Re: Problem with executing dsf-gdb JUnit tests [message #518863 is a reply to message #518626] |
Fri, 05 March 2010 10:29 |
sneha Messages: 25 Registered: July 2009 |
Junior Member |
Thanks for your inputs.
I checked the plugin. All the test binaries except MultiThread.exe is
present in the org.eclipse.cdt.tests.dsf.gdb/data/launch/bin folder.
Following is a snap shot of stack trace on Eclipse console once tracing
is enabled while executing Junit Plugin Tests in debug mode:
Launching test application: data/launch/bin/MultiThread.exe
365,716 [MI] 1-inferior-tty-set /dev/pts/8
365,717 [MI] 1^done
365,723 [MI] (gdb)
365,929 [MI] 2source .gdbinit
365,931 [MI] &"source .gdbinit\n"
365,934 [MI] &".gdbinit: No such file or directory.\n"
365,934 [MI] 2^error,msg=".gdbinit: No such file or directory."
365,936 [MI] (gdb)
365,940 [MI] 3-gdb-set auto-solib-add on
365,941 [MI] 3^done
365,942 [MI] (gdb)
365,953 [MI] 4-environment-directory
365,954 [MI] 4^done,source-path="$cdir:$cwd"
365,954 [MI] (gdb)
365,963 [MI] 5-break-insert -t main
365,964 [MI] &"No symbol table is loaded. Use the \"file\" command.\n"
365,964 [MI] 5^error,msg="No symbol table is loaded. Use the \"file\"
command."
365,966 [MI] (gdb)
!SESSION 2010-03-05 15:32:37.402
eclipse.buildId=I20100129-1300
java.version=1.6.0_16
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -g -version 3 -port 43220 -testLoaderClass
org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader
-loaderpluginname org.eclipse.jdt.junit4.runtime -classNames
org.eclipse.cdt.tests.dsf.gdb.tests.tests_6_8.Suite_6_8 -application
org.eclipse.pde.junit.runtime.uitestapplication -product
org.eclipse.sdk.ide -g -testpluginname org.eclipse.cdt.tests.dsf.gdb
Command-line arguments: -os linux -ws gtk -arch x86_64 -consoleLog -g
org.eclipse.sdk.ide -data
/users/snehaa/SystemAnalyzerWorkspaces/Task154/../junit-work space -dev
file:/users/snehaa/SystemAnalyzerWorkspaces/Task154/.metadat a/.plugins/org.eclipse.pde.core/pde-junit/dev.properties
-debug
/users/snehaa/SystemAnalyzerWorkspaces/Task154/.metadata/.pl ugins/org.eclipse.pde.core/pde-junit/.options
-os linux -ws gtk -arch x86_64 -consoleLog -g -testpluginname
!ENTRY org.eclipse.cdt.dsf 4 10005 2010-03-05 15:32:45.971
!MESSAGE Request for monitor: 'RequestMonitor
(org.eclipse.cdt.dsf.concurrent.RequestMonitorWithProgress@7925871f):
Status ERROR: org.eclipse.cdt.dsf.gdb code=10004 Failed to execute MI
command:
Error message from debugger back end:
No symbol table is loaded. Use the "file" command. java.lang.Exception:
No symbol table is loaded. Use the "file" command.' resulted in an error.
!SUBENTRY 1 org.eclipse.cdt.dsf.gdb 4 10004 2010-03-05 15:32:45.971
!MESSAGE Failed to execute MI command:
!STACK 0
java.lang.Exception: No symbol table is loaded. Use the "file" command.
org.eclipse.cdt.dsf.mi.service.command.AbstractMIControl$RxT hread.processMIOutput(AbstractMIControl.java:806)
org.eclipse.cdt.dsf.mi.service.command.AbstractMIControl$RxT hread.run(AbstractMIControl.java:645)
This error is repeated for most of the tests.
Following setup is done for gdb:
The .gdbinit file is kept in my home directory.
PATH variable is updated with the path of gdb binary.
All other steps have been executed as mentioned in the following link
before executing JUnit tests.
http://wiki.eclipse.org/CDT/cdt-debug-dsf-gdb#Launching_the_ tests
With the above set up following are the results after executing the
JUnit tests for Test suite gdb.6.8:
Runs: 136/136 (7 Ignored)
Errors: 41
Failures:1
The JUnit view displays failure for 4 classes out of 7 from package
org.eclipse.cdt.tests.dsf.gdb.test.tests_6_8.Suite_6_8.
Following binaries are present in
org.eclipse.cdt.tests.dsf.gdb/data/launch/bin folder:
BreakpointTestApp.exe
ExpressionTestApp.exe
GDBMIGenericTestApp.exe
MemoryTestApp.exe
SpecialTestApp.exe
TracePointTestApp.exe
Thus as mentioned above, only the MultiThread.exe is not present in the
bin folder.
Any pointers will be of great help.
Thanks and Regards,
Sneha
Marc Khouzam wrote:
> My guess is that the test binaries have not been built. Do you have
> anything listed under
> The tests are built automatically using 'make'
FUDForum. Page generated in 0.02304 seconds
