Home » Newcomers » Newcomers » eclipse broke (can't open editor)(editor)
eclipse broke (can't open editor) [message #519982] Wed, 10 March 2010 17:02 Go to next message
wwuster is currently offline wwusterFriend
I'm running eclipse 3.5.1 on Ubuntu 9.10 and trying to use eclipse to write / debug php, c++, and JAVA programs. I was setting up C++ projects and everything seemed OK for a few hours, but the last time I exited eclipse and restarted it I get this message:
Could not open the editor: The editor class could not be instantiated. This usually indicates a missing no-arg constructor or that the editor's class name was mistyped in plugin.xml.
If I open the php perspective and my first php test script it works fine. I just can't seem to open .cpp files any more.
Help, please...
William
Re: eclipse broke (can't open editor) [message #520259 is a reply to message #519982] Thu, 11 March 2010 17:51 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
First, read the "sticky" topic at the top of this forum group titled
"Linux + Eclipse users, read this!"
If that doesn't help, look in the Error Log view to see if there are any
relevant-looking errors reported there. It might help to clear the log,
then re-start Eclipse to reproduce the problem.
If you can't make sense of what you see in the Error Log, you can post
it here (or portions of it); the .log file lives in the .metadata/
directory under your workspace directory.
Hope this helps,
Eric
Previous Topic:Can't compile - cannot be resolved to a type
Next Topic:Subclipse UTF-8 Question
Current Time: Mon Apr 23 15:52:21 GMT 2018
Powered by FUDForum. Page generated in 0.03004 seconds
