radio button group with no default selection [message #514872] |
Tue, 16 February 2010 23:34 |
luke w patterson Messages: 2 Registered: July 2009 |
Junior Member |
didn't know until now about this user list, crossposting from dev list
http://dev.eclipse.org/mhonarc/lists/platform-swt-dev/
ok, I give up, hopefully someone can point me to a link and I'll be on my
way, what I want sounds simple enough, but I've been working on it with two
other team members for 4 hours now with no luck,
I want to create a reusable composite class that contains radio buttons and
I don't want any of them to be selected by default. It seems that when a
shell is activated that contains radio buttons, the first radio button on
the page gets selected. I found a partial answer here:
http://www.rhinocerus.net/forum/lang-java-gui/590377-swt-i-w ant-radio-buttons-not-initially-selected.html
that answer kinda works, but I don't want to mess up traversal, and I don't
want to add dummy buttons. Is it the OS that is selecting a default? or
SWT? How can I suppress that behavior or distinguish between OS noise and
actual user input?
Luke
swt 3.5, windows (i'm guessing part of the answer will involve the words
"windows 'feature'")
Re: radio button group with no default selection [message #514898 is a reply to message #514872] |
Wed, 17 February 2010 04:51 |
Vijay Raj Messages: 608 Registered: July 2009 |
It is a pickle....
see this snippet
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.RowLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
public class RadioButtons
public RadioButtons()
Display display = new Display();
Shell shell = new Shell(display);
shell.setLayout(new RowLayout());
Label label = new Label(shell, SWT.NULL);
label.setText("Gender: ");
label.setBackground(display.getSystemColor(SWT.COLOR_YELLOW));
Button femaleButton = new Button(shell, SWT.RADIO);
femaleButton.setText("F");
Button maleButton = new Button(shell, SWT.RADIO);
maleButton.setText("M");
// Button aleButton = new Button(shell, SWT.RADIO);
// aleButton.setText("M");
// Button leButton = new Button(shell, SWT.RADIO);
// leButton.setText("M");
label.setText(" Title: ");
Composite composite = new Composite(shell, SWT.None);
composite.setLayout(new RowLayout());
Button mrButton = new Button(composite, SWT.RADIO);
mrButton.setText("Mr.");
Button mrsButton = new Button(composite, SWT.RADIO);
mrsButton.setText("Mrs.");
Button msButton = new Button(composite, SWT.RADIO);
msButton.setText("Ms.");
label = new Label(composite, SWT.NULL);
label.setText("Education: ");
Composite composite1 = new Composite(composite, SWT.None);
composite1.setLayout(new RowLayout());
Button mrButton1 = new Button(composite1, SWT.RADIO);
mrButton1.setText("High School");
Button mrsButton1 = new Button(composite1, SWT.RADIO);
mrsButton1.setText("Graduate");
Button msButton1 = new Button(composite1, SWT.RADIO);
msButton1.setText("Post Graduate");
// Button drButton = new Button(composite, SWT.RADIO);
// drButton.setText("Dr.");
shell.pack();
shell.open();
// textUser.forceFocus();
// Set up the event loop.
while (!shell.isDisposed())
if (!display.readAndDispatch())
// If no more entries in event queue
display.sleep();
display.dispose();
private void init()
public static void main(String[] args)
new RadioButtons();
radio buttons on shell
and on composite1 are not selected by default...
although if remove composite...
then default button enablement comes up...
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
FUDForum. Page generated in 0.03670 seconds
