Home » Eclipse Projects » Buckminster » Headless installation behind proxy
Headless installation behind proxy [message #518556] Thu, 04 March 2010 13:28 Go to next message
Patrick Ruckstuhl is currently offline Patrick RuckstuhlFriend
Member
I'm trying the headless installation of 3.6 behind a proxy.
I already tried to specify http.proxyHost and http.proxyPort without any success. What do I have to do to install behind a proxy?
Re: Headless installation behind proxy [message #518697 is a reply to message #518556] Thu, 04 March 2010 14:12 Go to previous messageGo to next message
Achim Demelt is currently offline Achim DemeltFriend
Hi Patrick,
The director should pick up your system's proxy settings. (IE settings under
Windows, http_proxy under linux, etc.). If you're running on a 64 bit linux
box, you'll have to use the latest version of the director because earlier
versions didn't include the relevant platform-specific fragment.
Achim
> Thanks
Re: Headless installation behind proxy [message #518823 is a reply to message #518556] Fri, 05 March 2010 08:28 Go to previous messageGo to next message
Member
I'm running on windows. I tried both with the automatic settings in Internet Explorer and also manually specified the proxy in the Internet Explorer settings. Both don't work and I get
Connection timed out exceptions when I try to run
director -r http://download.eclipse.org/tools/buckminster/headless-3.6
-d C:\projects\education\eclipse_rcp\headless\buckminster -P Buckminster -i org.eclipse.buckminster.cmdline.product
Re: Headless installation behind proxy [message #518839 is a reply to message #518823] Fri, 05 March 2010 09:23 Go to previous messageGo to next message
There's a good chance that there actually *are* timeouts when accessing
Eclipse servers or their mirrors these days. I've heard of reports of co-
workers who also have trouble installing things.
My advice is to download the headless site as a ZIP file from
http://www.eclipse.org/downloads/download.php?file=/tools/bu ckminster/archivedsites-3.6/org.eclipse.buckminster.site.ecl ipse.headless_1.2.0.r11249.zip
and install from that. To be honest, I actually prefer this method myself
because using the bleeding-edge 3.6 version bears some risks. We tend to run
into regressions from time to time due to the evolving p2 API, which we
heavily depend on. It would be a shame if your build fails just because you
happened to pull a non-working version from our site. So it's best to stick
with a version that works for you. Plus, it's faster to not always download
the stuff from the internet.
Achim
Re: Headless installation behind proxy [message #518859 is a reply to message #518556] Fri, 05 March 2010 10:21 Go to previous messageGo to next message
Member
Can you give me an example how to install from a local repository?
I was successful in downloading the command line product in the first step by using an url with file://c:/bla/foo
But then failed downloading any further features.
I tried both using the director (and simply specifying the feature id like I would with buckminster install)
And buckminster install
In the director I get a "not found" error, running with buckminster I get "uri has an authority component" error.
Re: Headless installation behind proxy [message #518864 is a reply to message #518859] Fri, 05 March 2010 10:31 Go to previous messageGo to next message
Uhm, I must admit that I've never done this on a Windows box... I have no
such problems on Linux. Can anyone from the greater community help out here?
Achim
Re: Headless installation behind proxy [message #518873 is a reply to message #518859] Fri, 05 March 2010 10:47 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Patrick,
You need to provide more info. Downloading and unzipping a repository that you then reference using file:/ paths should
work just fine on Windows.
Try using file:/c:/ instead of file://c:/
Thomas Hallgren
Re: Headless installation behind proxy [message #518909 is a reply to message #518873] Fri, 05 March 2010 12:16 Go to previous messageGo to next message
Member
Thomas Hallgren wrote on Fri, 05 March 2010 11:47
Hi Patrick,
Thank you, that was exactly the problem.
Is there also somewhere a download of the external site available (for the svn features).
Thanks again for the great help.
Re: Headless installation behind proxy [message #518915 is a reply to message #518909] Fri, 05 March 2010 07:38 Go to previous messageGo to next message
Try this link:
http://download.cloudsmith.com/buckminster/archivedsites/3.6 /
- thomas
>> Hi Patrick,
> the svn features).
Re: Headless installation behind proxy [message #633936 is a reply to message #518556] Tue, 19 October 2010 23:47 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
I dont think asking for proxy install is answered by this. I want to install the current repository please advice why the network settings dont seem to work.
Some sites could not be found. See the error log for more detail.
HTTP Proxy Authentication Required: http://download.eclipse.org/eclipse/updates/3.6/content.xml
Re: Headless installation behind proxy [message #634082 is a reply to message #518556] Wed, 20 October 2010 13:32 Go to previous messageGo to next message
Fabian Baboschi is currently offline Fabian BaboschiFriend
Member
I had a similar problem. I solved it by copying the file:
configuration\.settings\org.eclipse.core.net.prefs
from a working installation into the director and then buckminster installation folder.
Re: Headless installation behind proxy [message #634131 is a reply to message #518556] Wed, 20 October 2010 15:41 Go to previous messageGo to next message
It doesn't even install! FAIL
Re: Headless installation behind proxy [message #634138 is a reply to message #518556] Wed, 20 October 2010 15:50 Go to previous message
I just got an email;
MyEclipse Supports Eclipse Helios, Delivers Solutions for SpringSource Tool Suite
It should support being freaking installed!
Previous Topic:NPE in P2Materializer
Next Topic:Clear metadata when moving workspace to new location
Current Time: Sat May 26 10:10:52 GMT 2018
Powered by FUDForum. Page generated in 0.02518 seconds
