Home » Modeling » EMF » launching CDO Server(CDO server + org.eclipse.equinox.launcher)
launching CDO Server [message #516977] Thu, 25 February 2010 16:34 Go to next message
mjido is currently offline mjidoFriend
Hello every body
I'm trying to launch CDO server using a batch command:
java -Xmx1100M -XX:PermSize=512M -XX:MaxPermSize=500M -jar D:\\eclipse\\plugins\\org.eclipse.equinox.launcher_1.0.101.R 34x_v20081125.jar -data D:\\tmpWS -product org.eclipse.emf.cdo.server.product
the server is started but it can not find the cd-server.xml
[WARN] CDO server configuration not found: xxxx\cdo-server.xml
where xxx is the working directory (i use ms-dos)
How can i specify the path of the cd-server file ?
Thank you in advance.
Re: launching CDO Server [message #517005 is a reply to message #516977] Thu, 25 February 2010 16:55 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 25.02.2010 17:34, schrieb mjido:
> Hello every body
You can specify the directory where config files are searched with
-Dnet4j.config="my.folder".
Cheers
/Eike
Re: launching CDO Server [message #517137 is a reply to message #517005] Fri, 26 February 2010 11:31 Go to previous message
It works Smile
Thank you Eike
Previous Topic:Ecore annotations propagating to genmodel
Next Topic:CDO Server
Current Time: Mon Apr 23 19:38:45 GMT 2018
Powered by FUDForum. Page generated in 0.01514 seconds
