Home » Eclipse Projects » Buckminster » Using headless Buckminster to create p2 reporsitory with multiple versions
Using headless Buckminster to create p2 reporsitory with multiple versions [message #517228] Fri, 26 February 2010 16:11 Go to next message
John is currently offline JohnFriend
Hi!
In the Eclipse IDE from the popup of a feature I can select
Export... -> Plug-in Development -> Deployable features.
Then I can select the features (and plug-ins) I want to deploy and a destination directory.
The I get a work p2 repository, than I can use as an update site.
If I go ahead and change the version on some of the features selected earlier
and possibly push the version number to the contained plug-ins,
I can repeat the above procedure, use the same destination directory
and I will now have a p2 repository containing both the old and the new versions.
How can I accomplish this using headless Buckminster?
I have created a my.site.feature representing the features I want in my p2 repository,
which is what I'm effectively doing in the dialog as described above.
I then execute headless the action site.p2 and get a working p2 repository.
But I can't see that I can use an old destination for the headless build.
The only part of the destination I have influence on is buckminster.output.root.
But the actual site is created in ${buckminster.output.root}/my.site.feature_version-eclipse.f eature/site.p2.
This is the folder that equivalates to the destination directory mentioned above.
Is it possible to get headless Buckminster to generate a p2 repository containg also older versions?
Or must it be done in some other way?
Could somebody please help me out with hao to achieve this?
Thanks.
/John
Re: Using headless Buckminster to create p2 reporsitory with multiple versions [message #517244 is a reply to message #517228] Fri, 26 February 2010 16:26 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi John,
On 02/26/2010 05:11 PM, John wrote:
> Hi!
> earlier
> versions.
Not at present and I consider this a weakness. Can you please enter an enhancement request for this?
> p2 repository,
> eature/site.p2.
> mentioned above.
One way of doing this is to create an additional layer of directories and add composites:
<repository root>
compositeContent.xml
compositeArtifacts.xml
/build-a
content.jar
artifacts.jar
/plugins
/features
/binaries
/build-b
content.jar
artifacts.jar
/plugins
/features
/binaries
This is actually very common at eclipse.org. If you point to /eclipse/updates/3.6milestones for instance, you get a
composite that in turn contains all milestones.
A compositeContent.xml can look something like this:
<?xml version='1.0' encoding='UTF-8'?>
<?compositeMetadataRepository version='1.0.0'?>
<repository name='&quot;My Update Site&quot;'
type='org.eclipse.equinox.internal.p2.metadata.repository.Co mpositeMetadataRepository' version='1.0.0'>
<properties size='1'>
<property name='p2.timestamp' value='1267159479207'/>
</properties>
<children size='2'>
<child location='build-a'/>
<child location='build-b'/>
</children>
</repository>
The compositeArtifacts.xml is almost identical. Just replace "Metadata" with "Artifact"
HTH,
- thomas
Re: Using headless Buckminster to create p2 reporsitory with multiple versions [message #517263 is a reply to message #517244] Fri, 26 February 2010 17:46 Go to previous messageGo to next message
Hi Thomas!
Thanks for the response. The enhancement request is here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=304063
If I understand you correctly you suggest something in the line of creating an aggregated repository. I've seen that suggested in the p2 documentation somewhere as a way to manage large update sites.
I can of course create this using the Aggregator. But is it possible to do it without manual intervention? I can only see this happen by running a headless job creating the new p2 repository using the site.p2 action. Then edit the Aggregator model to include the new site and trigger a headless build of the aggregated site.
This is of course doable, but are there some secret commands I can use to update an exisiting p2 repository with the conents of the newly generated p2 repository?
I've found some commands in the p2 documentation, but they seem to be more focuse on generating p2 metadata from other sources or install from p2 repositories into an Eclipse target.
Is there anything I can do to make this automated, without generating the metadata files myself?
Thanks.
/John
Re: Using headless Buckminster to create p2 reporsitory with multiple versions [message #519445 is a reply to message #517263] Mon, 08 March 2010 20:36 Go to previous messageGo to next message
Bernhard Merkle is currently offline Bernhard MerkleFriend
Member
Thanks John,
today i stumbled exactly over the same problem :-)
Bernhard.
On 26.02.2010 18:46, John wrote:
> Hi Thomas!
> Thanks.
> /John
Re: Using headless Buckminster to create p2 reporsitory with multiple versions [message #519716 is a reply to message #519445] Tue, 09 March 2010 18:24 Go to previous messageGo to next message
Carsten Reckord is currently offline Carsten ReckordFriend
--------------010208020400080206060501
Content-Type: text/plain; charset=us-ascii; format=flowed
Hi Bernhard and John,
I'm currently in the process of modularizing my build process to something more akin to maven, i.e. build a single plugin, test it, then
publish it to an integration site from where the other plugins can pick it up for their build.
The small ant snippet I use to publish the plugin to the site from a buckminster action should be easily adaptable to push a whole local
single-version site as produced by buckminster to a main site containing other versions.
The script currently has one noteworthy limitation: It will only publish the first fileset of the input path group since the p2 task I use
cannot handle Buckminster's path groups (hence the 2 actions grouped together in my cspex). I don't think that's a problem in your case
though, because the site.p2 action should return a single path.
HTH,
Carsten
On 08.03.2010 21:36, Bernhard Merkle wrote:
> Thanks John,
> Bernhard.
>> Hi Thomas!
>> Thanks.
>> /John
Content-Type: text/xml;
name="buckminster.cspex"
Content-Disposition: inline;
filename="buckminster.cspex"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4NCjxjc3Bl Y0V4dGVuc2lv
bg0KICAgeG1sbnM6eHNpPSJodHRwOi8vd3d3LnczLm9yZy8yMDAxL1hNTFNj aGVtYS1pbnN0
YW5jZSINCiAgIHhtbG5zOmJjPSJodHRwOi8vd3d3LmVjbGlwc2Uub3JnL2J1 Y2ttaW5zdGVy
L0NvbW1vbi0xLjAiDQogICB4bWxucz0iaHR0cDovL3d3dy5lY2xpcHNlLm9y Zy9idWNrbWlu
c3Rlci9DU3BlYy0xLjAiPg0KICAgPGFjdGlvbnM+DQogICAgICA8cHVibGlj IG5hbWU9InB1
Ymxpc2guYnVuZGxlLmphciIgYWN0b3I9ImFudCI+DQogICAgICAgICA8YWN0 b3JQcm9wZXJ0
aWVzPg0KICAgICAgICAgICAgPHByb3BlcnR5IGtleT0iYnVpbGRGaWxlIiB2 YWx1ZT0iYnVp
bGQvcHVibGlzaC5hbnQiLz4NCiAgICAgICAgICAgIDxwcm9wZXJ0eSBrZXk9 InRhcmdldHMi
IHZhbHVlPSJwdWJsaXNoIi8+DQogICAgICAgICA8L2FjdG9yUHJvcGVydGll cz4NCiAgICAg
ICAgIDxwcmVyZXF1aXNpdGVzIGFsaWFzPSJhY3Rpb24ucmVxdWlyZW1lbnRz Ij4NCiAgICAg
ICAgICAgIDxhdHRyaWJ1dGUgbmFtZT0iYnVuZGxlLmphciIvPg0KICAgICAg ICAgPC9wcmVy
ZXF1aXNpdGVzPg0KICAgICAgICAgPHByb2R1Y3RzIGFsaWFzPSJhY3Rpb24u b3V0cHV0IiBi
YXNlPSIuLi9zaXRlLnAyLyI+DQogICAgICAgICA8L3Byb2R1Y3RzPg0KICAg ICAgPC9wdWJs
aWM+DQogICAgICA8cHVibGljIG5hbWU9InB1Ymxpc2guc291cmNlLmJ1bmRs ZS5qYXIiIGFj
dG9yPSJhbnQiPg0KICAgICAgICAgPGFjdG9yUHJvcGVydGllcz4NCiAgICAg ICAgICAgIDxw
cm9wZXJ0eSBrZXk9ImJ1aWxkRmlsZSIgdmFsdWU9ImJ1aWxkL3B1Ymxpc2gu YW50Ii8+DQog
ICAgICAgICAgICA8cHJvcGVydHkga2V5PSJ0YXJnZXRzIiB2YWx1ZT0icHVi bGlzaCIvPg0K
ICAgICAgICAgPC9hY3RvclByb3BlcnRpZXM+DQogICAgICAgICA8cHJvcGVy dGllcz4NCiAg
ICAgICAgICAgIDxwcm9wZXJ0eSBrZXk9InB1Ymxpc2guc2l0ZS5wMiIgdmFs dWU9Ii4uL3Np
dGUucDIiLz4NCiAgICAgICAgIDwvcHJvcGVydGllcz4NCiAgICAgICAgIDxw cmVyZXF1aXNp
dGVzIGFsaWFzPSJhY3Rpb24ucmVxdWlyZW1lbnRzIj4NCiAgICAgICAgICAg IDxhdHRyaWJ1
dGUgbmFtZT0ic291cmNlLmJ1bmRsZS5qYXIiLz4NCiAgICAgICAgIDwvcHJl cmVxdWlzaXRl
cz4NCiAgICAgICAgIDxwcm9kdWN0cyBhbGlhcz0iYWN0aW9uLm91dHB1dCIg YmFzZT0iJHtw
dWJsaXNoLnNpdGUucDJ9Ij4NCiAgICAgICAgIDwvcHJvZHVjdHM+DQogICAg ICA8L3B1Ymxp
Yz4NCiAgIDwvYWN0aW9ucz4NCiAgIDxncm91cHM+DQogICAgICA8cHVibGlj IG5hbWU9InB1
Ymxpc2giPg0KICAgICAgICAgPGF0dHJpYnV0ZSBuYW1lPSJwdWJsaXNoLmJ1 bmRsZS5qYXIi
Lz4NCiAgICAgICAgIDxhdHRyaWJ1dGUgbmFtZT0icHVibGlzaC5zb3VyY2Uu YnVuZGxlLmph
ciIgZmlsdGVyPSIoIShjYmkuaW5jbHVkZS5zb3VyY2U9ZmFsc2UpKSIvPg0K ICAgICAgPC9w
dWJsaWM+DQogICA8L2dyb3Vwcz4NCjwvY3NwZWNFeHRlbnNpb24+
name="publish.ant"
filename="publish.ant"
PHByb2plY3Q+DQogICA8YnVja21pbnN0ZXIudmFsdWVmaWxlc2V0IGlkPSJi dW5kbGVzIiB2
YWx1ZT0iJHtmczphY3Rpb24ucmVxdWlyZW1lbnRzfSIgaW5jbHVkZXM9Iiou amFyIi8+DQog
ICANCiAgIDx1cHRvZGF0ZSBwcm9wZXJ0eT0ic2l0ZS51cHRvZGF0ZSIgdmFs dWU9InllcyI+
DQogICAgICA8c3JjZmlsZXMgcmVmaWQ9ImJ1bmRsZXMiLz4NCiAgICAgIDxj aGFpbmVkbWFw
cGVyPg0KICAgICAgICA8ZmxhdHRlbm1hcHBlci8+DQogICAgICAgIDxnbG9i bWFwcGVyIGZy
b209IioiIHRvPSIke3NwOmFjdGlvbi5vdXRwdXR9L3BsdWdpbnMvKiIvPg0K ICAgICAgPC9j
aGFpbmVkbWFwcGVyPg0KICAgPC91cHRvZGF0ZT4NCiAgIDx0YXJnZXQgbmFt ZT0icHVibGlz
aCIgdW5sZXNzPSJzaXRlLnVwdG9kYXRlIj4NCiAgICAgIDxwYXRoY29udmVy dCBwcm9wZXJ0
eT0iaW5wdXQuYnVuZGxlcyIgcmVmaWQ9ImJ1bmRsZXMiLz4NCiAgICAgIDxt a2RpciBkaXI9
IiR7c3A6YWN0aW9uLm91dHB1dH0iLz4NCiAgICAgIDxwMi5wdWJsaXNoLmZl YXR1cmVzQW5k
QnVuZGxlcyByZXBvc2l0b3J5PSJmaWxlOi8vLyR7c3A6YWN0aW9uLm91dHB1 dH0iPg0KICAg
ICAgICAgPGJ1bmRsZXMgcmVmaWQ9ImJ1bmRsZXMiLz4NCiAgICAgIDwvcDIu cHVibGlzaC5m
ZWF0dXJlc0FuZEJ1bmRsZXM+DQogICA8L3RhcmdldD4NCjwvcHJvamVjdD4=
--------------010208020400080206060501--
Re: Using headless Buckminster to create p2 reporsitory with multiple versions [message #519759 is a reply to message #519716] Tue, 09 March 2010 21:07 Go to previous messageGo to next message
Hi Carsten!
Thanks for the input.
I've found some p2 commands that I hoped might help me, but I haven't got around to investigating it yet. It will happen in the next few weeks.
I would like to look at your solution also, but when I read your post with my browser, it shows up as some text representation of a mime attachment.
Could you just paste the contents of the file(s) instead?
Thanks.
/John.
Re: Using headless Buckminster to create p2 reporsitory with multiple versions [message #519885 is a reply to message #519759] Wed, 10 March 2010 10:56 Go to previous message
Hi John,
Sure, here you go.
buckminster.cspex:
<cspecExtension
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0"
xmlns="http://www.eclipse.org/buckminster/CSpec-1.0">
<actions>
<public name="publish.bundle.jar" actor="ant">
<actorProperties>
<property key="buildFile" value="build/publish.ant"/>
<property key="targets" value="publish"/>
</actorProperties>
<prerequisites alias="action.requirements">
<attribute name="bundle.jar"/>
</prerequisites>
<products alias="action.output" base="../site.p2/">
</products>
</public>
<public name="publish.source.bundle.jar" actor="ant">
<actorProperties>
</actorProperties>
<properties>
<property key="publish.site.p2" value="../site.p2"/>
</properties>
<attribute name="source.bundle.jar"/>
</prerequisites>
<products alias="action.output" base="${publish.site.p2}">
</products>
</public>
</actions>
<groups>
<public name="publish">
<attribute name="publish.bundle.jar"/>
<attribute name="publish.source.bundle.jar" filter="(!(cbi.include.source=false))"/>
</public>
</groups>
</cspecExtension>
build/publish.ant:
<project>
<buckminster.valuefileset id="bundles" value="${fs:action.requirements}" includes="*.jar"/>
<uptodate property="site.uptodate" value="yes">
<srcfiles refid="bundles"/>
<chainedmapper>
<flattenmapper/>
<globmapper from="*" to="${sp:action.output}/plugins/*"/>
</chainedmapper>
</uptodate>
<target name="publish" unless="site.uptodate">
<pathconvert property="input.bundles" refid="bundles"/>
<mkdir dir="${sp:action.output}"/>
<p2.publish.featuresAndBundles repository="file:///${sp:action.output}">
<bundles refid="bundles"/>
</p2.publish.featuresAndBundles>
</target>
</project>
On 09.03.2010 22:07, John wrote:
> Hi Carsten!
> Thanks.
> /John.
Previous Topic:Getting components from Maven
Next Topic:buckminster resets "build automatically" in my workspace
Current Time: Thu Apr 19 12:14:50 GMT 2018
Powered by FUDForum. Page generated in 0.02307 seconds
