Home » Language IDEs » Java Development Tools (JDT) » Java debugging - cannot be resolved(At breakpoint in library method, get "cannot be resolved" when trying to display variables.)
Java debugging - cannot be resolved [message #515146] Wed, 17 February 2010 21:37 Go to next message
S B is currently offline S BFriend
Using Eclipse Version: 3.4.1
Build id: M20080911-1700
Workspace default JRE jdk1.6.0_01
I'm trying to debug into the Swing components to better understand them.
FYI: My main code is the TableExample3.Java from C:\Program Files\Java\jdk1.6.0_01\demo\jfc\TableExample\src folder.
I having some of usage problems with the debugger, I need some advice.
When I run the debugger and step into a Swing method, and look at the Variables tab, the method parameters are referred to as "arg0", "arg1", etc rather than their source names. The values are correct. The source code is visible in a source window, where I set the breakpoint. I cannot view expressions using real variable names. I try to set a "watch" using the variable names and it always says "..cannot be resolved". It seems there is some problem with associating the source with the library, yet the debugger is aware of the source since it displays it in a pane.
I have tried two different ways to associate the Swing source with the runtime code: 1) in the project properties, associated the source for the rt.jar 2) compiled the Swing source myself, created a jar, and added the jar to my project libraries, and associated the source. I even added the source into my Swing jar using the export utility. But I always see the parameter variables as "arg0", etc, and I cannot view expressions by variable names (unless I type in "arg0", etc).
Everything works fine in my project source. If I step into a method in the project (not in a library), the method parameters are displayed with their real names in the "Variables" tab and I can set expressions.
[Updated on: Wed, 17 February 2010 21:40]
Report message to a moderator
Re: Java debugging - cannot be resolved [message #515158 is a reply to message #515146] Wed, 17 February 2010 22:13 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
That's because code that Sun released in the Java JDK itself had all of
that information stripped out. It's not there so it can't be reconstructed.
Rich Kulp
Re: Java debugging - cannot be resolved [message #515162 is a reply to message #515158] Wed, 17 February 2010 23:06 Go to previous messageGo to next message
Thanks for the reply.
I have the same problem when I compile the Swing source code into a jar with a separate project and include that jar in my project and attach the source to the jar in the Project build properties. I also place the built jar (e.g. myswing.jar) higher than the jdk jars in the classpath under the "Order and Export" tab of the Java Build properties.
Is there something needed when building a jar to ensure that variable names are available to the debugger?
[Updated on: Wed, 17 February 2010 23:07]
Re: Java debugging - cannot be resolved [message #515327 is a reply to message #515162] Thu, 18 February 2010 13:59 Go to previous messageGo to next message
--------------000200010803090107000203
Content-Type: text/plain; charset=UTF-8; format=flowed
yeah, but by default you should be getting debugging info.
I've attached an image of the settings.
Rich Kulp
Content-Type: image/jpeg;
name="jdtsettings.jpg"
Content-Disposition: inline;
filename="jdtsettings.jpg"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAMCAgMCAgMDAwMEAwMEBQgFBQQE BQoHBwYIDAoM
DAsKCwsNDhIQDQ4RDgsLEBYQERMUFRUVDA8XGBYUGBIUFRT/2wBDAQMEBAUE BQkFBQkUDQsN
FBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQUFBQU FBQUFBT/wAAR
CADkAoADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD9U6+A/wBqX/lIX8Kf+wfo f/p5mr78r4D/
AGpf+Uhfwp/7B+h/+nmavu+Df9/q/wDXqp/6SeHnH+6/9vR/NH35RRRXwh7h Q06TfeaoN+7Z
chcb9239zGcY3tjrnGE652nO5oPFPizQ/A2hXWt+JNZ0/wAP6La7ftGo6pdJ bW8O5gi75HIV
csyqMnksB1NFsbmXUNQEFzEsaXKq6SKZCP3cJwMSnb8u/javLK204Jk85/ai h1KX9mD4q2S2
t3rep6h4Zv8AT7Sz0XTJ7ieeee1aCNFhi8x23Sv1AwinLEBGekhnqOk6tY6/ pVlqemXtvqOm
3sKXNreWkqywzxOoZJEdSQyspBDAkEEEUXurWOnXNhb3d7b2txfzG2s4ppVR rmURvKY4wTl2
EcUj7Rk7Y3PRSR81XOmeJtT8TeL/AB/pT+OEvj458N2+i2lxc6nDaf2JcQaI l8f7LlYQ7Qlx
qRkd4N8TrKxKSRZTzXT/AAtrviCDQr/xVa/EDxD4f0LxNb6hq/jKzk8TaZqO pF9L1aB3ttFY
i6sNk93Zq40/dBIs5IEccMsUDEfdVZNx/Yeka7Ddz/2fZa1rHl6bFPJsjuL7 ylnnS3VjhpNi
m6kCDO0GVgANxr4r+PGr/FhvGnjO58Ljxhpuq31l4g099D0nSdeuYoraLRr/ APs+6gvzO+mr
LNPBp8qraQRXCSXAhZy6ziTqvil8Mb3RfiZpOmyR/EDUfhZoF7pev3F1Z6tr Wo6jDPPZeIbO
4NtdRyyXz/O2kq8EDsEWQuUVJJWYA+oPEmreFX1XRfDmv3ujnUtVm+06XpOp SxedeS2rJceZ
BE5zI0LLHLuUEoVVuMA1a0DxZofiv+0v7E1nT9Z/s29k02+/s+6Sf7LdR48y 3l2E7JV3DcjY
YZGRzXivx9+GeuePPjB4J1DQIPs+taH4Z1290bWZ0dbW01Vb3RpLaKeZFLJF cLFcQyqhDyW7
3SKcFseFa38JvF3w31/xBoGj6l4o0PwAPEE091rVvo2s6le6vff2JoCQ3Uv9 jT2t3K0sias8
twGMDTCTzVMpiKgH3rRXx/s+JFv4026hrvjDVNeTwzi41z+xdTsovC0y6N81 z9gtml0nXZZL
xy/2eFnmikl2IZ44gYMq5bxbcfCzTtLk03xh4b0WTWrmb/hLPN8ZazeXpigg jib+zorqDVbO
KdpLs+VNK8ELWXWY3MExAPtWqmk6tY6/pVlqemXtvqOm3sKXNreWkqywzxOo ZJEdSQyspBDA
kEEEV8QR+KfGn9heCdY+I118QNM+IV9rXgYae1pHqtlpf2O4bRk1CK8jtQlg kr3UmrI0d2BL
8yKF2eQK1fgz4Z+JEHw90/xdrM3xAPjq11rwXYJb6nqWptE1hLYaDFqrSWEk hgkwZ9UMszxF
o5BK5ZXi3KAfatFfJX7P2ranD8aPA+maze+OE8YXPgbVLnxnZ+IZdWGmy6xH c6Qsklmlyfsb
Kkk12FawHlBZAFwjR5+taACiiigAooooA4Lx/wD8hCz/AO23/oMNcLff6v8A Ku5+IBxqFl/2
2/8AQYa4e+H7rP0r7DLf4EPn+bPHxXxS/rojrrD/AJFu4/7C2kf+g2NaVZun nPhuf/sLaR/6
DY1pV8Zjf4rPYofAV5P+QjB/1yk/mlWKryf8hGD/AK5SfzSrFecjoIL68Swt zKyvISyxpHGM
s7swVVHbJYgckDnkgVAb24sYi+pJbRszrHFFYyS3MkjHJICiJSSMZ+Xdxk9B mrF5aLeQeWzM
hDpIjpjcjqwZGGcjIZQcEEccgjisP/hDIZXmuJ206a6kkil2f2UBAWUTBmkQ yEyMfPJySOUU
84xVoRoHxHYhyu6c7EEkrLbSlYV3MuZWC4jwUcHeRja2cYNLP4hsLYTtJK6R Qh90xhfyiUBL
qr42swCtlVJPytxwcQy+G4zpWpWSTogvLNbQeVapDHHgzsSqKcAZn4HJ+Xli Tmor3wlb3L6q
Y2tYPtYutsq6dGbnM4fcXmJJIHmNgKFOFUbuuSyDUvPrVqlvDcZma2lVnWdL eRowinBdmC4V
O+8kKRyDjmobXxBDNayTSQ3Eey5ktlVbeV/MZZHUCPCfvCRGWITdtGc9DTPF XhxPFFzdu80C
rPC0Ia7sxctCDn5osuvlthuW5+4nTHLtR8PpqG5Xkt5oI7yS6t4buyEyKZGl Z/MBcCTmZioA
XGFyWwclkBDrPieGx0m8uLUSXFzFbSTLGtvI/llQw/ehRmMblIO7bgqw42nG /PF5M8kec7GK
59cGsC88MNLp9xZW17DaRXVr9lnK6eoUDdKw8qNHQIMzydS5OFyc5J3Lzdc3 yypM0UQld3QI
CZFKsAvt8xU5H93HeiyAy49YF5daetqsjW9xO0bTyW8ixuoglkBjcgK+TEOV JGD7in/2/aeX
uP2hHJULA9rKsz7s7SsRXewO1uQCPlb+6cQR+HpDaWdtLqLLDZxmGD7PB5cq J9mkgUmTecuA
6ncFHKnjnitH4QjjiuQjaZC85hwsGk+XHD5Yl+ZQJgfMzLxJuBAX16FkBrxa hHPd/ZkiuWlC
hnH2WXEWV3ASNtwjbcHaxB5HHIqjHrMj6nexEbIbeeG1ANtKVZ5DFhjMAVB/ fACPBJIySAeH
2vh6K11OK6FyxSGMIAsZWa5IiEYa4k34k7sAV4OMEDOZxpKnzMzEeZqUN+cJ naI/I+XrznyO
vbd3xRZAVtM8QQ3Vjp7TMfPntreWVo4X8mN5Y1YIXwVUksAFZsnK+ozesb+L UY2kgWZoQRiZ
oHSOTOcFHICuOOqkjp6isvTPCVvptzZyhrWRoEti08mnRyXDPFFHGNkjE+Wp 8pTjaxG5iCCR
i3ouiro8c371HeXYBDbQmC3hCg/cj3sAWLZYjGcA4zkkaQCrrtq9v56i5eEu EjdbWUicnOPK
wv73hSfkzwM9OaY/iSwRypeYlUDvttpCEyzKFYhflcsjKEOGLDbjPFMg0W5t 7WxjS/i3WG1L
TdaEhEETQ/vP3o8w7G7bPm56cU+28PR22P8ASncma1ndvKAy0d1LcvgbuAzS lQMnAHJNFkAp
8R2IcrunOxBJKy20pWFdzLmVguI8FHB3kY2tnGDTdX8QQ6Va3sjRStJbwvIo eJ0jlZUL7FkK
7S2ATgEnAJxwapDw1PK+o2ZvFh0+7g8uZvs2+R9891IyofMAQqs4GSGySDjg ipb7wjb6lqFz
cTywokzXLMyWYN0wmikj2m4LfdXzeBswAiDnGaLICS81/wCz6haQiGfy5HUO hs5zOVaO4KkR
bAwy0HXk43HAAzUN/wCJ0glUwtCYkVpJfNEisoENy5DDb8hDW5Ujlh8wK5HN qfSLu41BdROo
wrflo2ZhZExfKlypATzc9Ln+91XPfFVbnwfHPbzRfbXDSRSIz+QMF3S8DMBu 4G68JAyeE6nO
adkLUvWWsx3blHimik+1TWi5hkCO0bS/dcqAflhZjgnHQ81PBqVvdSpHE5Z3 EpUbGGRFII5D
nHZyB79s1U1TTJ5LK7ht5VcSXfnWwaLDW7PcGVpXJYh9jtuCbRkJtO7NaEVs to0ENrI8Gn29
t9nitQM5AKbCWJzwFbjuWz2pNIZJRRRUjCiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAyrzUm0bw3dXywNcm3+0S+UrBSwEshPJ6Due+BwCeKtavf/2VpN7e+X5v 2aB5tmcbtqk4
z26VVvNPk1bw3dWUcywNc/aITIybwoaWQHjI5wTjnr69KtNbXUnl7rzy/wBw 0cnkxAZkO3Ei
7t2MYbCnI+bnOKbAr6Fq0mrxSyk2LxKwVXsbz7QpPUgnYuCMj169q06z9O06 e3u7i7u7iO4u
ZkSImGIxIEQsRwWY5y7ZOfTgY50KQBRRRQAVpwy+VYQsc7QJCQoJPGOw5NZl XHfy7O0bO0Zk
GfxWtIbksz5vFNjJZ288crETNsEajL7uMgqPTPP4YzkZS5Ob20/3bj/2hUa6 bYw6hJeoiC4c
YJzwD3IHqe5/xOXSnddWTAHBW4wfXmCtJbMS3Ek/5CMH/XKT+aV8I6lq1joH /BVfSdT1O9t9
O02yhurm6vLuVYoYIk8PuzyO7EBVVQSWJAABJr7uk/5CMH/XKT+aV+c3xd8F X3j7/gpr4e07
TJbePUrTU7PWbVLtmSGeWxsIr1IHdVYxrI1uIzIFcoHLBH27G+14S2zL/sHq f+lQPIzL4sP/
ANfF/wCkyP1Xr4D/AGpf+Uhnwp/7B+h/+nmavvyvgL9qX/lIb8KP+wfon/p5 mr0eDf8Af6v/
AF6qf+knLnP+6/8Ab0fzR9+1BfX9tplpLdXlxFaW0Q3STTuERB6ljwKnrlPi ddJYeEjdyHbF
bX9hPI/ZUS8hZmPsACT9K+GirySPak7Jsfo3jnw7f6ndW8HiHTLmae4At4Y7 +N2k/doMIokY
9Q3AC85+U/ebd1bVrHQNKvdT1O9t9O02yhe5ury7lWKGCJFLPI7sQFVVBJYk AAEmvnLRPiN4
s8Qa5pum63408L+I7SfULLy7TQ/Dk+nz71u4X3mSS/uAVCq+VCA9DuAUg+96 74jXwZ4dutW1
n7XfQW/l710XSLm8nO7Yny28Allf5yT8qnap54UtQ0rXQk23Zk/hbxZofjnQ rXW/Des6f4g0
W63fZ9R0u6S5t5trFG2SISrYZWU4PBUjqK1q+CviV/wsrw78Npp9AsvFHhvU oZvEvijw1Lpu
ia7qM2q3V7q9/d2tvPaWE8UdqyRGxfGpwyoTeMjRL5Nwje6z2PxL0Tx3r9lZ Rah4i0Xwv/aP
izR4n1CS2l16e9imFppEt1IPJMUM7akDHgCCMaM2WKy1JZ9AUV81fskzeKbX xV450vUdW8Qa
34WhstLudPu9d0DXdLxeSPerdpGdauLi5kxHFZk7JfKXcu1FZpGf6VoAKKKK ACiiigDn734e
+FdR8ZWHi+78M6PdeLLCE21nr01hE99bREODHHOV3opEsg2ggfvH/vHPQUUU Ac/4b+HvhXwd
qutanoHhnR9D1LW5vtOqXmm2EVvNfy7nbzJ3RQZW3SSHcxJy7Hua6CiigAoo ooAKKKKAOA+I
X/IQsfrN/wCgw1xN9/qPxFdt8Qv+QhY/Wb/0GGuJvv8AUfiK+vy7+BD5/mzx sV8Uv66I6zTv
+RZn/wCwtpH/AKDY1p1mad/yLM//AGFtI/8AQbGtOvjcd/GZ7GH/AIaK8n/I Rg/65SfzSrFV
5P8AkIwf9cpP5pVivOR0hRUV3dxWVu00zbI1xzgkkk4AAHJJJAAHJJAFFtcf aovMENzCu4ri
5t5IWJGOgdQSOevSqAlooopAFFFFABRRRQAUUVRutat7XTZr7bLNBEJifKiY n91v3+wwY2GT
gZHXkUAXqKr6tfLo1rcTzxyuIEkd1iQscIrM3TgcKeSQM4GeRT0uUe6nt8Os 0IBdXjZcAs6A
5I5BMb4I64z0INMCWiiikAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAZjTadA7p/aBhO9i0a3zoAxJJ4Dcck0fa9O/6Cr/8A gxf/AOLqVdVh
0bRZLq5uPs1tE87O5JAH75/zPQAdT0q7d6l9gtJrmed0ghRpJGyThQMk4HPQ VQGb9r07/oKv
/wCDF/8A4uj7Xp3/AEFX/wDBi/8A8XVyw1sal5nlG7TZjPnwSw9c9N6jPTtV v7RL/wA9H/76
NFwMj7Xp3/QVf/wYv/8AF0fa9O/6Cr/+DF//AIutf7RL/wA9H/76NH2iX/no /wD30aLgZH2v
Tv8AoKv/AODF/wD4unLf2KDC6vIo9tSk/wDi61ftEv8Az0f/AL6NaltO4soR vbLFySGIPBFV
FXe4nocv/aVl/wBBmX/wZSf/ABdSWs1pc3IaK9N3MqEDfdNMVUkZwCxxyB+l bk99tijdbljG
+CriY4OemDnvms29leW+st7s+1LgAscnGYD1/GqlGy3FfUhk/wCQjB/1yk/m lfDcf/KWzw7/
ANt//TC1fckn/IRg/wCuUn80r83Pjn4W1Txl/wAFINK0vSrX+0ZDe21zdaX5 ip/aVlDp0U15
ZfORG32i2jng2Sssb+btkZUZmH2/CW2Zf9g9T/0qB4+ZfFh/+vi/9JkfrDXw F+1L/wApDfhR
/wBg/RP/AE8zV9+18B/tS/8AKQv4U/8AYP0P/wBPM1ejwb/v9X/r1U/9JOXO f91/7ej+aPvy
iiivhD3Chp0m+81Qb92y5C437tv7mM4xvbHXOMJ1ztOdzX6oadJvvNUG/dsu QuN+7b+5jOMb
2x1zjCdc7Tnc1+kgOa1X4geH9L1CK0m8QaTbypMUuYpryFXjGxjyGkUqdwUd GPOMc7l3rG/t
tTtIrqzuIru2lG6OaBw6OPUMODXyZ8U/GvjrSfGPhS18JeMtF0Cw03xLqc+q 2eoaZLOyq6am
Fkn230HnwM01ttgCbhJ5c28qm2voP4U3F1qPhK2vVmi+zXN5eXG1oSXdXurh twbdjB3RkcHg
HruBXWUUr2MoybsdD/wlmh/8JV/wjH9s6f8A8JJ9i/tL+x/tSfbPsu/y/tHk 53+Vv+Tfjbu4
zmtavj/+xPin/wALl/4Wf/wgun/YP+Fgf2b5v9qXX9u/2Bj+xfs/k/YcfYft H/E62ed5WPnx
u/e15V4e8WarL8BPh/rem6z8UH0XUNF8N/8ACcajf3XiA3Fzf3GsaGi/2dJO fOfzYJNXU/2Y
Srh0ByTb1man6K0V8QeLrLx/fx20enaz440P4SDU79tLuL7SPEupauw+y6Z9 nSeO0ubfVwv2
k66Q1y5iCiMFSpsyNXxRqXxWtPH3w8muZ/FFr4hsJvDem3KRaDqlzDrVrLLa jU724axun0ay
YCe/jeKaKZ0Ft5kcoD2zoAfZVFfGsuh+N9M/Zt+Eun63qnjhdU1TTLbVfEPi S7h1/VNStNRW
zgRLB7LSLi2ukVlebLlvLVrQmdZLi480nww0z4nan4STx/4hfxwnxBPiDwdb m0uLm/htPsVx
Y6CmrH+ywwtdoa41QyP5H7p1lYFGiBQA+yqK+Kr228Y3fwf0OK31H4gaV4ya 90//AIWZeX9h
4jvkjk+xXZm/s6G3mhZ4jqHkg/2NIsYQoWzbAqfpX4CW2uWnwn0KLxDqOoar qK+fsvNUsHsb
iS28+Q22+GWaaZMQeUB9oka4IAM+JjIoAPQKKKKACiiigAooooA4D4hf8hCx +s3/AKDDXE33
+o/EV3Pj5Q1/Z57Gb+UNcLeHMZHbIr6/Lf4EPn+bPHxS96X9dEdbp3/Isz/9 hbSP/QbGtOs3
Txjw3P8A9hbSP/QbGtKvjcb/ABWexQ+Aryf8hGD/AK5SfzSrFV5P+QjB/wBc pP5pVivOR0Fb
UoxLZuv2aS7OVxFC6o+dwwyszKFIOGB3AjGQc4rG/sefzI5bvSm1G0zMIdMu J4rhociHa7mW
QoxylxyXYgSKBgZA6KiqTEc7aaLf2sVtYSW/22Rr2xubi9E8Zj/drbLLuLsH Y5gkPCnIYepA
ZaeHE0/TdEgk0ePUUhsQtxaM0Umbpkh/eN5rBDtCSIOflDAKMZx0tFO4WMDS /D8tvr015cRT
NN59xJJdebbJE6tv8tAVQzOFDR/KxCApkHCrkvNIuJ5dX8qyRr64SQWuqOYv 9FUwBFUMx8xT
vEh/dqf9YD1Jxv0UXCxz0fhqG71OCU6JbWWkiZWXT5lgKjbBdAyNGjMhJaSA ZOWJTkYUGs4a
GbOXRUutKTUA6Wvm2mYX866+yXZndg7BWbd5ZZ2PO0cnAFdlRT5gscfq/hzU JtNWGOzL3KQT
taC2Nrm1keWRkVnl4QInkKPIORtbB4WptZ8MSSWd9a2emQiQ3F/I10phH2jz IbvyvmzvO3zY
0+YAAnjIGa6qilcLHKaz4amvY71rLSYtMt5EkWGxVoEw32W7QuVjYplmlgXO dx288LmryeG4
31O/N5psN0t4LmMT5iJhjNzds3zEhhvSaMDZk8c4wK3aKfMFjE0m0e9023v7 mNNSur2a0kDS
ERL5McimOQgYABJefbjOHCc4rbooqW7jCiiikAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFABRRRQBiavBPd+ENRt7aFriedLqFI1KgktJIo 5YgYGcnnoO9W
75ZdQtGtnsd8FzayCVZpgm1iFAjYrk8hmyy5xt75FSxQXduhSOW2Me92XzIG LDcxbGQ4zyx7
U/F7/wA9LP8A8B3/APjlMDP0C3uYZbktFdW1oyoI4L2486UON29t29/lIKAD d1VuBnJ2Kr4v
f+eln/4Dv/8AHKMXv/PSz/8AAd//AI5QBYoqvi9/56Wf/gO//wAcoxe/89LP /wAB3/8AjlAF
irrEGyt0ZVdHEqsrDIIyvBrKxe/89LP/AMB3/wDjlSGa+aJI2eyZUJK/6PIC M9eRLVxaTE9T
NTwwkdyFeZpdOjbzIrVjkKx659QO31PvnQmObyz/AN24/wDaFGbs97P/AL8y /wDx2kWKZp4X
laAJEjqqQRMuSxUkks7Z+4KqUk0JIST/AJCMH/XKT+aV8Nx/8pbPDv8A23/9 MLV9ySf8hGD/
AK5SfzSvzc+Of9uf8PINK/sH+0PO+2232/8Asnf9s/sz+zov7R8jy/3vm/Y/ tO3yP327Hk/v
dlfb8JbZl/2D1P8A0qB4+ZfFh/8Ar4v/AEmR+sNfAf7Uv/KQv4U/9g/Q/wD0 8zV9+V8BftS/
8pDfhR/2D9E/9PM1ejwb/v8AV/69VP8A0k5c5/3X/t6P5o+/aKKK+EPcKGnS b7zVBv3bLkLj
fu2/uYzjG9sdc4wnXO053Nfqhp0m+81Qb92y5C437tv7mM4xvbHXOMJ1ztOd zX6SA5fWfHPh
2w1O1t5/EOmW00FwRcQyX8aNH+7cYdTIp6leCG5x8o+8vQ2N/banaRXVncRX dtKN0c0Dh0ce
oYcGvkz4p+NfHWk+MfClr4S8ZaLoFhpviXU59Vs9Q0yWdlV01MLJPtvoPPgZ prbbAE3CTy5t
5VNtfQfwpuLrUfCVterNF9muby8uNrQku6vdXDbg27GDujI4PAPXcCusopXs Zxk3a5c0D4se
B/FfirUvDGieMvD+s+JNN8z7do+n6pBPeWvluI5PNhRy6bXYI24DDEA8mqvj XU/AXww8ARf8
JGmj6L4T0aEXFrZS2yeTCtjE12gt7dVJZoI7RpkSJSyi33KPk4+P9R8GePdb 0rxPonhZvHF1
4stfEHjq/sdL1HSX0nTdGa5XXEsr/T9SNvbiWeSS7tVUNdTqFvZZBGvlLJBb /aW8ReNPi7de
Nk8FaV8QLjwtceGW09rC48P6rp8VxO2h+LPMQW9xDGZN0z6SpIUhpPsq5LBA MzQ+1NZ8U6X4
f1HQrC/uvs93rl62n6fH5bN586281yUyAQv7m2mbLYHyYzkgHK/4Wx4H/wCE 7/4Qn/hMvD//
AAmf/Quf2pB/aP8AqvO/499/mf6r95937vzdOa+dbPSdT1H4/eAbjWrLxxde MrDxzrlzfyzR
as+gW2jmx1iLTpIzj+zEY28unJuixLvkcSfvGmB6vTPhN4q8Y/FX4oLqGpW+ k+BJfHOka4tk
+jS/br+Wy07Rp4pYLxpxEIPtFokbj7O5PlTqHViDGAe/6nq1jotslxqF7b2F u80NsstzKsat
LLIsUUYLEAs8joir1ZmUDJIFVNG8U6X4g1HXrCwuvtF3od6un6hH5bL5E7W8 NyEyQA37m5hb
K5Hz4zkED4W1vTfiJ458QanZahaeMBouo/ZPEHibw/DpviGP+xZ7TxBpFy8F nqFxcSR3MsVs
dTEZ0gQCXyN0cbH7OqelaL4D1PRta8Y+NvC8Hji2vpfHPheHTEvb3Vtt1o8l loFreTXFjcPt
mYQNerJPcRNLG0TszrJCCgB9a0UUUAFFFFABRRRQAUUUUAcJ49/4/rT/ALa/ yhrg7v7h+orv
PHv/AB/Wn/bX+UNcHd/cP1FfX5b/AAY/P82eRivif9djr7D/AJFu4/7C2kf+ g2NaVZth/wAi
3cf9hbSP/QbGtKvjcb/FZ69D4CvJ/wAhGD/rlJ/NKsVXk/5CMH/XKT+aVYrz kdAUVk+KPs39
mRfbfK+x/bbTz/Px5fl/aY927PG3Gc54xWSZ0iuFuNKeyi0ze32ZyiC0WZbS 7aQqQPlUbYdx
TAyX/iL1SVxHWVEt3A9w0CzRtOucxhxuGApPHXgOn/fQ9RXL/wBts+lQFdRl gVp5FbU7u8t4
7eTYqZWKUQMGBL5UbNx2vnbtIqrpmo3Erm9MiW8l1EJJplX5YElTSfMcZyAE V2bLZA25ORmm
o3C529FcxFf392wjsb03FtcSS2Vnet5bb5NsD+aWVQrCNTdHgAHytp+brJeX 9zc+Dtev5UEZ
KT+TBJtkEYSBQ6HjD4mEykkYO044xSsB0LzRxNGruqNI21AxwWOCcD1OAT9A adXJ6zqckOro
8V6bjV4LjUDHpIEeECW90sR8tVEmWCo33sHzOAAVw/T7i8vri2tl1yO4hkuR G1zp8qXDcW9x
Iy+YbdYxzFH8oVmAJJOCtPlC51NRR3cE1xNBHNG88O3zY1cFo8jI3DqMjpmu MvLopaa3d3N6
UmbTpobeGRYsXZhkvUJYMh3lQqMwTaPn5GCBWjdPdaVZB7V5buVtR1SSG1ki jZFZBfEBFVA2
WKrk5z1AwDiiwXOnorlbC5v72e2totctp4pLkRPdWjLd4HkTu4DiGKPP7tCo wxBOWypCm/o2
ovea5qMD3DXRiEjBbWaJ7e3QSBVWT5BIsuOoJKn5iOhClgubdRTXcFu6JLNH E7/dV3ALfMF4
z15ZR9WA71gnWFjt9QeTUXOogyoLBZIUW1TzvLSZgULKu3bIXYlQHLbSMCsy xv5NR1O0d7uG
9WG6SBJ4JhMrgXemPneEQMcyEcIuMY5PJErhc7aonu4ESd2mjVIM+cxcAR/K GO704IPPY5rk
9M1jUbi0Mk+pWodo4mukifzXsN8sauWHkqsOxHkJErucp3CvnT0GK01bTNch F0dUsri+eNpm
kRjIptbcMN0YUeo4A6evNFgub1FcrfeI7qTXphFfWcDyvcD7JeXC5h8uGRxI 0YjDIhaMHcZG
+VwdvzDFeTX5I9Nt5hqFw8Pmyxs8dxbNcXbqI8C0/dbJEy5zkB88cEbCrAdl TZpo7eJ5ZXWK
JFLO7nCqByST2FchqOsanbvrLfb7aCe3S9IsfM82aFI1k8tzEIcqSURt7yFS H4HzKBpz6VAv
iG+stRv5JftFnHbmL93Ct4c3PmBRgthAy8K2QCpYnNOwXN6ioYLn7Vc6g5nM zi6KlPL2rDmO
NtgP8X3t2f8AbA7VNSGFFFFIAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKAKNpaR
TwGSQzO7Sy5P2mVRxK4AADADgCpv7Pt/7s3/AIFTf/F1zPilYH07RhcyWcMB 1Kfc+oRiSAcX
ONyllB5xjkc4qGXUJLWy1I6Ve2qWNjpX2mNbGFBE0x88Fl6gLuTO3nkDn7wZ 3A6z+z7f+7N/
4FTf/F0f2fb/AN2b/wACpv8A4uub1rU73S3mjfUtlxFaia2Ty0UX05aTMQUg kgbYwFQ7sOMs
SQa1vD011dw3c9zcecDdTxRRhAoREmdRyOScAc+gHGcli4F7+z7f+7N/4FTf /F0f2fb/AN2b
/wACpv8A4urFFFwK/wDZ9v8A3Zv/AAKm/wDi60INEsntY3Kz73Lcm7mxxj/b 96r1fD4srddz
IWEgDrjKnK8jPFaQ1ZLKk2j2sYHyyZP/AE8z/wDxyqb28dte2vlCRN6TBwZp HVtpiwcMxx94
1QVNakljsZp9sMBDG9X70q/wrz34Oc/jn+LSnObyz/3bj/2hVySsxLcZJ/yE YP8ArlJ/NK+G
4/8AlLZ4d/7b/wDphavuST/kIwf9cpP5pXw3H/yls8O/9t//AEwtX2vCW2Zf 9g9T/wBKgeRm
XxYf/r4v/SZH6RV8BftS/wDKQ34Uf9g/RP8A08zV9+18B/tS/wDKQz4U/wDY P0P/ANPM1ejw
b/v9X/r1U/8ASTlzn/df+3o/mj78ooor4Q9woadJvvNUG/dsuQuN+7b+5jOM b2x1zjCdc7Tn
c1+qGnSb7zVBv3bLkLjfu2/uYzjG9sdc4wnXO053NfpIDl9Z8c+HbDU7W3n8 Q6ZbTQXBFxDJ
fxo0f7txh1MinqV4IbnHyj7y9DY39tqdpFdWdxFd20o3RzQOHRx6hhwa+TPi n418daT4x8KW
vhLxlougWGm+JdTn1Wz1DTJZ2VXTUwsk+2+g8+BmmttsATcJPLm3lU219B/C m4utR8JW16s0
X2a5vLy42tCS7q91cNuDbsYO6Mjg8A9dwK6yilexnGTdrlzX/ix4H8KeKtN8 Ma34y8P6N4k1
Ly/sOj6hqkEF5deY5jj8qF3DvudSi7QcsCByK6uvFPh14iT4XaxrHhfxNpXi CXxFrfia/wBQ
j1jT/D99qNnfQXV45snlvYIXji8m2NvasLhozEtoAB5CwyP4rpH/AAsj/hHN N+x/8LA/tX+x
bX/hZ327+0/+P/8AtHTPtv8AZXnfL/x6f29t/sf5f9V5Xz/ZKzND6/0bxTpf iDUdesLC6+0X
eh3q6fqEflsvkTtbw3ITJADfubmFsrkfPjOQQDxT4s0PwNoV1rfiTWdP8P6L a7ftGo6pdJbW
8O5gi75HIVcsyqMnksB1NfC1x4c8Spq3iOTw1e/EDwz8Mr7xNeXZvdU0PxZf 6pd3I0jQorYu
kFzbaqYt0eqKJJHa3HlBWUt9nK/SnjWx8r4P+ALzxvqfjC28X6V9knTXvDfh 37fqltqZspIZ
5ms7SG9t13xy3UbApLCnnYRt3lPQB6X4S+IXhXx/bC48MeJtH8R25hW5EukX 8V0piaSWJZMx
sRtMlvOgboWhkHVGAtaz4p0vw/qOhWF/dfZ7vXL1tP0+Py2bz51t5rkpkAhf 3NtM2WwPkxnJ
APzB4O8Fa943+Jd7qXjmXxxod94k8Jf2BoPiDRWvrCVoobvWwt1ex26i3trs 2N1YXC/bIowl
xM4hjjkR4k5/xN/wt/4meE/DHxC0f/S/F817dQaFBoW59JhktvDOuQR6lGtx ujWK61K5cxXD
t5c1q2m7sMWBAPtWivn/APZS03xDp/8AwlP2/wAQ+INe0F/sv2L+3dB1jTPK uR532jy/7Zvb
m+kyhts/ct12r5W6Rrjb9AUAFFFFABRRRQAUUUUAcH49IF/Z/wDbb+UNcJec IfqK7rx//wAh
Cz/7bf8AoMNcLff6v8q+vy3+BD5/mzx8V8T/AK6I6+w/5Fu4/wCwtpH/AKDY 1pVm2H/It3H/
AGFtI/8AQbGtKvjcb/FZ7FD4CvJ/yEYP+uUn80qxVeT/AJCMH/XKT+aVYrzk dAqsVYMpIIOQ
R2p7zySNuaR2bGMliTj0qOiqAlNzKZBIZXLgYDFjkfjSPPJJndI7Z65YnPT/ AAH5Co6KLsCR
55JG3NI7NjGSxJx6UwsSACSQBgZ7UlFAEouZQrKJXAYksNx5z1zSGeRgoMjk KMAFjwOmKjoo
uwHiV1GA7AbdvB7en0oMrs24uxOCMk+vX+Z/OmUUXAkM8jBQZHIUYALHgdMU hlcxiMuxQHIU
ngfhTKKLgPEriMxh2CE5Kg8H8Kc11O5BaaQkdCWPHf8AoPyqKii7AeZXMYjL sUByFJ4H4Uss
8k2PMkeTHTcxOKjoouBIs8iIUWR1Q9VDEA0v2qffv86TfjG7cc49KioouwHi VxGYw7BCclQe
D+FAlcMzB2BYEMc9c9c0yigBdxKhcnAOQKSiikAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFFFFABRRRQBStppLaExPZ3LFZJSGj8sqQ0jMDy4PQjtUv2xv+fK8/KL/ AOOVHB9quYzI
LmGJTJIqr9nLEBXZeT5g/u+lSeTdf8/kP/gIf/jtUAfbG/58rz8ov/jlH2xv +fK8/KL/AOOU
eTdf8/kP/gIf/jtHk3X/AD+Q/wDgIf8A47QAfbG/58rz8ov/AI5R9sb/AJ8r z8ov/jlHk3X/
AD+Q/wDgIf8A47R5N1/z+Q/+Ah/+O0AH2xv+fK8/KL/45U51PdbxJ9ivVaMt zthIIOP+mg9K
g8m6/wCfyH/wEP8A8dq1FpV5LAsv26D5icKLQ54/7a1Ub30E7dSE3xP/AC63 n/fuL/47UQdp
rq3IgnjWNJdzz7BksY8ABWbshqy+n3aDJvI//AP/AO3VARNBdQI88cySpIcC AxspUp/tsDkP
TfNbUSsJJ/yEYP8ArlJ/NK+G4/8AlLZ4d/7b/wDphavuST/kIwf9cpP5pX5z fGvxrffDX/go
Jrni/TIrefUtA8P6vqtrFdqzQvLB4YmlRXCspKlkAIBBxnBHWvuOEtsy/wCw ep/6VA8fMviw
/wD18X/pMj9V6+A/2pf+Uhfwp/7B+h/+nmavvyvgP9qX/lIX8Kf+wfof/p5m r0eDf9/q/wDX
qp/6Scucf7r/ANvR/NH35RRRXwh7hQ06TfeaoN+7Zchcb9239zGcY3tjrnGE 652nO5r9UNOk
33mqDfu2XIXG/dt/cxnGN7Y65xhOudpzua/SQHL6z458O2Gp2tvP4h0y2mgu CLiGS/jRo/3b
jDqZFPUrwQ3OPlH3lPG3i8aL8NPEXibR5bW/aw0q6v7V93mQStHEzrkqRlcr g4I78ivm34p+
NfHWk+MfClr4S8ZaLoFhpviXU59Vs9Q0yWdlV01MLJPtvoPPgZprbbAE3CTy 5t5VNten6tcX
Wo/s2eNL1Zovs1zpmuXG1oSXdXa8bcG3Ywd0ZHB4B67gV7aNOLrRi19pL8Tm nOXI2n0bPANM
/bP+M2t6Ld6xp3gfS7/SbTf9ov7XSb2SCHYoZ98izFV2qQxyeAQaxf8Ah4L8 RP8AoDeGP/AW
4/8Aj9eSeKtKbxlYWOs6Re6WmlafpFtatYXWp21rPbSwwKLhUt5JFZ/MlEsw MQYOZyf9YXVf
R5bvwvp+p6tdSL4Texgkv5fCaxxWMpNkun35iF0iglpPMGnbVvAZS+QAW82v 1mWX5fBXeHi3
rot1bo99evTRN62Ph1isVJ29q159H5+n62Rqf8PBfiJ/0BvDH/gLcf8Ax+tP Rf23/ix4hW5f
T/DHh25ito5JZpRaXAjjCQyzsCxuAAfLgmYLnLCNsAkVz/hdfD/iLVJ0tbbw xNqVpp8N1YI9
vZJF582gXtzeNKGAjdEvEhOJcpAQEXy1+WoNPvvDmn6Nqct9ceHbbxY2lzRX z6c9qkRmfTtc
QLCYP3OGjbTlYQ/KZGQN+8JrGeEy9JqOGXMkn1e+2mmnd9Hp5mka+KbTdZ2u /wAP17eWpqf8
PBfiJ/0BvDH/AIC3H/x+tb4S/tneLr/xX4M8HweHPCuk6FNe2Wkx22m2M0K2 1uZEiCRKJtqB
UOFG3AwOMcVha7qXw/i1MtBoXh19Igj1J9JNzqdpKbq2XT7vyUkitoYpkLSf ZMfa5TcB9oQl
/NYeSfCC7k1D45+CbqVYkln8R2UrLBEkUYLXSEhUQBVHPCqAAOAAK1WXYCtR nJYZRtG/59u1
tez0IeLxVOpFe2bu7fl/SP1mooor8bP0AKKKKACiiigAooooA4Lx/wD8hCz/ AO23/oMNcLff
6v8AKu78eqX1KxUYyTMOTgdIe5rgr6e2KAJe2czMcBILqORj36KxPavsMt/g Q+f5s8bFP3n/
AF0R2Nh/yLdx/wBhbSP/AEGxrSrNsP8AkW7j/sLaR/6DY1pV8Zjf4rPZofAV 5P8AkIwf9cpP
5pViq8n/ACEYP+uUn80qxXnI6ChrTzLaQpBO9s813bQGWMKWVXnRGI3AjOGP UGs+bVJ9M1E2
jG5v0iAlDLs86RWguX2EKgDHNucbQmdyjsS2zeWUN/B5M6s0e9H+SRo2DKwZ SGUggggHII6U
xdKs44UijgZFVnk3CeQyF2jaMuZCxcsEcqCTwMYxgVasIyx4hmeziMaWdxev K0bWlvLcStGF
UFt6rAXVlJAKlOMjJBIFUNP1uSfUHu0E0qXKn7NbyS7VzKumiINyQoBnbJGc b2OCevQNotiY
kiEEkaqzMWjupllcttB3Sh97A7E4LY+RePlFCaJp8UXlxWixKIxGpSR8oAsK gqd2QQLaHDdQ
VyDnmmrBqZ0viOaCSeBrNJLqJXXZDMWSSYG3EcaMUB+Y3UY3EDBz1HNPuNeW bQNY1C3yYbVG
aGVDtaRfs8cyuAy/LkSDGQenI7Vpwafa2v2byoNpt5WnRmkd28xkMZcszFmO 04GScADHQUkm
nW0umy2BiH2SUS+ZGGPzeYzM5znOSWPT2x0paAY+razNaXlvdyRCPS4Lm8Vh HOxml8iC5DAp
tC7d8RIy3O1TgZ4kh1rU52gi/snyZ5phGrXJngh/1Ush+Z4FYsBCcgIR8y/N yQNGXR7Ce8ku
ZbXzZHaVvLeaQwqZFZXxFu2ch3z8vJYk8mnW2lWdrLHKkDPcIxfz555JpCSj pyzsTgCR8LnG
WJxmnoGpgza9fNFrNyqRpa2diZGxNhklV7pG8v8Adtuy0HBfbgAHbyRTzqMu jpPe3is8bXt6
uY7pndo4Fujjy2QIgAhA+UgsQCxHIrWl0KwnheJ7cmN45Y3VZpEEgkZ2bcFY buZZCM5C7jjF
WJrG0uNgkto3RXnlEbZKlpfM8wkE8586Tg8c9OKNA1MiLXdSkMER0WUXE8wh TzPMgjyY5X+9
NGhO3yjuwpwCCCx+WrljqxvNTurZlhtxEX2Ryu63Eqq23zBGUA8snOHDHOB0 OQLFtpVnayxy
pAz3CMX8+eeSaQko6cs7E4AkfC5xlicZp9tY29pNNNHGxnlBDSyzSSEKWDFV DMQgJC8KB91f
QUtA1KI1eb7Hd3pit4rOMyRwmSZ/NlkSQx7dixkAF1YDBZjxhcnFZLatcajq tkjpNaGOZIJo
gZY1Zvtdh2dUbHlzkfMo+82Mjk7x0ezPnExSZlOeLiUKh3BtyIG2o24btygN uJOcnNFvoun2
ro8dpl1k87fJPLIxbfC+SWck828X4Ljuaat1DUyrDxRc39qtwmlTrDOsZtnd JURjJIkcYd3j
VQSZFPyGQYDHnAzPaQ3mo6fr8Es4tbt7p4Elt5XkWEG2gKlCQh4LFug5J+tX I9CsIonRbc5K
hVdppGMSgggRZYiIAqpHl7cbFx90VYs7K30+F4raJo1eQzOXmklZ2KquSzsx 6Io69qWgGLd+
LJQdTuLfSbiSxtvtJSTZKB+5DltzmPywpMbKCHY5K/LycXV1O6h1ePTLq2gW 5LgO1vO0kaqY
53HLIpLf6O4xjHIOT0qSXQdOuFnEtt5omV1KvLIUUOCHKJu2qxDNllAPzsc5 Jqxe2Ftf3E88
0R86YoWkjkeNxt8zAVlYFeJZASCCQxBOKNA1MdfEd1NJJ5NjC0aSJDl7kqzO 9zNbxgDYRgtD
kkngNwGIwbthJPcq96imR5pI7UW5lxHF5c8sc0gY9Rzn7oJEY6E4Fi30mxtE RIbUKqvFJ80s
jktHM8yklmJP7yR2PPOfSpBYW32eKAwK0Mc32gIScF/OM2Tz/fOcdO3SjQNS aiiipGFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAc5rF3d29jpcdm1wrz3 88bi0ERkZc3D
YHm/KOVB57A0Ta/daTFdRvbTXZs7D7dNNcyxo/PmkRkIuN2UAyBjGTnIG6zJ FpmoWcUN3dxR
yQXM0ihbzyJEbzJBnKsCPlY/gacLLRRb3ELXcEqXEH2eUy3+9njy5wWZyf8A lo/Oc8+ww7MC
G88R3Nms7NYKotbcXd0jz4ZIiXwFwpDPiNsjIAOAGI5q9o+py6oLl2tvs8MU 8kCMZAxkKSMh
bAHA+Udec5GMAFor630bUZRJPd2zNt2MFvQiyL/dcBgHXk/K2R8x45ObFrPp tnG0cN5Zohd5
CPtSH5mYsx5buWJoswLtFV/7Ssv+f+z/APAlP8aP7Ssv+f8As/8AwJT/ABos wLFaKOUsYNu0
viQqGOATlepwcVjf2lZf8/8AZ/8AgSn+NWm1Wxa1twuoWRZC4ZftUYPOMdW9 q0huSzK/4Si5
u2htFsSNSVsTRsSEQDGWz6EdP68ZvXBze2h/2bj/ANoUrahZFywu7IMQAW+1 xZIGcD73ufzq
E3MM97aLHcQTuEnZlgmWTaCYQM7ScdDVy2YkOk/5CMH/AFyk/mlfCOpaTY6/ /wAFV9J0zU7K
31HTb2G6trqzu4llhnifw+6vG6MCGVlJBUgggkGvu6T/AJCMH/XKT+aV+ePx U8df8Kv/AOCj
OoeMvsP9p/8ACO6Lqer/AGLzfK+0fZ/DUsvl79rbd2zG7acZzg9K+14S2zL/ ALB6n/pUDyMy
+LD/APXxf+kyP1Mr4D/al/5SF/Cn/sH6H/6eZq+/K+A/2pf+Uhfwp/7B+h/+ nmavR4N/3+r/
ANeqn/pJy5x/uv8A29H80fflFFFfCHuFDTpN95qg37tlyFxv3bf3MZxje2Ou cYTrnac7mv1Q
06TfeaoN+7Zchcb9239zGcY3tjrnGE652nO5r9JAcvrPjnw7Yana28/iHTLa aC4IuIZL+NGj
/duMOpkU9SvBDc4+UfeW7rem6b8QfB2pab9r87StYsprNrmxlViY5EZGZGwV zgnBwRnsa+YP
in418daT4x8KWvhLxlougWGm+JdTn1Wz1DTJZ2VXTUwsk+2+g8+BmmttsATc JPLm3lU219B/
Cm4utR8JW16s0X2a5vLy42tCS7q91cNuDbsYO6Mjg8A9dwK7/wAN80bppmKf Po9mj5v0D9lL
4CeK/FWpeGNE+Jc+s+JNN8z7do+n69YT3lr5biOTzYUiLptdgjbgMMQDya1f E37Efwn8H6dD
f6v4j8T2lpNe2mnpJ50L5nubiO2gTC2xPzTTRrnoN2SQASLHhODUPEOiQ+CL HQPEGn+LdK+J
upeIf7U1DQ7yys7KwHiW5upZor6WJY5PtNjLJbqtu8jSLelWAhM7p4/B4X+J Wo+A7j/hNNV8
ca/cGbw/c+L9K0/w5rsLW19HrumTXElpcPeSmRoo01Aq2iwxwbVL/IFtFPrf 25mX/P5nH/Zu
E/59o90tP2B/AmnytLa+IfFltK0bxF4b2BGKOhR1yIOjKzKR0IYg8Gof+HfX w7/6DPif/wAC
rf8A+MVR8D+JvEPgXx3B4hu4fiBc/CFP7XsNGhvNN1jU9R/exaK8LXNo8cl+ cXEGuBJrlPkV
gqsscsAfzTRNW8XaL4N+Htx4+vfiRYeO31PwHbaXL5usx2LWMp0aK/j1AwkW hne6fVUdb39+
25QcqYBS/tvMd/bMP7Own/PtHrP/AA76+Hf/AEGfE/8A4FW//wAYrT8LfsNe BPCXibSNcs9W
8RSXemXkN7Ck9zAY2eNw6hgIQSMqM4IOO4r6JopSzrMZJxlWdmNZdhIu6poK KKK8U9EKKKKA
CiiigAooooA4TxzL5Or6a5JAV5SSM56Q+hH8xXnl9c3NwsQc3hRXyfPaQr0I /iu5R3/u/iK7
/wCIX/IQsfrN/wCgw1xN9/qPxFfYZa7UIfP82eLi1eT/AK6I63Tznw1Of+ot pH/oNjWlWZp3
/Isz/wDYW0j/ANBsa06+Mxv8Vns4f4EVLuUW13BNJkRbWjZ+yklcZ9Bx1p/9 pWn/AD9Qf9/B
/jSzXkcH3mA+tVzrNv8A89B+deedJP8A2laf8/UH/fwf40f2laf8/UH/AH8H +NUn8TadHexW
bXcK3csbyxwGQCR0QqHYL1IUugJ6Auueoqb+2bf/AJ6D86GmtwJ/7StP+fqD /v4P8aP7StP+
fqD/AL+D/GqV74m07TLK4vLy7htLS3jaWaeeQJHGijLMzHgAAEkngAVBaeNN Gv8A7F9m1O0u
Pttubu18qdW8+EbMypg/Mg8yP5hkfOvqKpQm1zJaCuk7XNT+0rT/AJ+oP+/g /wAaP7StP+fq
D/v4P8ag/tm3/wCeg/Oj+2bf/noPzqNRk/8AaVp/z9Qf9/B/jR/aVp/z9Qf9 /B/jUH9s2/8A
z0H50f2zb/8APQfnRqBP/aVp/wA/UH/fwf40f2laf8/UH/fwf41B/bNv/wA9 B+dH9s2//PQf
nRqBP/aVp/z9Qf8Afwf40f2laf8AP1B/38H+NQf2zb/89B+dH9s2/wDz0H50 agT/ANpWn/P1
B/38H+NH9pWn/P1B/wB/B/jUH9s2/wDz0H50f2zb/wDPQfnRqBP/AGlaf8/U H/fwf40f2laf
8/UH/fwf41B/bNv/AM9B+dH9s2//AD0H50agT/2laf8AP1B/38H+NH9pWn/P 1B/38H+NQf2z
b/8APQfnR/bNv/z0H50agT/2laf8/UH/AH8H+NH9pWn/AD9Qf9/B/jUH9s2/ /PQfnR/bNv8A
89B+dGoE/wDaVp/z9Qf9/B/jR/aVp/z9Qf8Afwf41B/bNv8A89B+dH9s2/8A z0H50agT/wBp
Wn/P1B/38H+NH9pWn/P1B/38H+NQf2zb/wDPQfnR/bNv/wA9B+dGoE/9pWn/ AD9Qf9/B/jR/
aVp/z9Qf9/B/jUH9s2//AD0H50f2zb/89B+dGoE/9pWn/P1B/wB/B/jR/aVp /wA/UH/fwf41
B/bNv/z0H50f2zb/APPQfnRqBP8A2laf8/UH/fwf40f2laf8/UH/AH8H+NQf 2zb/APPQfnR/
bNv/AM9B+dGoE/8AaVp/z9Qf9/B/jR/aVp/z9Qf9/B/jUH9s2/8Az0H50f2z b/8APQfnRqBP
/aVp/wA/UH/fwf40f2laf8/UH/fwf41B/bNv/wA9B+dH9s2//PQfnRqBP/aV p/z9Qf8Afwf4
0f2laf8AP1B/38H+NQf2zb/89B+dH9s2/wDz0H50agT/ANpWn/P1B/38H+NH 9pWn/P1B/wB/
B/jUH9s2/wDz0H50f2zb/wDPQfnRqBP/AGlaf8/UH/fwf40f2laf8/UH/fwf 41B/bNv/AM9B
+dH9s2//AD0H50agT/2laf8AP1B/38H+NH9pWn/P1B/38H+NQf2zb/8APQfn R/bNv/z0H50a
gT/2laf8/UH/AH8H+NH9pWn/AD9Qf9/B/jUH9s2//PQfnR/bNv8A89B+dGoE /wDaVp/z9Qf9
/B/jR/aVp/z9Qf8Afwf41B/bNv8A89B+dH9s2/8Az0H50agT/wBpWn/P1B/3 8H+NH9pWn/P1
B/38H+NQf2zb/wDPQfnTl1e3Y4Dj86NQJf7StP8An6g/7+D/ABo/tK0/5+oP +/g/xqaOVZBl
TmnUagU4p0u9QDQnzI4o2VpF5XJKkAHvwP5V8FeKPC2l+Of+CoVt4b1u1+26 LrFle6ffW3mN
H50Evh2SORNyEMuVYjKkEZ4INfoDX5qftA+KdU8Dft3+KfEmiXX2LWtH8M61 qFjc+Wsnkzxe
Fp5I32uCrYZQcMCDjkEV9/wltmP/AGDVP/SoHi5l8WH/AOvi/wDSZH6w18B/ tS/8pC/hT/2D
9D/9PM1fflfAf7Uv/KQv4U/9g/Q//TzNXocG/wC/1f8Ar1U/9JOXOP8Adf8A t6P5o+/KKKK+
EPcKGnSb7zVBv3bLkLjfu2/uYzjG9sdc4wnXO053Nfqhp0m+81Qb92y5C437 tv7mM4xvbHXO
MJ1ztOdzX6SA5fWfHPh2w1O1t5/EOmW00FwRcQyX8aNH+7cYdTIp6leCG5x8 o+8vQ2N/bana
RXVncRXdtKN0c0Dh0ceoYcGvkz4p+NfHWk+MfClr4S8ZaLoFhpviXU59Vs9Q 0yWdlV01MLJP
tvoPPgZprbbAE3CTy5t5VNtfQfwpuLrUfCVterNF9muby8uNrQku6vdXDbg2 7GDujI4PAPXc
CusopXsZxk3a47TPjf8ADrWvGT+ENP8AH3he/wDFiTTWzaDbazbSXyyxBjLG YFcuGQI5ZcZX
a2cYNWta+KvhDw1rt9o+s+I9P0a/sbKLULhdRmFsiwSLduriR8I3yafeuwBJ VLd2YBRmvmrw
Rf8Ai/w34c+Kuh+HdU+ICePry98ZSeHPD+oeETFoVteS6jfXNlcRahJp6xHz B5bqZrt4mM5X
HKqvmvxG8Aa34z1/xvp/wr0n4kXWkeIfD8WjTP4rGuRG7mOieLVEDy6sQ3kC e403qwhWWWI8
O2azND9Cq5+9+HvhXUfGVh4vu/DOj3XiywhNtZ69NYRPfW0RDgxxzld6KRLI NoIH7x/7xz8v
+PP7V/s68/4RD/haHk/8IyP+Fdeb/wAJB5v/AAkX2i/87+0/O+fyt/8AZm3+ 1v8ARvL3bP3X
nV7X+z9oGuWGk+KdV8Sal4gvNT1DxNrawW2tzuUtLCPV70WcdvEQAsRhZXVy GZkeNd5ijgSM
A9VooooAKKKKACiiigAooooAKKKKAOA+IX/IQsfrN/6DDXE33+o/EV2/xBBO oWOBnmb/ANBh
riL3/U475FfX5d/Ah8/zZ42K+KX9dEdZp3/Isz/9hbSP/QbGtGVtqE1nad/y LM//AGFtI/8A
QbGr8/8Aqm+lfG43+Kz2MP8AAj49+P17rWv/AB5i0S18S69ounp4eS68rSdQ e3UyfaXUsyjI
OVOOmeF5wK4zxH8MtaTSbWW+8Z+L7rQJ5mh1h7jVWaKK0aGQF3UgjZ5nlByQ VVGdmwoLL3nx
DQSftS4PI/4RVf8A0sNfQ/gnSoJNMjJQdK8LC0qTqSqVI3959Wvu7NdPM/Sc 0zfHYCjhKGEq
ckfZQfwxerve91rfqfB8fgPRvCd3ay+DPFeq3OmfYr6aS40XWY0jglE1hGxk liQrFEFmjeZi
CQkStghADWsr7XS1zez+P9Xv7CK+lsY7PRfF/wBour1hBaSILMuiLcuGndWQ BW5QLuYYf9IP
7Gt/+eY/Kj+xrf8A55j8q9xSy9r97h3J93N33v2/E+afEGeL4MVZdlCH+R+e Go6Hq9xe3eiz
+MvEmsXNpq9qjT2Ovi7tbdG1OCGJJ1xvgu1D7gpG3dEWVjtZVz/EnhPxF4f8 ba4NP8ReIGur
SaQSXk+qvE/kgaN50k0yqSqCO5Jd9pCrbxEgiMg/o/8A2Nb/APPMflR/Y1v/ AM8x+VKlLA05
J/V7rW65nre3+T08/IJcQZ3JW+ta/wCCHn5eZ8HaD4B8Z+JfB2v6ppvjjxDq N9H5w0pNM8Ry
3FpOywqUUzvHGsmZdylkwo+6TuRscHeeE7fQvFep3PhLXb6TVpIPtd3qEOv+ VdxR/a7VLoX6
LbiS2x57uzOWK+SzOvylR+lv9jW//PMflR/Y1v8A88x+VTReCpTk3QvF9OaS 000dt9vxd79K
nxDnUopLE69+SH4aaHwF4M8MeKPE3iS1tJPHviGewu4L24gn0jxDNdRMsBsl G2dokWX57iYM
UUgFQudyOK57wtb+Ndek0i3n8b6za3OojTZ4YZvElwl3PBNBbyzSQWqwu0qA vOok3hV8tt/E
Tk/o9/Y1v/zzH5Uf2Nb/APPMflQv7PXN/s260956avXz6LXt5g+Is80/2r/y SH+R+e0Wl+I9
P8CeEtX1Tx74giutcslvWvNQ8SvpmnRblRxF5rJKfNIkG1f4xFK2V27ayNA8 PanrHhxLi/8A
F3iCLWNRvdCvhZHVCrXMVx/Zym7CN8z7JZWRJeQrQIuSUNfpB/Y1v/zzH5Uf 2Nb/APPMflTi
8BG7WH1bvfme3Ne1rfL8RPiHPHb/AGrS38kO1r7fM/Ou3t/Ed5aeHBbePPFN xeyw2keu28Wt
OzabdzXllAYJFHML4nusJJ82YT12MD3mg/DDxFrGqeJ7RvHXjRBpeopZxMus PkqbS3mJbjk5
mYcY4x7k/bH9jW//ADzH5Uf2Nb/88x+Vc9angpxahQ5d/tN7tPy2s0vJ+Wuk OI87i7yxN/8A
t2Pb0+Z8ff8ACkPEX/RQPGv/AINXo/4Uh4i/6KB41/8ABq9fYP8AY1v/AM8x +VH9jW//ADzH
5V5/1Sh/L+LOn/WfN/8An9/5LH/5E+Pv+FIeIv8AooHjX/wavR/wpDxF/wBF A8a/+DV6+wf7
Gt/+eY/Kj+xrf/nmPyo+qUP5fxYf6z5v/wA/v/JY/wDyJ8ff8KQ8Rf8ARQPG v/g1ej/hSHiL
/ooHjX/wavX2D/Y1v/zzH5Uf2Nb/APPMflR9Uofy/iw/1nzf/n9/5LH/AORP j7/hSHiL/ooH
jX/wavR/wpDxF/0UDxr/AODV6+wf7Gt/+eY/Kj+xrf8A55j8qPqlD+X8WH+s +b/8/v8AyWP/
AMifH3/CkPEX/RQPGv8A4NXo/wCFIeIv+igeNf8AwavX2D/Y1v8A88x+VH9j W/8AzzH5UfVK
H8v4sP8AWfN/+f3/AJLH/wCRPj7/AIUh4i/6KB41/wDBq9H/AApDxF/0UDxr /wCDV6+wf7Gt
/wDnmPyo/sa3/wCeY/Kj6pQ/l/Fh/rPm/wDz+/8AJY//ACJ8ff8ACkPEX/RQ PGv/AINXo/4U
h4i/6KB41/8ABq9fYP8AY1v/AM8x+VH9jW//ADzH5UfVKH8v4sP9Z83/AOf3 /ksf/kT4+/4U
h4i/6KB41/8ABq9H/CkPEX/RQPGv/g1evsH+xrf/AJ5j8qP7Gt/+eY/Kj6pQ /l/Fh/rPm/8A
z+/8lj/8ifH3/CkPEX/RQPGv/g1ej/hSHiL/AKKB41/8Gr19g/2Nb/8APMfl R/Y1v/zzH5Uf
VKH8v4sP9Z83/wCf3/ksf/kT4+/4Uh4i/wCigeNf/Bq9H/CkPEX/AEUDxr/4 NXr7B/sa3/55
j8qP7Gt/+eY/Kj6pQ/l/Fh/rPm//AD+/8lj/APInx9/wpDxF/wBFA8a/+DV6 P+FIeIv+igeN
f/Bq9fYP9jW//PMflR/Y1v8A88x+VH1Sh/L+LD/WfN/+f3/ksf8A5E+Pv+FI eIv+igeNf/Bq
9H/CkPEX/RQPGv8A4NXr7B/sa3/55j8qP7Gt/wDnmPyo+qUP5fxYf6z5v/z+ /wDJY/8AyJ8f
f8KQ8Rf9FA8a/wDg1ej/AIUh4i/6KB41/wDBq9fYP9jW/wDzzH5Uf2Nb/wDP MflR9Uofy/iw
/wBZ83/5/f8Aksf/AJE+Pv8AhSHiL/ooHjX/AMGr0f8ACkPEX/RQPGv/AINX r7B/sa3/AOeY
/Kj+xrf/AJ5j8qPqlD+X8WH+s+b/APP7/wAlj/8AInx9/wAKQ8Rf9FA8a/8A g1ej/hSHiL/o
oHjX/wAGr19g/wBjW/8AzzH5Uf2Nb/8APMflR9Uofy/iw/1nzf8A5/f+Sx/+ RPj7/hSHiL/o
oHjX/wAGr0f8KQ8Rf9FA8a/+DV6+wf7Gt/8AnmPyo/sa3/55j8qPqlD+X8WH +s+b/wDP7/yW
P/yJ8ff8KQ8Rf9FA8a/+DV6P+FIeIv8AooHjX/wavX2D/Y1v/wA8x+VH9jW/ /PMflR9Uofy/
iw/1nzf/AJ/f+Sx/+RPj4/BHxH/0P/jX/wAGr1zf2bxJ8NPit4Ntz4u8Q6nB fm882DVL95om
2Q8fJkA8tnnuAa+430a32n92Pyr5e/aDs44PjX8MVRQAw1TP/fhK56+HpU4x lBWfNHq/5ke5
k+d4/MK9XD4qpzQdHENrljuqFRrZdGk15o9/8E6ne6lYI7Tw5I7wn/4quq2X f/PeD/vyf/i6
434a/wDIOT6V3Y6V6bR+dFaGaZbkwThWyu9JIxgEDAIIJODkj86/Pzx94Ksf iV/wUufwhqct
xBpuv6ZqGlXUtoyrMkU/hyWJ2QsrAMFckEgjOMg9K/QST/kIwf8AXKT+aV8I alqA0v8A4Kua
FdMrOI/O4QAnnQmHQkevrX3/AAgnL+0Yr/oHn/6VA8TM3Z4dv/n4v/SZH6W1 8B/tS/8AKQv4
U/8AYP0P/wBPM1fSX/C+PFH/AETPUf8AwKb/AOM18jfGPxbf+Mv28vhfe6jo U3h+eO30WEW0
8hdmUatId+Sq8EsR0/hr1+EaMqeOqycov91U2lF9OybZx5vNSw1rP4o9Guq8 j9I6KKK/PD3y
hp0m+81Qb92y5C437tv7mM4xvbHXOMJ1ztOdzX6oadJvvNUG/dsuQuN+7b+5 jOMb2x1zjCdc
7Tnc1+kgOX1nxz4dsNTtbefxDpltNBcEXEMl/GjR/u3GHUyKepXghucfKPvL 0Njf22p2kV1Z
3EV3bSjdHNA4dHHqGHBr5M+KfjXx1pPjHwpa+EvGWi6BYab4l1OfVbPUNMln ZVdNTCyT7b6D
z4Gaa22wBNwk8ubeVTbX0H8Kbi61HwlbXqzRfZrm8vLja0JLur3Vw24Nuxg7 oyODwD13ArrK
KV7GcZN2ua/hv4heFfGOq61pmgeJtH1zUtEm+zapZ6bfxXE1hLudfLnRGJib dHINrAHKMOxr
oK+SpdJ1Px18X/EmjRWXjjSdCvvimlzqV3YRatoa3Onx+ETbrIt5EIS8H2+x VdySFSywnlZY
y9TSf+E8j8e+DLXUP+Ew8RR2WtXenWmgS/23paWlhDrt7HFqc+qw/wCjX2LC G1Jtb8lp0iWR
ZS9wVuczQ+tdJ1ax1/SrLU9MvbfUdNvYUubW8tJVlhnidQySI6khlZSCGBII IIrn9P8Ail4Y
1Xx3e+DbXU/N8SWfn+fZfZ5Rs8mKxll+crsO1NTsTw3PnYGSjhfkvRfDWr+E P2bfhv4Jtrfx
x4cfTYY7fxHqstt4q1Say1a2s7aFrO3t7C6guHtJN87JNbytYKbXaqs0sbLx Oi6D8Z9VluPF
Eml+INJ8V6poqTavq8mi3COgmsfAy6kyww+TIZfKttUAitmjnL20qQFZYxtA P0VrlE+KvhD/
AIVxYeP7jxHp+meDL6yttQh1vVJhZW/kXAQwu7TbNm/zEAD4OWAxnivmDw3Z eI7DStDj8baz
8SNc+GZm1RorjRNI8RabqS3W3TvsaGOK5uNZMGRrJ3XbhCxA2iMWRPr/AMGv ESfCL9lj4RJ4
n0rxBb3dv4Z0jT7iw0/w/faheW862Kbklt7aGSWPaUZWLKArYUkEgEA7bSfj f8Otf8TWXhzT
PH3hfUfEN7Clza6TaazbS3c8TwC4SRIlcuytCRKGAIKEMOOaNM+N/wAOta8Z P4Q0/wAfeF7/
AMWJNNbNoNtrNtJfLLEGMsZgVy4ZAjllxldrZxg18lfB34Q/EvwX4CGm+ItN +z+EtG1rwpe6
5olppUk+su+m6Fobm4sbhJmiuYo7yxjjkhjhd3SG6ELvN5cZ7X4Zajq3hmx+ JOit4o+JGga7
d6n4vl06zl+H9xe6RpbSalfXNvfW8qacDdMY9sqRNdSLK0vlqpZkVQD61orx /wDZfXU18Aag
uo6XrFii6nIlre63qWrXM2qRLFEpuxBqpN3Yq0gkX7LIWCGMsryrIsr+wUAF FFFABRRRQBwn
j3/j+tP+2v8AKGuDu/uH6iu88e/8f1p/21/lDXB3f3D9RX1+W/wY/P8ANnkY r4n/AF2OvsP+
RbuP+wtpH/oNjV6f/VN9Ko2H/It3H/YW0j/0Gxq9P/qm+lfG43+Kz16HwHyR 8QP+Tp/+5VX/
ANLDXa+JtM8P33ijw9c+JdFtNe0vTPDOt6i9rd2sdwB5cunksqyfLu27gDx1 PPNcV8QP+Tp/
+5VX/wBLDXsGnaX4jh8SeHfEWgWGlap9i02+sJrbU9Rks/8AXyWjq6skE2cf ZmBBA+8Oa83L
m4zm07O8tfkfT8TxcqeFS/580+l+r6dTH8J6N8LfHnxA0vQfCHw28La/pSQf bNZ1r+xLcQWc
bxMYYlygzKz7Mr1UBhgkP5deLxj4m8Mfs6/CfTfA8WkyeNvEVhpul6O3iBZT pqSrp7XcpufK
IkC/Z7S4ClAT5hjBG0sR6L4UuPFvgbTZLDQfhx4N0qzknkuXhtvE9wqtI5yz f8g76ADoFCqM
KoA5i1/Zu8K+ItC+HcXjvRdL8VXnhLw+2jJZX9pFeWBeRbQSzBJoyd4NmoRv lIWSQEfNx3Xr
KjbEVFKTd9HdLR6LXb13PiMFSqQfNU+J3vZWS2slfXp16322OT+K37T7n4Ga 14h8B6Hrt9rE
3gT/AIS2K5hjsl/sOC5tZnsri6W4nVX+aCYlIROR5DZXDJv3tX+N2oax8TvA Gj6BpGrQeG73
xTf6LfeIJls/sV81rp+pedbRqZTcqyXVpjeYUVvs7YdkZfMq337IHhZfCmr+ G/D+va74N0fW
LO90zUrbQ1sVS6sbi6u7kWu2a1kWGOJtQu1j8kRsEkAZnKIV6e0+A1hYeNtJ 1yDxLrqaXpWs
XmvWfhnNodPivrqK6S4l3m3+0tva9upNpnKhpMKAqqg5/dPX1NTU/jFouk63 qGjT2t+dYtdY
0/SItPWNPtF79rVHS6t4y+6S3RTcs8gHyiwvSARA1cJf/tkeBNK8ReJNDu4r 9tU0O8jtZLTT
JbPVLicNqEFg0iwWdxNKmya6gzFMkczByEidkdF9O1D4c6LqXxC0rxlPBnWN Os5bOL5E2PvI
2SvldxkiVrlI2DDYl7dKBiZq87tf2VNDgv8AQWl8U+JbvSvDsNva6Fo0z2Yt tMtoL+wvYoI2
W2WaRQ2mWse6aSRygb5t7F6S5eoah4g/aY07wRoviHVvEGnT2qadrttoradd Xml6bLaSy6Xb
X3lvPdaglvOy+cwJjkBzlVR1jMz5fw//AGlF1zxR4ouZrHVtT8B3Ou6Va6L4 phhtksraK/0z
S5LWCSMyLdlpLi9HzGBgv2ldzKqN5fY6v8BrC68V6r4p0jxLrvhjxNqN5Jcy apphtJHSOS1s
beW3WO4t5Y/LcaZZuSUMgeM7XVWZTheDf2VND8EpZWNp4p8S3Xhu3m0q6fw9 dPZm1uLnTraz
gtJ3kW2W4DL/AGfaSFUlVGeM5XYzIX7oanHfCf8AbR8LXmk/DXw74m1T7V4v 1fR9DXU777RY
w41K+tLeWNPsnnJcv5jXEJ3wW7wr53LqI5fL9O+Nf7Qvhb4B/wBjS+Kn+z2O o+czXf2+xh+z
xxeWZH8me4jmnwJAdltHNIcYCbmQNV8Efs6aX8O00e00HxP4lsdEsobBbrSI 7mBYtTms7aC2
gnuJRCJw3lWlqrxxSxxOIcNGyySiS18VvgNYfFT+2s+Jdd8Mf29o/wDYOs/2 IbQ/2jYjztkT
/abebZs+1XOGi8tj5x3FtqbV7tw1OEg/aR8Xt/Y+z4f3+p/avHer+GB9hezX +0rW1/tfY9p5
t6uySP8As6HzTceWrZk8tWyuKvxl/ahlsvhf4s1Lwpbatot7Yza/o1tqmoaV G8UuoWGn6tK3
kFpQCqSaasnm+XLGwdYtu/zvs/ot38BrB/tH2DxLruj7NYl17SfshtH/ALFv pvtP2uW3823f
f9o+23W9bjzlXzT5Qi2ptq+LP2a/DPjHwK3hS9vtWi05tS1vVDLBNEJfN1SL UI7kZMZG1Rql
xsGMgpHuLYYM7xFqWtI+PNhdeK9K8Lav4a13wx4m1G8jto9L1MWkjpHJa31x FcNJb3EsfluN
MvEADmQPGNyKrKx5jT/2n7efx74wguNDv4vA3hvR5b/UNeEcX/Eue2vtYtbt 5088ySRsdKzE
IIpH5YuF3ALuv+z1a3Vw2rXvjLxLf+Mkmt5bTxZMLBb2zWGO6jjjjiS1W1ZQ l/fLmSB2P2pj
uykRjq6P+zB4e0vT76xn1zXdUtdYs7+w8RR3clsv9vwXVxe3DJcGOBDFsl1G 8ZDa+Qf3gDFw
qgL3R6mFoX7a/gLxFpkj2Mc91rZ1Kz0q20O11TSrmW7uLpZmt0S5hvXs1Zxa 3OEkuEcmIDbu
lhEvY/Ev4qa74Lg+HE+n+Eb/AFS68Sax9gvNBR7X+0Ik/sy8uiiO9yluJEe2 QMTKyFRIFLEq
aNQ+Cl9rHhnU9I1D4k+LNRk1PEN5e3kOlTedaBJFNobV7E2nlt5rl2EHmv8A KrSMiKg1NU+D
uiz+DfC3h7R7q/8AC8fhTyf7AvtMkSS407y7Z7Vdv2lJUkzbyyxHzUfiQtw4 V1NA1KukfG7S
9Y8XW+jppGrQade6ld6Lp/iCZYPsV9qFqJ/tNtGqym4Vk+yXY3ywpG32dtrt uj8yr4o+PNh4
a8TTaWnhrXdXsbTWNP0HUdbsRaC00++vXtlgikWW4SZ+L21ctFFIoWYclldV taR8EdL0fxdb
6wmr6tPp1lqV3rWn+H5mg+xWOoXQn+03MbLELhmf7XdnZLM8a/aG2ou2Py+O +IvwO8SeJ/ib
aXWh6r/YvhC+1jS/EOvRfbon+2X1jNbuh+yvYvJ80djZxbo72FV27zE5VxMa XDUy9F/bo+Hv
ieK9/sKC/wBeul+ytp9lpl3p09xqcdxe29lG6ot3m2/e3ltlL37PIBIfkzHI E1PF37YXg/wL
aQR67p9/pHiFryayn8Panf6ZZXFs8UVvM5a4nvEtH/dXtm4WO4dyLgYXMcwj 3dN/Z00uw0ew
0Z/E/iW80DSZtObRtImuYFttLhsry3uoIIxHCpmXNpbx+ZcmaUIrBZFMkjPa 1f4DWF14r1Xx
TpHiXXfDHibUbyS5k1TTDaSOkclrY28tusdxbyx+W40yzckoZA8Z2uqsyl+6 GpV8OftKeGfG
Fh4p1LQ7HVr7RPD2mpqlxrM0MVlZSxSWFtfQCOa5kjXdJBcg4cqIvLYzGJWi aTmPB37V1r8S
/HXhLTvCGiT69pWow6pFqy2d1YXEul3FtLpmyRp47s28sIi1He4t3nfLooUO kqDu/wDhRegL
oPiPSkvNWCa1qVlq/wBqmvDcXNpeWcFnFazRyShzIyHT7aX9/wCbvcN5m9WK 1l+HP2erXw54
j/4SRfGXiW+8US6lJfXWtXQsPNu4ZIbKGazeNLVYVhddNs8skaygxHbKu5sr 3Q1OY8KftufD
jxq+oR6RPPfTxwxT6db2t1ZXMuqLLcw2sISOK4drVnnurVAl6LZgZxuCiOYx 7vw9+MV3Ppvx
g8Q+NbW/8L6P4U1hs2Opx28lxp1jHo9hdSbvsjyrJlpZpRtd2xIF4ICLasP2 dNLsvDg0BvE/
iW50SyhtoNBsJLmBYtBW2mimtTbqkKidoZLa2KPefaGxDtJZZZhLqeH/AII6 Xp/hXxvoWu6v
q3jODxnNLLrVxrLQRS3CyWcNk0Y+yRQKi+RbouVUNnJ3ZNHuhqcxqHxo1vT/ AB1psur+HdW8
JaJB4W8Q6veaPrNxpiy3DWculGKYTx3LwxqFubhf3k0a5JL4VVaqug/theD/ ABdaaPH4b0+/
8SeIdUvLuyg8PaZf6ZJcF7aKGacrcG8FpNsiubdysNxI+JT8uYphFu6l+z1a +I3s7nxH4y8S
+JNVsIZ4rHUrwWEMtoz3NhdxyKsFrHGzQ3GmW8iB0ZSS6yLIhCjM1P8AZa07 xFoOuaJ4g8ae
JfEWleItS/tHxBa6jBpZXVyILWBIpdlkpiVI7KLa1v5UisWcSbwjIe6LU7Hw L8XbD4i+JvEO
m6Jpd/c6Xol5caZc6/51obT7dA6pNa+WJzcpIrE/6yFFZV3KzK8bP8/+M/2h PGmg/Dr4j+Ij
Pq2l3bal4k0jQpp7HT59NRtNtdaeJ7TbL9oRv+JZE8zXayq0gKxRrHIWj+gN C+EVhpXxN1Dx
7e6pf694hns5NMtZ76G0j/s+xeYTNaxtBBE8ke9UI89pWXadrAySl8HxZ+zX 4Z8Y+BW8KXt9
q0WnNqWt6oZYJohL5uqRahHcjJjI2qNUuNgxkFI9xbDBhNIephTfto/DKz8b a54dvNU+y/2R
/aCz332i1mzJYxSy3ifZIpnvU8tbe5O+S3SNvJ+R28yHzOxt/jRaj4P658R9 S8O6tpGiaXps
+rrBJcWF1Le2cdv5/nW72tzNC6uuQmZFyRk4UhiWPwaXR9T1GfS/GHiXStOu Jr29tdHtZbYW
tje3TSvPdJmAyTMZJ55RFcvNAryAiL93EIzw18CPDOgeBfFnha5WfW7TxdNd 3HiG5uhFby6n
LcxCGZ3FqkMcbNGqqTEiEkFzmRndj3Q1Mu2+K8vw78I+JY/HEk+q+JPCHhaL xZ4gm0uKP7M6
zG9doLPOwssZsp0QSgNsEO93cu1VdS/ai8LaZp/jLV5bG/PhjwteSaVeeIft Nilo+pJcR2xs
sPciWGTzpVXfcRxQhf3hlETLI1bXP2etQ+IfhGaz8U+MtW0zX9U0L/hGfEmp eHBZhdfs4zOs
byJcWsgt2YXNxIUgCbGuXTfKI43GnrX7OOh+J/FWreJdb1nVtV1+5hS307UJ I7OGXRoo7yO9
hS3aK3TzVjuYLeRBdeeAYsHIkmEh7oamZ4W/au8OePtMtH8I6Jq3i3W5prqK TQ9GutNmlgW3
W3aaQ3P2sWbqovbLiK4ds3AG3dHMI8Gw+MXi+D4Qfs4+IUtb/wAUax4r+xf2 zY6ZHZx3Go+Z
oN5dPt894oY8TRRynDpxGVGQdjd3cfA55vsF+nj7xZD4rtPtMf8AwlHmWUt3 JBP5Hm2/kyWr
WkcZ+yWpxFAh3Q7s7pZjIXfwGsP+EC+HvhjSvEuu+H/+EF+z/wBkatYm0ku/ 3VjLYjzBPbyR
Nuhnkz+7HzEEbcUaBqVR+0p4ZGj6tey2OrQT6fpsl6NPlhiFze3MV5NZT6fa r5m24uoruJLd
ljZkL3VqEdxOhOp4x+JGr+G/jB4I8KWPh+fXNO13TdSuruWzMKy2Rt7jT40n YyzRjyVF5JvV
BJITs2KcMDlr8CLK317wIirBeaJ4fm1HVru6vQrX99qVxOk4aTCCPyXuHmvH jQIFubexeNVW
EKOx8S+ArfxD4m8P+IYtSv8AR9Y0fzYUubHym+0WkrwvPaSLLHIvlyNbQEsg WUeWNkiBm3LQ
NTxP4b/tZ2ulfA/wpr/xK0/VtD1W58LWWri/1A2CRa4zfZIZZoGhnMcCtcXt qP8ASfs6qLlW
O1ElMfovgX9ovwZ47+GXiHx3b332TQ/Dv2j+2G82G9+x+TCtxJ+8s5J4psQu j/uZJPvbTh1Z
Fqzfs1+GZvDngvR/t2rInhDQk0LSbpZovNiEc1hPBdNmPa80c2l2si5XyyQ4 eN1baOnt/hjZ
XPgXXPC3iPVdW8Y2muwz2+qXOs3CrLcxSxeS6AW6xRwL5YC4gSMZy5zI7uzf KGp47rP7Vx8A
+OvFL+ONE1bwlpUOm6JFpWh6zdaTDLPeXEurNLILkXZt0VorIcT3Cc25Crvk USGi/tZ2uq+K
tc1+y0/Vtc+Gtt4WsNXur/TzYPFobLeatDfzTt54edVFkB/ov2hWFszRbg6m TsR+zdHPrd14
gv8A4geLNT8Vn7H9i1+4TTEuNO+zreovkxx2SwNuj1K8RvOik4lyNrKrKax+ zTYa5d3sl341
8WS2ur6PFoev2ck9pKmuWqy3UrrO72zSRbzfXKkWrwKiOqxCIIgV+6Gpqax+ 0R4T8PeGbXxD
qgv7HR5dY1jR5Ll4A/2d9MTUHupnVGZjHt0y4K7AzndH8oJO3LH7SMcGt3Xh +/8Ah/4s0zxW
Psf2LQLh9Me41H7Qt66+TJHetAu2PTbx286WPiLA3Myqxrv7MHh7xNqBj1LX NdufChvNSvz4
R8y2TT/Pv7e7hvH81YBd/vPt92+PtGFaX5Qqqirwun/s/wDxIuf7f8Wa54h+ 3/EP/iXJoMv9
s23+gfZvtyPL9qTR44jvh1S8j8uSxlx1EmXQwGgamnrX7dHw98MRWX9uwX+g 3Tfam1Cy1O70
6C40yO3vbiykdka7zc/vbO5wll9okIjHyZkjD73ij46S3/gHxb4w8O2erafp 3gPUrltWbUrO
NINUt7G4nh1KCDJLSMsMMksUiGNDKbdGk+W5iSr8Pv2abvw74ftm1Dxrrtj4 hvvtJ8Q3OiT2
8f8Aakc1/d3wt3mNsrp5T6hdIJ7RbSRvMLgRkRrF0/iP4O/avhzeeBdKusaH r2sXlzrst9Jm
VrG9vJry/t4wiDPnedJbA7kaKOYyB2eJQ57otT06iiisyhH+6a+Vf2if+S3f C/6ap/6ISvqp
/umvlX9on/kt3wv+mqf+iErkxX8Nf4of+lI+p4b/AN9qf9ecT/6j1T3D4a/8 g5K7sdK4T4a/
8g5K7sdK7GfLFeT/AJCMH/XKT+aV+f8A4zfy/wDgqJpTZxjzOf8AuCGv0Ak/ 5CMH/XKT+aV8
A+MNv/D0fSd6h1/eZBgkm/5gh/gjIY/gfc8Zr9B4Mmqc8wnLZYeb/wDJoHhZ qnL2CX86/wDS
ZH3h/Yt5/wBB/Uf+/dt/8Zr4z+O1rJaft8/C5Jbua9Y2uiHzJwgYD+15ePkV Rj8M819xV8S/
tB/8n/fCz/rz0T/08S0uCP8AkY1f+vVT/wBJFnf+6f8Ab0fzR+iFFFFfInrF DTpN95qg37tl
yFxv3bf3MZxje2OucYTrnac7mv1Q06TfeaoN+7Zchcb9239zGcY3tjrnGE65 2nO5r9JAUNRk
2Xmljft33JXG/bu/cyHGN656Zxh+mdoxuW/WbrDSiXT0gmSGaSZ1RpMld3ky EZUSJvAIzt+b
p0GN6Txx3wnBe4t2h3ElFt2Dbcvgbt55wY+cfwtx8w2gzn5vix4HtvFV54Yl 8ZeH4vEln5H2
nR31SAXkHnPFHDvhL718x7iBFyPmaaMDJdc9BHq1jNqtxpkd7bvqVtDFcz2a yqZoopGkWORk
zlVdoZQrEYJjcDO04+YPj7BqHxL+JOhar4e0DxBd2Hgfb/bM0+h3lt/q/Eeg XrfZBLEpvv8A
R9LvnH2US7vLRRlpYg9TxJpOp/GT4/aPrulWXjjS/AmqTaRo+p3cMWreGrlx aWPia4kWTi3u
UgWa70394cRPI6IGZlZQxH0/ceLNDtNdh0SfWdPh1qfy/K06S6RbiTes7ptj J3HctrdMMDkW
8pHEbY1q+Fb/AMLeNNc8badL41tfiBceBfCutKfO0+TVRexWcVz4wsLeWBrU /a55Whl0USSR
F5ZIpIpZmdCz191UAFFFFABRRRQAUUUUAFFFFABRRRQBwnj3/j+tP+2v8oa4 O7+4fqK7vx8c
X9n/ANtv/QYa4S94jz7ivr8t/gR+f5s8jFfE/wCux19h/wAi3cf9hbSP/QbG r0/+qb6VRsP+
RbuP+wtpH/oNjV6f/VN9K+Nxv8Vnr0PgPkj4gf8AJ0//AHKq/wDpYa9os/Hp 8Ly6PpVvoGqe
INQv7a4ukh0xrZdkcLQq7MZ5oh1njAAJPX0rxf4gf8nT/wDcqr/6WGvTorDU dS8c6Fb6PPHa
6s/hTXBZzzDKRzGbThGzcHgMQTwenQ15eBScql1fWTt6K59TxLJwhhJR/wCf NPb1Z3EPj3xB
P/q/hj4qb/t50kf+31dD4U8R23jDwvo+vWaSxWeqWcN9Ck4AkVJUDqGAJAOG GcEjPc1yHwu8
M+PPHfi7T/FnjmH/AIRmy0LzILDw9atlbi58toZrqU5OU+aQRjJ4IIO3LTeG eOUXxr8G/gX8
NLjwbq3jvRNf0SHVNf0XSri2tmuNNs7KEAebNcQFWF9dabIBG4JWKQE7cq/X CUa9F1VDl103
1VnrZ7eX/BPisJiJ1/eaaTva+jaVtbWTW70ettep9W6pqlloemXmpaleQafp 1nC9xc3d1KsU
UESKWd3diAqqASSTgAEmi81Sy0+4sYLq8gtp76Y29pFNKqNcSiN5CkYJyzCO OR8DJ2ox6KTX
wp8T/jTrfi79nTxLYeO/G0/w91GD4fXVnLaXJ0y3bxNr8LajY6raBpElWVUm sodq2bRuFvVJ
I8yIJ6J/wm7+Kfj78OLfWPHefE1r471q3b4e7rKP7BZw6drMNreeT5X2webb rby75JWjb7Xu
VQrRhY5T07n1PZ6pZahcX0FreQXM9jMLe7ihlV2t5TGkgSQA5VjHJG+Dg7XU 9GBqzXxR488V
674e/aD8ZWeg6p/Yd1qfiOGybVLeytZru3SdvAtpIYnnikC5iupQVIKFtjMr GNCup8RPi98Q
fCviC+8Ijx1YaRo+jaxd2U3jbxNqVjoss7rYaTd29tLcvp1xaeY/9o3m2JLa N3js1YPmKXzT
lC59h0V4p4u8QeMdY8NfBSy/4SGfwlrfinUorfW73QrBEZSNFvruRIYtQt5G iUz28fEsQkVR
tba2a8n1z9prXfBngT4rXHiLxjYaLfab4c1O18JXeqC1tn1PVLDUtcs3kiDK qXFwUtdMeWJF
2B5U2xRrKFK5WwufYdVtO1Sy1i3eewvIL6BJpbdpbaVZFWWKRo5UJBI3JIjo w6qysDggivkX
xB8WviDomleKNci8bX832Oz8c+IrewmsbH7PGNB1UWtrY8W4kNvNHMPOJczE xIY5ovn35fh3
4qa74H0/xTH4C8V/8Jv4rTxH42kufh15dref2YkVxrFzb3HkW0aXi+ZdQ2UW ZZWRvtu1QGkh
KnKFz7Xor488FfE74keJ9V8OaFZfFDQtX0/VvEcOnt4h0O6ttfeONtK1W4uI PtMenWdoJF+y
WskaCOSSJ2DzCSKWOJvWP2nPiHqHgzTNBsdN8SQeCZ76aWZvEOq6vZ6Tp6rE qj7K91dWN4nn
SGYPHEIgzrbTsJFEZVzld7Bc9ror4L0rxHqHxA8C+KvEer+MJ/DWt+I9S8Ge L5tCsls44rSy
8rw3Jda5Ck8Uk3k27RXCGWR3tkFu4dSyOa9Ou/GHiLWLfxRff8JrB4r8L6V4 18H6NpAl06xn
W7iuJPD88l48yR7JGY3MjxNEsYjaaR1LYg8h8oXPp3S9Ustc0yz1LTbyDUNO vIUuLa7tZVli
nidQyOjqSGVgQQQcEEEVZr4U+Cvxd1Xw18HvhlbeFfiJ/wAJho9t4c0K58Ss wsLhPCccd9pE
U1vI9vCn2eM2c+plzdF5FSyZ1dDFKx7HSviZa/Eb9pux12D4jwWvg3TdS1LQ dI1jSp7B7K/k
ltfDM6aV57xyLI08321gsbCc+VIEcCMgHKwufXVFfFHgj47fFDVvCmu6jqfj 7wJpV8+jw3Wp
W2ra9Gg8LXkl1bI9tKy6YqaZIEmu40hvnvJDNFEMSrDcb/RPGOtXHjz9lDSd YGreJbdG13SL
2XXtbi04X9tawa9bvJfsbaNrIwxwxNOkyq0JgRJWLKWJXK0Fz6Tor5jl+Luq w+NoLSw+In9q
30WsaHp+heHMWD/8JTo1zFYG71nYkImm2C51CTzrV47dfsOSm2OYMftWfF3V fh//AMJpj4if
8K2/sjwgdX8N8WCf8JBqZ+2+Za/6ZDL53lfZ7L93b7HH2v5ifMi2nKwufTlF fFHjX49fFDSd
Q+KF1B4q0LT7rSLPxM0Xhn7ZHcahp1vZ294bC+/s8af5kHmGCzl8+6u5LeRb n5UBuIETp/i1
8RfiD8Ltbv8AwhZ+N/tliv8AZF7d+MfFM9jpj6VBdLq4cPdR2D2sMZl0y0iR pbSQl7t03bpI
miORhc+sKK+Y/hd8UfH2p6vquo67rv8AwkOjeG/CFvrjaT4U04Xc2uyPd6zD E0E8kMBm82C0
t2zFFFHPKsTwGOBmSbyez+Kut+MvFGjWWvfFbSW0Dwtrthq8/j3w/rumaouk rd6Zr1sUnu/7
Ot7SJTJDbRqstuWDXY/eMZYljOVhc+9KrR6pZTancabHeQPqNvDHcTWiyqZY opGdY3ZM5CsY
pQpIwTG4H3Tj5FvPjl8V7Xxt45bTtR0LU9U03/hIFtfAH2lrvUFhtIro6fN/ ZsFitzD57QWb
edNetFKt1iNVa4t0Tuv2fNb0jXvjn8R7jRviX/wtS1Xw54fjbWftOnz+S/2r WCbfdYwxRjAI
fDKX/ecnBUAcbBc+gLzVLLT7ixguryC2nvpjb2kU0qo1xKI3kKRgnLMI45Hw MnajHopNWa+P
LH4qPqll8K/Fep+K7/xx4rtNYbVNd8DaXHZS3egXn/CNa3JLp0NrDGk6SeYs kKxXTvJuhClt
wcnB0v8AaN8WppnifTrj4seDLzTtMm0m5m8R2ni/Sri6MVwuo+bZ2d2+nW1j 9qzYwMkE9vgp
JNunTfG8ByMLn3DWZ/wlOi/8JN/wjf8Aa9h/wkP2P+0P7I+0p9r+y7/L8/ys 7/L3/Lvxt3cZ
zXz/AOAvixresfGnw5od/wCI9WuYLvTbaWHw5bvpn9oWMZ01Z5JfEll5C3Fn M0r4V7VxAWaC
NkiLDz8zXYdQ0vxd8Wtah1id7RviZ4T086Hc2lnPZbpB4bVrkb4GlEwRiqsJ NqYV1VZFVwcu
tgufTul6pZa5plnqWm3kGoadeQpcW13ayrLFPE6hkdHUkMrAggg4IIIqzXwp 8BPir4+t4PhR
oFv4h0LSNLttH8MWVj4bvr8Ld6vYS6ZYvc3cdgthLc3G1prtBcRXUMEbWpMq BYJzJ7t+y/8A
EfVfiB/wkv8AbHib/hLb60+zNPqGiXdhfeGkmk81mh0y5t4o5jsATzIbvdLG Gh+aRXEso42B
O57ZZ6pZahcX0FreQXM9jMLe7ihlV2t5TGkgSQA5VjHJG+Dg7XU9GBqzXzH8 K/idb/Drwp8I
rzxT4gsPDPh7WPDmq3via81iaK0t/wDhKJLqymnhllkwIbjz5dXJtgV2mOZf LAhwnCeFv2if
iDe6FpF+uvf8Jh4rm8CQ6zYeGPDBsbvfd/2ELsya1YiFbyDzbpwsT2kgifzL eNliZgZzlYXP
tesz/hKdF/s/7f8A2vYfYftn9n/aftKeV9q+0fZvI3Zx5nn/ALnZ97zPkxu4 r5P8M/Gbxe+k
lNW+KehTeEJtYtbW+8e6Jqtnqn9ixtaX0rh7/wDsy10+PdPb6fCI3hlkX7Yd xBuLYqf2lYf8
MZ/b/wDhMv8AiV/8LH8//hMfOtP9T/wm+77f5nl/Zvu/vd3l+V327eKOULn2 HRXzHYfGTxfo
WkXniTSdV/4Wl4QsNYn8PabeeZZwf29Jc2lk9hc/a4I1hbbqby6Z+5jWNftO +Xm1kZt3456b
qGh+Gvg3L4i8eT6K+ia6ja348hgs7RYG/sXUIGupBPHLbQLNPJHHh1KhrhUU 7ihpcoXPdtO1
Sy1i3eewvIL6BJpbdpbaVZFWWKRo5UJBI3JIjow6qysDggirNfHlp4r8bfCf wTe+IPC2qX/i
W61nxf44srPwjeWUE9ok8EmvXsJgEESXTyPPYxqVaZwVnlCqCYynp37L/jjx J4w/4SWPV/GW
heOtLtfszWmqaJq0WrbJn83zoXu7fT7K2O1UgYQqjyp5haRtssIDceoXPbJN UsodTt9NkvIE
1G4hkuIbRpVEssUbIsjqmclVMsQYgYBkQH7wySapZQ6nb6bJeQJqNxDJcQ2j SqJZYo2RZHVM
5KqZYgxAwDIgP3hn4Uv/AIw+IrjWvDfifTPHkGu/EB/BV22vaDdTWMMXgqW5 1TQEvlcRWzS2
i26PcsWvVuDELMtIsgjlD6enfEa41Hx14G1Hxv8AGvSfCtpHpviS10/xlo2q 6dNFqEXm6E/k
G8u9OhtLhhIZxutrdQogEZYyRT5fIK59w0V8n6P+0j4kg8M29r4x1iw8J/EP WPEfhFbDwxeR
xWl21jeJoo1BILabMrxiabVIy53sjRyrvBi+XmLL9oPxO8/h94fib9v1jVPD gv8AxfoHlaa3
/CEztqejQXb7EgE1t9khvdROL1pQn2bdMHEcmVyMdz7XqtqOqWWj26T395BY wPNFbrLcyrGr
SyyLHEgJIG55HRFHVmZQMkgV8T6n8e/FpvdT07Qfi/pOo+DbfXby2h+IGs61 pWmROY9O0iaK
yF6mm3Fo7NJe6g3li3EjC2OJAIZFf1j4datrXxQ0L4o/8LX16wXwhbWcOlal o8dm+mWkEdxo
WnXV/JJNOEuY41a4n2LJ5UkSyS+YWPliA5bahc+iH+6a+Vf2if8Akt3wv+mq f+iEr3n4Oajr
+sfB3wNf+K0nj8UXWg2M+rJdW4t5VvGt0acPEFURt5hbKbRtORgYxXg37RP/ ACW74X/TVP8A
0QlcOK+Bf4of+lI+q4b/AN9qf9ecT/6j1T3D4a/8g5K7sdK4T4a/8g5K7sdK 7GfLFeT/AJCM
H/XKT+aV+f3jS/tNL/4Kh6Vc32qR6Lap5m++lkjjWPOiYGWkBUZJA5Hf1r9A ZP8AkIwf9cpP
5pXwfqelQa3/AMFW9Csrh7mOGXztzWd1LbSjGhMRiSJldeR2IyMg8Eivu+E1 eOZL/qGqf+lQ
PGzL4sP/ANfF/wCkyPviviX9oP8A5P8AvhZ/156J/wCniWvsT/hGLP8A57aj /wCDK5/+OV8Z
/Hawj0/9vn4XRxNM6m10RszzvK2f7Xl7uSccdOla8Ef8jGr/ANeqn/pJlnf+ 6f8Ab0fzR+jF
FFFfInrFDTpN95qg37tlyFxv3bf3MZxje2OucYTrnac7mv1Q06TfeaoN+7Zc hcb9239zGcY3
tjrnGE652nO5r9JAUNRk2Xmljft33JXG/bu/cyHGN656Zxh+mdoxuW/VTULa e4ELW06QSxMz
gyK7KSUZRlVdcgFgcHI47HDKRx3wnBe4t2h3ElFt2Dbcvgbt55wY+cfwtx8w 2gHP6B8WPA/i
vxVqXhjRPGXh/WfEmm+Z9u0fT9UgnvLXy3Ecnmwo5dNrsEbcBhiAeTXV18a6 38JviLe/BL4h
ar/aVxZ3Ggan481zwlomjaNc2utf2hPNrMFtL9p89jMrx30ksQigjYl7dldg p8zoPjLoHizw
xeatpunal8QNY1OLwyjeBdQsJ7+ZLjxM8189xJqJtALZYjI2mEJfKlkib0iR IlmRWB9VUV8Q
abq3jrWrbxTcfDG98cX/AMSk8QeNba8l1aXUZNFW1ik1iLTo7Y35Omhku00l Atv86hXDYjFw
KteBvB3jzWdW8M6VD4z+IFz4OvPE0K39zHpGt6I8UI0jVzcxtLq15c3wikf+ z0LgxQxuYmtn
W58x0APr+HxZodz9j8rWdPl+2Xs+m22y6Q+fdQ+b51umD80sf2efcg+ZfJky BsbGtXxVqPhb
4geD9H1mw+H1r4wtPiJN4z8U6hPHJJevpJS5s/EdzpLxG4J0/wAppZrBnEfy CZoRcASgAVbL
T/Gem+AdZZfG3jjUPDx1OxdbJvB/i21mv3WK7ae0WeS7utZtVciyZrqMC2jM SKqTmW5iYA+v
/GvxC8K/DXSotT8X+JtH8K6bLMLaO81u/is4XlKswjDyMoLFUc7c5wpPY1la X8a/AWv3OgQa
P4v0fXH16b7Ppx0i7S8WdvLu5Ad0RYKpXT70B2IUtbSIDuG2vNPH3g7xP4v8 P/s+W0KeIPA+
q2mtR3GpTafdRaxeaJ/xT+pI6y3dzFPHNiV0gaeVW3tICDvdTXmvxt8IfFyw +JNlB4U1HxR4
w1LStMiudF1rU7a38ldUbSPGCLI2yGKzRhJNpkTMUVSGthJncpIB9lVz/jX4 heFfhrpUWp+L
/E2j+FdNlmFtHea3fxWcLylWYRh5GUFiqOduc4Unsa+QLLT/ABnpvgHWWXxt 441Dw8dTsXWy
bwf4ttZr91iu2ntFnku7rWbVXIsma6jAtozEiqk5luYm9K+M9nrg8BfAW+uL bxh4Pu9M1qG4
1VvDdu/ijVNFzoWowsrObe7NziaVIGneJ93mbsgsGAB7U/xV8If8K4v/AB/b +I9P1PwZY2Vz
qE2t6XML238i3DmZ0aHfv2eW4ITJypGM8Vq6R4s0PxBeXdppes6fqV3Z5+0w Wd0krwYmmgO9
VJK/vra4j5/jglXqjAfIH7ST3vj34ceL4LuP4oa9pV98P3sfCa2Gj61ZXF/r QF/DeHUbSygh
2+ZjTSFvIUgYM5hXY01GneFviBaeMfiP4kjtfGCePtQ0XXdP8DXLSXps5Ly3 1jxJJbpdqT9l
ESwXWnG3N+BEVdfIJw2AD7Vor4/t9A8Q+KfiB4c0rwfqXxQ0r4U3OtWa3tzq k+sQX/mf2Zrp
v43l1IG8jtnxo6BwVjWRw1u8dwGdfsCgDgvH/wDyELP/ALbf+gw1wt9/q/yr uvH/APyELP8A
7bf+gw1wt9/q/wAq+wy3+BD5/mzx8V8Uv66I6+w/5Fu4/wCwtpH/AKDY1en/ ANU30qjYf8i3
cf8AYW0j/wBBsavT/wCqb6V8Zjf4rPYofAfJHxA/5On/AO5VX/0sNe46X4E0 nxZDpt7fHUIL
yyhlhguNN1S6sJFSQxmRC0EiFlJijODkZUV4d8QP+Tp/+5VX/wBLDXpt1f6m 3iLw7pdt4ou/
C2mPo+pajeXNpHakkwSWaqXa4ikVUVZ5CcAdsnivLwCk5z5JcrvLX5a7H1fE jjGGEc1dexp/
m+533/Cq9K/6C/i7/wALHV//AJKro9C0Wy8NaJp+kabD9m07T7eO0todzN5c SKFRcsSTgADJ
JPrXn11ps+neL9C8L3XxV8VNrms+Y1vaQ2uklljSN3aR/wDQvlX92VB6k9AQ rFaZ+NH/AAhX
wA8J+M9csNW8U6xqOmaey6V4ftEn1LU7qWFXkW2twUEjBfNmZVxtjikbGENe hUc5xf7zms7P
V6O1+vkfHUalGU3GEbNb7eTtp6o9aorzH4vftD+DPhJ8Mrvxdd+ItCuPO0e5 1XQ7ObV4bf8A
tzyofNSO1ck+Zv3RgMgf/WqcHIBteI/jl4Z0X4neFvANrq2k6n4o1fUnsrvS YdTi+26dEun3
N4J5LcZfaRBGnIUfv1bPQNyWZ3HolFYV5498M6f4usfCl14j0m28UX0JuLTR Jr6JL24iAcl4
4C29lAjk5AI+Rv7pqr4Z+KXgzxpaW114e8XaFr1rc3jafBPpmpQ3CS3SxGZo FZGIaQRK0hQf
MEBbGBmiwHT0VhWvj3wzfammm23iPSbjUXma3S0ivomlaVWuFZAgbJYGzvAR jINrOP8Alm+M
L/hfXwy/4Rn/AIST/hYvhP8A4R77Z/Z/9r/25a/ZPtWzzPI83fs8zZ82zO7b zjFFmB3VFed/
G74xWXwa0HSLy6fSYZ9X1IaXaT+INVXS9Nil8ia4JubopIYlMdvIqkRuWkaN cAMWWrZfH7w9
/wAJF4ttdYubDw5ofhyztrm41vU9Utlt98uoahYlGZXMceJNP43PvzMEdI3R lp2e4Hp1FYWo
+PfDOj+EU8V3/iPSbHwu8MVwut3N9FHZNFKVETicsE2uXTac4bcuM5FZd58Z vh/p/hGx8V3X
jrw1beF76Y29prc2r26WVxKC4KRzl9jMDHJwCT8jf3TSswOxorjta+M3w/8A Dep6tpur+OvD
Wl6jpEKXGpWl7q9vDLZRO0ao8yM4MasZoQCwAJlQD7wzqXnj3wzp/i6x8KXX iPSbbxRfQm4t
NEmvokvbiIByXjgLb2UCOTkAj5G/umizA3aK45/i14Zt/iq3w7utSgsfFD6b b6paWl1PFG19
FK90pFuhffI0Ys5GkAXCqyHJycang7x74Z+ImmS6l4U8R6T4n06KY28l3o19 FdxJKFViheNm
AYBlOM5wwPcUWA3aK463+M3w/vNT1zTYPHXhqfUdChnuNWtI9Xt2l0+KFts7 3CB8xLGeHLgB
TwcVW1D49fDLSdE0rWb74i+E7PR9W83+ztQuNctY7e98pgkvkyF9smxiFbaT tJwcGizA7quY
8a/DfQviH9jTXkv7q1tt4NjDql1b2l0j7d8d1bxSLHdRsFwY51dCpZcYdgbV 5498M6f4usfC
l14j0m28UX0JuLTRJr6JL24iAcl44C29lAjk5AI+Rv7prL1H4zfD/R9BTXL/ AMdeGrHRHmit
11K51e3jtmllgW4iQSFwu54HSVRnLIysMqQaNQOxorhbH43eDLrxX408N3Gv WGl6x4R/e6pb
aheQwulr9lt7lrwKX3C3VblFMrBVDq46AE2bz4zfD/T/AAjY+K7rx14atvC9 9Mbe01ubV7dL
K4lBcFI5y+xmBjk4BJ+Rv7poswOxorhfCfxe0XVvgv4a+I/iG7sPCGj6to9j qs8mp3yR29l9
pjjZY2nfYpw0qoGIXcSOATisvTv2h/BjQeJtQ1nxFoXh/wAPaXrFvpVlrl9q 8MdpqXnaZaX8
ckcjFU+ZLogKrNuWIuDg4BZgenUVhXnj3wzp/i6x8KXXiPSbbxRfQm4tNEmv okvbiIByXjgL
b2UCOTkAj5G/umsK8+N3gz/hWXifx7o2vWHi3w94ds7q8vZ/Dl5De/8AHvD5 0kSsr7PM2YIV
mH3lyQDmiwHdUV474a/aGt9e1DwNpywaFqd14jvPs0l54Z8RRapp8KG31WZX ilCJJLzpLo2+
GJN0jBHkMMgHovg7x74Z+ImmS6l4U8R6T4n06KY28l3o19FdxJKFViheNmAY BlOM5wwPcUWa
Fc3aK47wD8SrLx5b/aYxBZwXs12+ixvdK0+p2NvIkTXyJgDyXkdWjdC6tFNb SblM2xbVt8Uv
Bl5rejaNb+LtCn1jWrNdQ0vT49Sha4v7VlZ1ngjDbpYyqOwdQVIRjnANFhnT 0Vx1n8Zvh/qH
hG+8V2vjrw1c+F7GYW93rcOr272VvKSgCSTh9isTJHwSD86/3hXHf8NJ6L/w pn/hZW2w/wCE
e/4SP+xftn9pp9k+y/25/Zf277Rt2eXs/wBI/u7fl34+eizA9P0Lwzpvhn+0 Bplt9kjv7yS/
nhSRjF58mDI6ITtj3sC7BAA0jySEF5HZtOsLw7498M+L7fTp9C8R6TrUGowz 3FlLp19FcLdR
QyLHM8RRiHWOR0RiuQrOoOCQKwvGnxu8GeANJ8KazrOvWFr4e8S3i2dlrr3k Kaeu60nuo5Xn
ZwgjdLcqrKTuaSMAYbILMDuqK87+F3xy8M/E+/1jR7XVtJh8UaVqWp2V34fh 1OKe9hitL+W0
E8kQw6LIEjk5XA85RluCen8HePfDPxE0yXUvCniPSfE+nRTG3ku9GvoruJJQ qsULxswDAMpx
nOGB7iizQFrV/DOm69qGiX19befdaLeNf2EnmMvkztbzW5fAIDfuriZcNkfP nGQCNOvMZP2h
/Bj/ABNl8I2niLQr3+z9H1TVdcvIdXhb+xfsU1rE8d0gJ8rP2mQlnK7fs7DB 5K1dc/ab+H+g
a94TjuvFvhqHwv4j03Ur208Tza5bx2Ty2k9pCYI5CdkjMbmQ8Plfs7DB52uz Fc9YorMm8U6L
b/a/N1ewi+yXkOn3O+5QeTdTeV5MD8/LI/nwbUPzN50eAd65wbf4zfD+81PX NNg8deGp9R0K
Ge41a0j1e3aXT4oW2zvcIHzEsZ4cuAFPBxSsM7GiuF/4X18Mv+EZ/wCEk/4W L4T/AOEe+2f2
f/a/9uWv2T7Vs8zyPN37PM2fNszu284xVnxn8SrLw7pmtHSRB4m1/SIZLqfw 5YXStqEsUKwS
XCRQqGZ5hDcwskZADtPbqzRiUOCzA7GuOt/hN4dttT1zUgNWl1HV4Z7ea7uN cvppbaKZt0qW
bvMTZKxCEi2MQzFEf+WUe3qNL1Sy1zTLPUtNvINQ068hS4tru1lWWKeJ1DI6 OpIZWBBBBwQQ
RVmjYDC8HeCNI8B6ZLY6PDOqTTG4uLi9vJry6uZSqrvmuJ3eWVgiIgLsxCRo gwqKBa8TeGdN
8Y6Jc6PrFt9t0u62i4tWkZUnQMGMcgUjfG2NrxtlJELI4ZWZTp0UAI/3TXyr +0T/AMlu+F/0
1T/0QlfVT/dNfKv7RP8AyW74X/TVP/RCVx4r+Gv8UP8A0pH1PDf++1P+vOJ/ 9R6p7h8Nf+Qc
ld2OlcJ8Nf8AkHJXdjpXYz5Yryf8hGD/AK5SfzSvgTxVpNjrn/BUvSLLUbO3 1Cyl8zzLa6iW
WN8aISMqwIOCAfqBX33J/wAhGD/rlJ/NK+CfEFql5/wVS0WGRpFRvNyYpWjb /kBk8MpBH4Gv
uuFPhzL/ALBqn/pUDxsx+PD/APXxf+kyPv6viX9oP/k/74Wf9eeif+niWvtq viX9oP8A5P8A
vhZ/156J/wCniWtuCP8AkY1f+vVT/wBJMs7/AN0/7ej+aP0QqC+v7bTLSW6v LiK0tohukmnc
IiD1LHgVPXKfE66Sw8JG7kO2K2v7CeR+yol5CzMfYAEn6V8nFXkkepJ2TY/R vHPh2/1O6t4P
EOmXM09wBbwx38btJ+7QYRRIx6huAF5z8p+827q2rWOgaVe6nqd7b6dptlC9 zdXl3KsUMESK
WeR3YgKqqCSxIAAJNfJXw28bePtT8eeJbPxR4x0bxDpepeKNOn02107S5bdj GkemgyQ7r6fy
IA8NxugK5Mgkm3hZNtfUeu+I18GeHbrVtZ+130Fv5e9dF0i5vJzu2J8tvAJZ X+ck/Kp2qeeF
LUNK10JNt2ZP4W8WaH450K11vw3rOn+INFut32fUdLukubebaxRtkiEq2GVl ODwVI6itavgr
4lf8LK8O/DaafQLLxR4b1KGbxL4o8NS6bomu6jNqt1e6vf3drbz2lhPFHask RsXxqcMqE3jI
0S+TcI3us9j8S9E8d6/ZWUWoeItF8L/2j4s0eJ9QktpdenvYphaaRLdSDyTF DO2pAx4AgjGj
NlistSWe1eKfFmh+BtCutb8Sazp/h/RbXb9o1HVLpLa3h3MEXfI5CrlmVRk8 lgOpo8LeLND8
c6Fa634b1nT/ABBot1u+z6jpd0lzbzbWKNskQlWwyspweCpHUV8beAI7+3uf EEXiXxD8SJ9E
0ebStS8M+IdN8C+JHvrDVZo9Ut7zyoNWXUZ5VNp5cblw1un2hSqRzN5jd/4Q 1PxNq/jnw5df
ExPHA01obdPC02kW2p2y3My6nfL9o1aHT1VImlsho0skd8kcKNJOqxRYuI1A Poqx/sPw/eRa
JZf2fpt3efatSj06DZE8+Zle6uBGMFv31yrSOB9+cFjlxm3Jq1jDqtvpkl7b pqVzDLcwWbSq
JpYo2jWSRUzllRpogzAYBkQHG4Z+FfE1t468EfBn4MXXiHXviRKNS8P6ZJ4v umvNRF8t3PrX
haFrYi22yxz/AGc3sKRxqJn/ANIY+ZLJM79r4U8LXt38ZfCPiTU7X4gP8O9P vdU0/wALXN1J
rQ1GM3A0GSJL9Sftptmu7XVyTfgwBUj3ERG3yAfYFFFFABRRRQAUUUUAFFFF ABRRRQBwPxA/
5CFn/wBtv/QYa4e+/wBV+Vdv8Qv+QhY/Wb/0GGuJvv8AUfiK+wy3+BD5/mzx sV8Uv66I62w/
5Fu4/wCwtpH/AKDY1en/ANU30qhp3/Isz/8AYW0j/wBBsa0J+Y2+lfGY3+Kz 2aHwHyP8QP8A
k6b/ALlVf/Sw16Rdtp1v4q8Py65p2qX2gXPh/V9Num03TLu9wZpbDCN9mR2T ckcuG4+6cHNe
R/HTUr7wl+0BHrn9g6xqli/h9bQSabZtMBJ9pZyCeBwAM85+Ycc1ci/bS0Lw LZ20WteHfEmm
mUMIjdWccQk243bd8ozjIzj1FeHhcRTo1Jxmr3ctNdmrdmfomb5JjM0w+Fq4 aClD2UFe8bXT
d002j2n4PS/Dr4Qi9ubceMtY1i6/ctqd/wCENXeZLVMLDbqfsvyoiKgOMbio OAAipzWn/B7x
L408L/A8/wDCTap4Js/CuhfaZ47CG2F+uqNZw20OUuraZdiQTaijqQCGkjOC Vyvnv/DxLwN/
z46x/wB8W/8A8erpLT9se1v7WG5tvA/jO4tpkWSKaLS1ZJEIyGUiTBBBBBFd P1nDUKSpU48s
fn5+S7nzmF4QzKglClRVl0Uo9f8At5mXN+zT8RfDXwu8TeENDvdC8S/234Qk 8Cx3WualJZPp
+n28+pLp0uYLJ1uJBa6hEki7YsPbEh5PMLL3ekfCbxnpXjbwna+ToUvhDQfF +seK/wC1f7Sm
GoT/AG+LUz5H2P7N5a+XJqe3f9oO5Yd21S+xed/4a9T/AKEHxv8A+Ckf/HKP +GvU/wChB8b/
APgpH/xysfrtF/a/Bnf/AKr5v/z5/wDJo/8AyRsfEb4C+JvHXijx5aaVqUHg 3wv4u027tdYu
YdRl1JtXll0z7DE8mnywKlo0J8tvMtrgGVbdVkVt6tCal8KvH+vePrX4lXVl 4as/FGmTWK2n
hyHWLiayuYre31aAtJfGzV4mYa1I20WzgfZVG798TFj/APDXqf8AQg+N/wDw Uj/45R/w16n/
AEIPjf8A8FI/+OUfXaP834MP9V83/wCfP/k0f/kiLwt+yxrN9pXxP/4Sh9C0 3WPGnhzUdDiv
dML376Z9t1XWb2ZVeSKFnjC6jaZA2b3tzkKFQnd+IPww8efEnU/DfibUtG0m z1vRodQ01dG0
bx7qumRTW901nJ9oOoWtpFNuVrQp9nMRRhIHMgZApx/+GvU/6EHxv/4KR/8A HKP+GvU/6EHx
v/4KR/8AHKPrtH+b8GH+q+b/APPn/wAmj/8AJHpKfCWfTNN+DOmadJYRWPgS 8jedI1mjR4E0
e8sVWBXeVx89xEQskjEIGy7MPm8dv/2TvFEniK/1wXlhdSRaxJqtnYWmu32k Pcb9Q8SS+W97
bR+dbYh16Bt0avueCSIgI/mVs/8ADXqf9CD43/8ABSP/AI5R/wANep/0IPjf /wAFI/8AjlCx
tH+b8GH+q+bf8+f/ACaP/wAkdtD8GL61+DOh+E7QWFjfW3iPT9fuE+23d1Eu zXItTuE+03Bk
mnkIWQea+3zZDu2wq2xMHxj8GPGt14o8V6ppd3Bf6VrOunU/7Dh8Tah4eaQf 2ZptpHNJfWUT
TBo2srofZwDHIt0rsweJVrH/AOGvU/6EHxv/AOCkf/HKP+GvU/6EHxv/AOCk f/HKX12j/N+D
H/qvm/8Az5/8mj/8kS/Bn9m3xN8O9O8Cwalf6TO+ha7Y6pcm1mlYPFD4RTRX Cbo1yxuVLgHA
8vBJDfJWD8Nv2SNd8GS+GLTUjYatawf8I/e312vifVoLe2utNsrCDZHpcWy3 u8vpySJcTOjK
ZVLRSCAJJs/8Nep/0IPjf/wUj/45R/w16n/Qg+N//BSP/jlP67R/m/Bi/wBV s2/58/8Ak0f/
AJI7b4o/B7WfG+t+OIrG6sIdH8c+EP8AhFNRu7iRxcaV5a6gYp4YQhW63tqB DI0kGwQ5DOXw
u78PvC/iYeOvEnjLxXa6TpOo6ppun6RHpejahLqESRWkt5KJjPJBAdzm+ZfL 8vCiEHe28qnl
n/DXqf8AQg+N/wDwUj/45R/w16n/AEIPjf8A8FI/+OUvrlH+b8GP/VfN/wDn z/5NH/5I8/sv
hH4w+IM/h/wAdL+yaP8ADfw4NCt9f83U9N/tWe11PRp4BvktIGg89dIk/fWU l2Id+4OxEXne
xfCX4F6t4K+IVh4qvIbCw8yz1dL+0j13UNZuPPuTpCQs15e/vLjEeltltsQQ NFGqNsaVud/4
a9T/AKEHxv8A+Ckf/HKP+GvU/wChB8b/APgpH/xym8bR/m/MX+q2bf8APn/y aP8A8kY3w2/Z
I13wZL4YtNSNhq1rB/wj97fXa+J9Wgt7a602ysINkelxbLe7y+nJIlxM6Mpl UtFIIAknUWXw
D8UeE/gv8L/B+ifYJI/DmjpZ6toumeIr7w3b3l8Y4t16t9ZRGdsSLckxMgWU 3Zkch4kBof8A
DXqf9CD43/8ABSP/AI5R/wANep/0IPjf/wAFI/8AjlH12j/N+DD/AFWzb/nz /wCTR/8Akih4
Z/Zf8W6F8H7nwFPdaTcwXEPh7VZL+11W6s5RqOmW+lQmzRo4g8cMo0rcL1HE sZnGIGMYLb3h
L4J+L/h7rdn4x0PStCufEL/2jDeaLqfirVLpGS6XTV85tVuYZ5p5EGkxKE+z xJsmCjBh3z0P
+GvU/wChB8b/APgpH/xyj/hr1P8AoQfG/wD4KR/8co+u0f5vwYf6r5t/z5/8 mj/8kdZpvwi8
TeGvhJ8GNMsG0nUfFHw7hsma0ubuW3sr+WPSp9OlUXAhd41AuXlVvJYt5aqV XeWTC1z4OfEL
UNV1/V1ksJI9b1hdUufDmn+LdR0VBIdK0y1Eh1K0txO3kyWV2oh8sRypcpI+ x4lQUP8Ahr1P
+hB8b/8AgpH/AMco/wCGvU/6EHxv/wCCkf8Axyj67R/m/Bh/qvm//Pn/AMmj /wDJFDwX+zR4
t8NeGrbw3JDpKaBN4Wg0nxLYw+IrqS28V3Eeix6eIpIntM6coKL/AKVayb2S FfMicsvk93J8
K/HGu/s8/EPwZrmtwXWt+IdN1HT9Jhur572LSoZrTyILd7028U10qtukM0sR lxIVYysnmPyf
/DXqf9CD43/8FI/+OUf8Nep/0IPjf/wUj/45R9do/wA34MP9V83/AOfP/k0f /ki/8d/2adZ+
MfjvUb6DVrDS9H1HR4tKlmkDyXEP/Et8RWjyLEAFfDa1bMFLrkRy5KkLu7H4 IfC/UfA+p+Id
Z1jT4NO1HVIbS08tfFWqeI5Wigad1LXd/tKrm5fbCkShTvYvJ5gWPz//AIa9 T/oQfG//AIKR
/wDHKP8Ahr1P+hB8b/8AgpH/AMcpfXaLVub8GH+q+b/8+f8AyaP/AMkX/APg Pxn4W0TwA+i6
TYXuu/D7R77wNLYa9dzabb39qWsTDqMVxHbzg+ZFYW8nlKrqpupI2lElu6ty /h/9lTxna+B2
8FR6vYeFNH1HwhHoPiK+0/U5tTTWroaJHpqyGxnt41tfKZUcSwTq0qW6LKhL qYdn/hr1P+hB
8b/+Ckf/AByj/hr1P+hB8b/+Ckf/AByn9do/zfgw/wBV83/58/8Ak0f/AJIl 0T4BeKtH1iy8
Y22maTB4o0zUra6g0vUfGer60t9FFZ6ja7JdSvI2eBQNVlkWOO1YBom3M3n5 g3f+FTeM/wDh
RP8AYfk6F/wl/wDwl/8Awlf2T+0pv7P/AORj/tbyPtP2bzP9X+73+R97nbiu d/4a9T/oQfG/
/gpH/wAco/4a9T/oQfG//gpH/wAco+u0f5vwYf6r5v8A8+f/ACaP/wAkS+Kv hF4mvidRmafQ
vG3jDxSzS3nhS7lki0Wxl0mKyvFe+MMchVrewE8TGJFF99gDKyxb29O8f/D+ 8ew8DTeDLHSY
Z/BmpC90/RLmRrGyli+wXViIBJFFIYFSO7LrticfulTCht6+Wf8ADXqf9CD4 3/8ABSP/AI5R
/wANep/0IPjf/wAFI/8AjlL67R/m/Bh/qvm//Pn/AMmj/wDJF/xr+zTrPjf4 ZW/hGXVrCw8z
xH4q1K5vEDy+Va6rDrcUJRMLvkT+1ICyEqvySAOcKW7H4IfC/UfA+p+IdZ1j T4NO1HVIbS08
tfFWqeI5Wigad1LXd/tKrm5fbCkShTvYvJ5gWPz/AP4a9T/oQfG//gpH/wAc o/4a9T/oQfG/
/gpH/wAco+u0dub8GH+q+bf8+f8AyaP/AMkY2ofsyeOte8P+D/DN+2hW2j+C PDkWiabf2OuX
kV3q729/o91E0my3RtP8xdIKl4pZ3hacMnmGP5t7wv8ABfx58PPF2l+LdA0L w1d6jLDq0Wpa
ZqvjHVblg1yNKSKT+0Lm2uJblgmlYIMUKqrxoFbyzJJF/wANep/0IPjf/wAF I/8AjlH/AA16
n/Qg+N//AAUj/wCOU/rtH+b8GH+q2bf8+f8AyaP/AMkRaD+zj4z8BeGdM8Fa NPoWueHm1jwv
qt7rd9ezWV3D/ZSaVDJHHaLBMknmJpIcM06Ya4KkYj3vwll4F8YajP4f8PHR vL0f4R+HBYW+
tfZNTX+2J7HU9GuoE8mSxRv9IXRpBmyN8E8zgyHyhN6B/wANep/0IPjf/wAF I/8AjlH/AA16
n/Qg+N//AAUj/wCOUfXaP834MP8AVbN/+fP/AJNH/wCSOT0H4UeN/ip4g1j4 l3Hh/wDsu+vN
YvRbaH/wlOs+HPNtZrDRoDcfaorWK7G2XSXXyJraNX8zzASqRNL6d8PvhlP+ zf4S8e6npfh+
w8Qaxd/2dDpNjokMsUt6lrpNjYWto7yea8Mf2iGYhpJJUhjmMkkmPMYc7/w1 6n/Qg+N//BSP
/jlH/DXqf9CD43/8FI/+OUfXaL+1+Yf6r5v/AM+f/Jo//JHuPwt8Fj4a/DLw j4R+2/2j/YGj
2elfbPK8rz/IhSLzNmW27tmduTjOMnrXT5FfM/8Aw16n/Qg+N/8AwUj/AOOU f8Nep/0IPjf/
AMFI/wDjlT9bo/zfgx/6r5v/AM+f/Jo//JH0xkUZFfM//DXqf9CD43/8FI/+ OUf8Nep/0IPj
f/wUj/45R9bo/wA34MP9V83/AOfP/k0f/kj6Wcjaa+Vv2if+S3fC/wCmqf8A ohK02/a8Qj/k
QfG//gpH/wAcry7xd8Rbr4p/FfwRfW/hnX9Kt9M+2iaTVLExL+9hAXBBI6rj nHUVz1sRTqxj
CDu+aPR/zI9zJ8kx+X16uIxVPlgqOITfNHrQqJbPq2kvNn1d8Nf+Qcld2Olc L8No2XTY8jHF
d0Oleoz86K8n/IRg/wCuUn80r4O1b/lK1of/AG1/9MTV94yf8hGD/rlJ/NK+ DtW/5StaH/21
/wDTE1fdcKfBmf8A2DVP/SoHjZj8eH/6+L/0mR9818S/tB/8n/fCz/rz0T/0 8S19tV8S/tCH
/jP/AOFn/Xnon/p4lrbgj/kY1f8Ar1U/9JMs7/3T/t6P5o/RCiiivkT1ihp0 m+81Qb92y5C4
37tv7mM4xvbHXOMJ1ztOdzSatq1joGlXup6ne2+nabZQvc3V5dyrFDBEilnk d2ICqqgksSAA
CTVS2NzLqGoCC5iWNLlVdJFMhH7uE4GJTt+XfxtXllbacEyQa74jXwZ4dutW 1n7XfQW/l710
XSLm8nO7Yny28Allf5yT8qnap54UtSQyfwt4s0PxzoVrrfhvWdP8QaLdbvs+ o6XdJc2821ij
bJEJVsMrKcHgqR1FVZvH/h2G50SAatbzvrOp3GjWJtiZllvYI7iSeAsgIRo1 s7kNuIw0TIfm
wp+X9I0DxxptrY6FpWpaho3/AAs698QRSWc089vfaNYSa5eX6atbwgBrOU6f fzxvJKpZLuTR
4pETEgqrpvwbGo+JtB0G/wBP8cW18Pinres61La6jrFraW1lcweIprGe0uop FhhV0ubYS/ZH
X55ljn/eNtLEfZVFfFWtf8LIj0nxFa33/CwDrVjZanYfDZrD+0yjanBq+rQ2 rai8P7uWI20e
hETaqWhlQvIWcPcsfQPAPhnxZoXirwt4habxhLf618QPE1hrkOp6lf3VnHoy vrL2TLaTSNBb
RZt9MEc0SISrIoYrMwcA+itT0mx1q2S31Cyt7+3SaG5WK5iWRVlikWWKQBgQ GSREdW6qyqRg
gGrdFFABRRRQAUUUUAFFFFABRRRQAUUUUAcB8Qv+QhY/Wb/0GGuJvv8AUfiK 7b4hf8hCx+s3
/oMNcTff6j8RX1+XfwIfP82eNivil/XRHWad/wAizP8A9hbSP/QbGtJhuGKz dO/5Fmf/ALC2
kf8AoNjWnXxuO/jM9jD/AMNHG+J/B8GtX8IdQcxSH9UryDxr8PDpPxB0qa0s ZNQng8Na1dR2
cIO+do5bArGuATlicDAPXoa+iZP+QjB/1yk/mlc14o8La5e+LNG8QaBq+naZ e2Fld2LR6nps
l7HKk72zkgJPCVZTbL3IIY8VzUGlN8zto9fkOvGUqbUN9Pz8zxr4bQ3Hxd8X WLeFLCWLwbYI
X1XVL6PY007QnbaxDn5kZlZyP7vUKV83yi5sJ9F0f4KaV/b/AIn0HTNV8GT3 87eE9A/te6lm
hXTFiDRizumSMLczZYIoyVBbJAP19ZRfEfToTDa+IPBltEXeUpF4UuVBd2Lu 2BqPVmZmJ7kk
nk1H4O+GemeFdP8AB/m/6frHhrQzoNtqPzR7oGFt537vcVG9rSBuclduAcFs 1Fezo8s6nPJu
+iaWz2utvv7nJhaVeGtZ3et3ol00STdlp+vU+XrTx/4g0Twl4jvfFXgVrTUf DTaVpWo/Yroz
rPrF9b6cyW8MMKzS+WkuoFZGUSMFWMxC5Z2SNLj4pXlp4bsb2+8GN4bnku7i 3utS8WSX+j6F
brEkDK7X09gJI/MNykcZnt4VeSK4RXJWPzvqq/8Ahn4a1K08SW1xpu+PxDeR 6hqLLPKrvdRx
QRRTxuGDQyRra25R4irI8SupD/NWDJ+z/wCC59Mt9OmtdWuLJJpJ7mGfxBqE g1NpFRHGobpy
b9THFHFsuvNURqIwAny1ldHo2PmnXPjV/ZU3jO5t/Aer3+heH4taCailtfIj z6bHcGbzpms/
skcLyWksavHczPueEGIFpFi6/wAS+I7nwak9vrnhU6drV3pK3+haW2oLI+pX T3q2iWLyIjRw
SCS60tHcs0Ya9ba8iQPIfZ9X/Z88B6/ca1JqGjz3UGrw3cNzYPqd39iQ3Ubx 3MsFqJfJt5pV
lmDzwokjefMS2ZXLdjq/hjTNd1DRL6+tvPutFvGv7CTzGXyZ2t5rcvgEBv3V xMuGyPnzjIBB
dDsfL3g3xs3jP4nz+G7Xwdq/9iLqN/pKa2llfFEntHmjleZ2tFtFhMlvKitH dSuWeEGNS0gi
29W1SDS/+Eq/4lBk/sLxbpHhY/6Tjzjff2bif7ny7P7SHyc7vK+8u75fadO+ EXhXSvFz+JLa
wnXUTNLcxwvf3D2VvcShhLcQWbSG3hmk8yXfLHGrt5025j5sm6r4i+CHhDxV 4mi16/s78XyX
lrqDxWer3lraXN1bPG8E89rFKsM8iGGEB5UZtsMSklUUBXVwsfNOg/E+/m0H wRqeu+D7LTh4
0s9N1LR4tO1p7vFtc3+m2khuC9tF5cif2rbuEQSB9kgLphS2l45+IK+E9f1z Sk0Oyt4tK1Zt
Nn17xBqUtho0CrYWN0GubxLaZbaSRtQSOJJAFkMT4kDlI2+hJfgb4Im0TQtJ bRP9B0LSDoWl
qt3OHs7TdbOojkD71kR7K0dJs+ajwqyOrZJzIP2bvAsFpNatBrt1a3N499ew XvijVLhNRkeK
GFlvFkuWF3GYraGPyp98ewFduHYM7oVmfPdz8ZrTT9Y8UzXHgrXpfCeg/wBr pNq9nYXrsG01
bg3DOz2yWaxs1pNGhS7kYu8KsiFpBF1fw58I+KNT+M3jTTPFVlY6U1poGi3N vYaVq02oWyiW
41RWl3SQQbXbyVVgEPEafMei+2P8DfBE+t32p3Oifbvtv2gy6be3c9xpivOr rcSR2Mjm2jkl
WWYSSJGrv58+4nzpN1rwN8JfDvw71PVNS0gatPqOpwwW91d6zrl9qkrxQtK0 SB7qaUoqmeY4
UgZck5obXQdj5k8ES+J9T0bwA+jaPY+Ida8faNeeMnGt61LYwafbBrLyrWPy 7afd5cd9BFlU
jDmF5WG+Vqh8M/Ga08b+J9GtvD3grXtR0G9/sxJ75bC9ee3a+tba5jY+TbSW gjjivIGlMl3G
yhZSEcLH5v0v4F+EemeCLu3mR/tn9l/b7XQyQ0Z03T7uWGeSyCh/LaNJII1i wieXDFDEB8jP
JV0j9nzwHoFxosmn6PPawaRDaQ21gmp3f2JzaxpHbSz2pl8m4miWKEJPMjyL 5EJDZiQqXQrM
+fNQ+LFjYeGhqA8N3Fzf2mnxHWNPtpZJn0zVJtTGlwWJ8uFnuFN3Hfo0tukh C2TMscnmxB7X
gzxpq/i/xN4c8Pj4e6hYajqX2+S5mv2uLG3t4LR7DfPGLu2guJoyl/sB8hSZ 4imPLJuE+l7/
AOGfhrUrTxJbXGm74/EN5HqGoss8qu91HFBFFPG4YNDJGtrblHiKsjxK6kP8 1VfC3wi8K+Dd
TtNT0ywn/tW3huoBqN7f3F5dTLcNbmYzTTSO8zEWdqoeQsypAiKVQbaV0Ox4 b4619fAvivxX
Yz+HLi80Pwt4XTxXq2rQ3UYZLdhfDyY4TgvMTZfKCVQq0hZ0KIs3N6b8Q7+4 8Ka3eX/gq60r
XLSa2i0+zurXWIoNVaUyExW/maWl3LNHHBNK6Q2kiqgRi+PMMX1TeeBNA1LU 9bv73SoL6fW9
Nh0jUUugZYrqziadkheJiUK5urjPy/MJCGyAAOYj/Z/8FpplxaNa6tcTzTRz /wBrXPiDUJtV
iaNXWMRX7zm5iVVmnUJHKq4uJxjE0gYugsfKXjn4jar42+Cvju88G6B/Z+oa P4Vv9R1e41LU
bjTptOZZNQtN1ov2YyySLNpt0wEy2zACHIRmdYvZvB/gaW0+KHjbwlPcTXtt a29jr9nLM5Zr
eK9e6ia2y2WYLNYzShi2AtyI1VUiXPaX/wCy18ONR8OHQpdM1aPTpIbm3uhb +I9Shl1CK4ml
nmS8mS4El2pkuLhgJ2cKZ5duPMbPY+E/BI8Pa34l1u8vP7T1jXLwSyXBi2C3 tY18u2tIgWZh
Gi7nI3FTNPcyKqCXYrbVtAsfI3wb8Y3198MfBV9daUNT0e2t/DmiazrN1qT/ ANoNqWoWmntE
8cBiZZo92pWpeR50fmYhG2L5nVweJdSm+F1v
Re: Java debugging - cannot be resolved [message #515472 is a reply to message #515327] Thu, 18 February 2010 20:38 Go to previous messageGo to next message
S B is currently offline S BFriend
Thanks Rich:
Your image came through as mime data. Do I need to enable something here to view it?
-SB
Re: Java debugging - cannot be resolved [message #515475 is a reply to message #515472] Thu, 18 February 2010 21:11 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
I don't know anything about that. But it is on
Window->Preferences->Java->Compiler
On the page in the section labeled "Classfile generation" It is the
three checkboxes that end with ...(used by the debugger).
They need to be checked for the debug info to be built into the .class
files.
S B wrote:
> Thanks Rich:
> here to view it?
> -SB
Rich Kulp
Re: Java debugging - cannot be resolved [message #515476 is a reply to message #515475] Thu, 18 February 2010 21:26 Go to previous messageGo to next message
Ok, thanks. I do have those checked already.
I guess the loss of variable names in jars is due to something else. I'm wondering if the debugger is still looking in the rt.jar even though myswing.jar is higher in the classpath -- although it does breakpoint into myswing code. I'll try some other tests.
-SB
Re: Java debugging - cannot be resolved [message #515491 is a reply to message #515476] Fri, 19 February 2010 00:21 Go to previous messageGo to next message
Um, you can't replace java classes that already exist in the rt.jar. Is
that what you did? Java doesn't allow you to do that. You can only add
classes.
> -SB
Rich Kulp
Re: Java debugging - cannot be resolved [message #515679 is a reply to message #515491] Fri, 19 February 2010 18:20 Go to previous messageGo to next message
Eclipse User wrote on Thu, 18 February 2010 19:21
classes.
I thought I read somewhere that the class loader uses the ordering in the class path to find and load classes, but that's an area I'm not clear enough on. So maybe I'm stuck not seeing variables in the debugger.
More info if you're interested.
(BTW: Is there a way to see the actual command that Eclipse uses to run the project application to verify the classpath?)
The debugger seems to know about overlapping libraries -- when I do add "myswing.jar" to the libraries, duplicating the existing Swing classes, and attach the project source to "myswing.jar" and also attach the JDK source to the rt.jar, then the debugger asks which source I want to use when it enters a Swing routine.
It seems then that the debugger knows that there are overlapping libraries, but doesn't know which one it is running perhaps? But no matter what I choose, I can't "watch" or inspect variables other than the method parameters (arg0, etc).
That seems consistent with what you said about not being able to replace classes in rt.jar, if in fact it always runs the Swing code in rt.jar, ignoring "myswing.jar".
The way around it may be to actually include the Swing source in my project, rather than making a separate project and jar. I'll try that.
-SB
Re: Java debugging - cannot be resolved [message #515795 is a reply to message #515679] Sat, 20 February 2010 17:58 Go to previous messageGo to next message
There is a special exemption for any classes that are part of the java
runtime itself, anything in rt.jar. Java makes sure nobody can override
a class within rt.jar. Otherwise you could cause major havoc by
overriding the SecurityManager class when running as applet. That would
allow defeat of all security operations. They also don't want you to be
able to change the operation of any system class because that would
cause problems to people who expect the code to work one way and you
replaced the class and made it do something different.
So, no you can't just compile the javax.swing classes into your own jar
and expect those classes to be executed. Java won't allow you to replace
the javax.swing classes with your own build of them.
>> Is that what you did? Java doesn't allow you to do that. You can only
>> add classes.
Rich Kulp
Re: Java debugging - cannot be resolved [message #515839 is a reply to message #515795] Sun, 21 February 2010 17:10 Go to previous message
Ok, that makes perfect sense, I had never seen it stated.
I'll work around it best I can. At least the debugger will attach source to the rt.jar and display it to its ability, which is helpful.
Thanks.
-SB
Previous Topic:compiler bug with ternary operator and typed static method
Next Topic:Compiles too many files when add one method
Current Time: Mon May 28 03:40:08 GMT 2018
Powered by FUDForum. Page generated in 0.02152 seconds
