| Adding compiled classes to your application [message #518709] |
Thu, 04 March 2010 14:33  |
No real name Messages: 1 Registered: March 2010 |
Junior Member |
I'm new to eclipse so bear with me. I have an application with import statements pointing to classes previously compiled. There is no source code. I've identified the .jar file in WEB-INF/lib directory.
How do you add a jar file to your application? Any URLs detailing steps would be great to start. Clealy this is not my application and I'm starting out with Java.
Thank you.
| Re: Adding compiled classes to your application [message #518774 is a reply to message #518709] |
Thu, 04 March 2010 17:08  |
Russell Bateman Messages: 2709 Registered: July 2009 Location: Provo, Utah, USA |
> Thank you.
There are a number of ways. Here's one...
Right-click on your project and choose Build Path. Or, if you don't see
that, choose Preferences, the Build Path down the left-hand side.
Then, choose the Libraries tab.
There, you'll see a button to Add External JARs. Use that.
Ask again if this isn't enough.
Russ
[Updated on: Tue, 13 April 2010 14:20] by Moderator Report message to a moderator
FUDForum. Page generated in 0.01485 seconds
