method, but still it doesn't change the output.
Miles
Re: How to make BIRT reload data properly? [message #523280 is a reply to message #522997] Thu, 25 March 2010 18:24 Go to previous message
Miles,
Can you try selecting the outline view view and right click on the
library and select refresh?
Jason
>> Miles,
>> data?
>> Jason
> Hi Jason,
> Miles
Previous Topic:Crosstab report custom export
Next Topic:Pie Chart grouping issue
Current Time: Mon Feb 19 12:33:49 GMT 2018
Powered by FUDForum. Page generated in 0.02198 seconds
