Re: Error in headless build but not during import [message #519219 is a reply to message #519195] |
Mon, 08 March 2010 06:55 |
Hi Patrick,
I think the problem is that you don't issue a build between the import and the perform so the workspace is inconsistent.
Try adding:
<buckminster command="build" workspace="${workspacePath}"/>
just after the import.
HTH,
- thomas
On 03/07/2010 11:55 PM, Patrick Ruckstuhl wrote:
> I did some further testing.
> If I checkout the projects manually into the workspace from eclipse, it
> compiles.
> If I make the import using buckminster and then launch the workspace in
> eclipse, I get the same error.
> What could be the difference between a normal svn checkout into the
> workspace and what buckminster does? (Could it be that buckminster uses
> subclipse and eclipse subversive?)
> What can I do to further track this problem down?
> The build project can be found here
> https://svn.origo.ethz.ch/aranea/trunk/dev/ch.ethz.origo.ara nea.messagedsl.build/
> and currently expects buckminster headless to be installed and also have
> a target eclipse that consists of an eclipse xtext distribution 0.8 M5
> I'm running on Linux64 bit.
> Thanks for any ideas and help.
FUDForum. Page generated in 0.03839 seconds
