Home » Modeling » Epsilon » samples of inter-model consystency
icon5.gif  samples of inter-model consystency [message #519833] Wed, 10 March 2010 06:59 Go to next message
paolatco  is currently offline paolatco Friend
Hi averyone!
I was reading about epsilon and i really like it. However, i check out the whole examples of the repository and i couldn't find the sample for inter-model consistency checker sample.
Where can i find a sample of it? And, can i used in the EVL+GMF integration?
Tranks a lot,
paolatco
Re: samples of inter-model consystency [message #519862 is a reply to message #519833] Wed, 10 March 2010 09:28 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios KolovosFriend
Hi Paolatco,
paolatco wrote:
> Hi averyone!
You're right; there's no example in the SVN of using EVL for inter-model
consistency checking. I'll add one shortly.
> integration?
It would help if you could elaborate a bit on what you are trying to
achieve.
> Tranks a lot,
> paolatco
Dimitris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: samples of inter-model consystency [message #519873 is a reply to message #519862] Wed, 10 March 2010 09:56 Go to previous messageGo to next message
Here you go:
http://eclipse.org/gmt/epsilon/examples/index.php?example=or g.eclipse.epsilon.examples.evl.intermodel
Dimitris
Dimitris Kolovos wrote:
> Hi Paolatco,
> paolatco wrote:
>> Hi averyone!
>> integration?
> achieve.
>> Tranks a lot,
>> paolatco
> Cheers,
> Dimitris
Re: samples of inter-model consystency [message #520030 is a reply to message #519873] Wed, 10 March 2010 21:34 Go to previous messageGo to next message
Hi Drimitri.
Thanks a lot! it works perfect!
>> integration?
>achieve.
Right now i don't have an example Embarrassed
I'm gonna learn a little bit more for publish an example of what i want. The general idea is that I get several diagrams of the same object definitions, for instance a component, i get the deployment diagram and the class diagram. I would like to validate, if it's possible, with inter-model consistency that the component A is defined in both views, the deployment and the class diagram.
Thank you, very much, for the fast answer.
Re: samples of inter-model consystency [message #520039 is a reply to message #520030] Wed, 10 March 2010 21:57 Go to previous message
Hi Paolatco,
paolatco wrote:
> Hi Drimitri.
>>> integration?
>> achieve.
> Right now i don't have an example :blush:
No worries :) In any case it was a good opportunity for adding another
example.
> diagram.
That would fit in very nicely with the inter-model consistency checking
features of EVL indeed.
You're welcome!
Dimitris
Re: samples of inter-model consystency [message #587317 is a reply to message #519862] Wed, 10 March 2010 09:56 Go to previous message
Here you go:
Dimitris
> Hi Paolatco,
> paolatco wrote:
>> Hi averyone!
>> integration?
> achieve.
>> Tranks a lot,
>> paolatco
> Cheers,
> Dimitris
Re: samples of inter-model consystency [message #587350 is a reply to message #519873] Wed, 10 March 2010 21:34 Go to previous message
Hi Drimitri.
>> integration?
>achieve.
Re: samples of inter-model consystency [message #587360 is a reply to message #520030] Wed, 10 March 2010 21:57 Go to previous message
Hi Paolatco,
paolatco wrote:
> Hi Drimitri.
>>> integration?
>> achieve.
example.
> diagram.
You're welcome!
Dimitris
Previous Topic:Deep Cloning Source Elements
Next Topic:Mixing Other Frameworks
Current Time: Fri Feb 23 01:05:14 GMT 2018
Powered by FUDForum. Page generated in 0.02528 seconds
