Home » Language IDEs » CDT » Refreshing Option Display in Tool Setting
Refreshing Option Display in Tool Setting [message #521119] Tue, 16 March 2010 10:07
Jim Adams is currently offline Jim Adams
Hi All,
I have extended CDT's Managed Build System by creating tools with options for our custom assemblers, compilers and linkers. One of the requirements I have is that some of the options for the tools are only applicable under certain conditions. When those conditions are met I display the option in the Tool Settings tab using an Applicability Calculator (IOptionApplicability). When the conditions are not met I hide the option. I also allow the user to change the conditions in which case I want to then display the option or not based on the user's settings. However, it seems the isOptionVisible method only gets called when the Tool Settings tab is first created. Is there a way to refresh the Tool Settings tab and get the options updated?
Jim
Previous Topic:How to implement the source's relative path or absolute unix format path in subdir.mk automatically?
Next Topic:Call hierarchy is not working
Current Time: Wed May 22 23:07:50 EDT 2013
Powered by FUDForum. Page generated in 0.01518 seconds
