Home » General (non-technical) » Eclipse Foundation » Another bug - could not load the Tomcat server configuration
Another bug - could not load the Tomcat server configuration [message #52466] Thu, 06 March 2008 13:09 Go to next message
vijay is currently offline vijayFriend
Hi there,
There is another bug related to tomcat server in eclipse.
I get the following error:
Publishing failed
Could not load the Tomcat server configuration at \Servers\Tomcat v5.5
Server @ localhost-config. The configuration may be corrupt or incomplete.
I am in Windows XP system logged in as admin user.
After going through all the bug reports i figured out the issue with all
the 3 xml files(server.xml,tomcat-users.xml, web.xml) which are copied to
the server directory. String "<!DOCTYPE Server SYSTEM "null">" is appended
in all the xml files (End of file)...
[workspace]Servers\Tomcat v5.5 Server @ localhost-config
server.xml
<Context docBase="spring" path="/spring" reloadable="true"
source="org.eclipse.jst.j2ee.server:spring"/></Host>
</Engine>
</Service>
</Server><!DOCTYPE Server SYSTEM "null">
tomcat-users.xml
<user password="tomcat" roles="role1" username="role1"/>
</tomcat-users><!DOCTYPE tomcat-users SYSTEM "null">
web.xml
</web-app><!DOCTYPE web-app SYSTEM "null">
I tried removing these string and starting the server. Then the error was
little different :
Publishing failed
Resource is out of sync with the file system: /Servers/Tomcat v5.5
Server @ localhost-config/server.xml.
What might be the problem pls help me to solve this issue...
Set up
OS Windows XP
Eclipse version : Eclipse SDK Version: 3.2.2 Build id: M20070212-1330
Tomcat version : 5.5
Thank you,
Vijay
Re: Another bug - could not load the Tomcat server configuration [message #52496 is a reply to message #52466] Thu, 06 March 2008 14:47 Go to previous messageGo to next message
This question is not appropriate for the eclipse.foundation newsgroup;
I've redirected it to eclipse.webtools
Vijay wrote:
> Hi there,
> Publishing failed
> to the server directory. String "<!DOCTYPE Server SYSTEM "null">" is
> appended in all the xml files (End of file)...
> server.xml
> ========== <Context docBase="spring" path="/spring"
> reloadable="true" source="org.eclipse.jst.j2ee.server:spring"/></Host>
> </Engine>
> </Service>
> tomcat-users.xml
> web.xml
> was little different :
> Publishing failed
> Set up
> OS Windows XP
> Thank you,
> Vijay
Re: Another bug - could not load the Tomcat server configuration [message #52550 is a reply to message #52496] Fri, 07 March 2008 16:16 Go to previous message
i dont find the posting there in the eclipse.webtools .. I will post egain in that forum..
Thank you
Vijay
Previous Topic:Still Haven't Registered for EclipseCon?
Next Topic:Modeling Webinar - Mar. 27
Current Time: Thu May 24 06:29:59 GMT 2018
Powered by FUDForum. Page generated in 0.02175 seconds
