Home » Modeling » TMF (Xtext) » [Xtext] Using existing enums from imported metamodel
[Xtext] Using existing enums from imported metamodel [message #517508] Sun, 28 February 2010 22:46 Go to next message
Originally posted by: ogucuk.gmail.com
Dear Xtext gurus,
is it not possible to directly use the enumerations that are defined in
an imported metamodel without explicitely introducing them in the grammar?
We use an imported metamodel instead of generating our own from the
Xtext grammar. In our Ecore metamodel, we had already defined literals
for our enumerations. Now we want to reference the enumeration in our
Xtext grammar, i.e:
Entity :
type=[metamodel::EnumType]
Code generations is no problem but in the editor I do not see the enum
literals in content assist. Also if I type the predefined literals, I
get parser errors.
What am I missing?
Re: [Xtext] Using existing enums from imported metamodel [message #517523 is a reply to message #517508] Mon, 01 March 2010 03:02 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Özgün,
since enumerations are datatypes, I doubt that you can use them in a
cross reference.
You could use you EnumType as follows:
enum EnumType returns metamodel::EnumType:
Foo | Bar;
Entity:
type=EnumType;
You have to list the enum literals because the grammar describes the
abstract and the concrete syntax. E.g. there may be situations where you
do not want to use every defined literal in your concrete syntax.
Hope that helps,
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 28.02.10 23:46, schrieb Özgün:
> Dear Xtext gurus,
> Xtext grammar, i.e:
> Entity :
> get parser errors.
> What am I missing?
Re: [Xtext] Using existing enums from imported metamodel [message #517524 is a reply to message #517523] Mon, 01 March 2010 03:02 Go to previous messageGo to next message
Hi Sebastian,
thanks again, for your prompt responses.
If I leave the brackets and the metamodel alias, Xtext thinks EnumType
is a parser rule and cannot resolve it. I was kind of hoping, maybe in
that case the brackets do mean that it is imported :) and not a
cross-ref. Do you have any suggestions?
Well, it is not a big deal but we would be happy if we could release the
grammar from the double declaration of enumerations (once in metamodel
and once in the grammar).
Thanking you
Özgün
Sebastian Zarnekow schrieb:
> Hi Özgün,
> cross reference.
> Foo | Bar;
> Entity:
> type=EnumType;
> Hope that helps,
> Sebastian
Re: [Xtext] Using existing enums from imported metamodel [message #517527 is a reply to message #517524] Mon, 01 March 2010 08:25 Go to previous messageGo to next message
Hi Özgün,
it is not possible to use enums without declaring an enum rule.
Sebastian
Am 01.03.10 08:56, schrieb Özgün:
> Hi Sebastian,
> Thanking you
> Özgün
>> Hi Özgün,
>> cross reference.
>> Foo | Bar;
>> Entity:
>> type=EnumType;
>> you do not want to use every defined literal in your concrete syntax.
>> Hope that helps,
>> Sebastian
Re: [Xtext] Using existing enums from imported metamodel [message #517531 is a reply to message #517527] Mon, 01 March 2010 08:37 Go to previous message
Ok thank you
> Hi Özgün,
> Sebastian
Previous Topic:reference a concept from other model through its fully qualified identifier
Next Topic:[Xtext] Problem with the autogenerated code.
Current Time: Thu Feb 22 23:04:13 GMT 2018
Powered by FUDForum. Page generated in 0.01339 seconds
