Home » Modeling » TMF (Xtext) » xtext expression language example for 0.8?
xtext expression language example for 0.8? [message #514759] Tue, 16 February 2010 09:53 Go to next message
Michael Scharf is currently offline Michael Scharf
is there somewhere an example of an expression language for
xtext 0.8?
Michael
Michael Scharf
Wind River Systems GmbH
http://www.WindRiver.com
http://MichaelScharf.blogspot.com/
Re: xtext expression language example for 0.8? [message #514821 is a reply to message #514759] Tue, 16 February 2010 08:12 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian Zarnekow
Hi Michael,
please have a look at the
org.eclipse.xtext.testlanguages.SimpleExpressionsTestLanguag e in one of
the test plugins.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 16.02.10 15:53, schrieb Michael Scharf:
> xtext 0.8?
> Michael
Re: xtext expression language example for 0.8? [message #514878 is a reply to message #514821] Tue, 16 February 2010 14:04 Go to previous messageGo to next message
Hi Sebastian,
unfortunately, the files in the project
org.eclipse.xtext.generator.tests
are not accessible via anonymous cvs :-(
( I can see the directory structure but
all directories are empty)
using the web interface is quite painful to
fetch all the files and setup a project...
In the web interface I can see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.tmf/org .eclipse.xtext/tests/org.eclipse.xtext.generator.tests/src/o rg/eclipse/xtext/testlanguages/SimpleExpressionsTestLanguage .xtext?root=Modeling_Project&view=co
but using the eclipse cvs client I cannot see it.
Could it be that someone did something on the command line
with the cvs repository that causes some problems with
unix permissions? (I had this problem before with some
other CVS repositories)
I am now downloading the entire modeling CVS reopsitory (600Mb)
http://archive.eclipse.org/arch/modeling-cvs.tgz
hoping I can get access to the files....
Michael
> Hi Michael,
> the test plugins.
> Sebastian
Michael Scharf
Re: xtext expression language example for 0.8? [message #515046 is a reply to message #514878] Wed, 17 February 2010 09:46 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven Efftinge
Hi Michael,
that could propably be a bug with the changes the Eclipse webmasters
introduced in order to improve overall performance of CVS access.
Anyway, we (accidently) included the current state of the base language
in M5. Which might as well guide you a bit. (importing it with source
code should work).
Sven
Michael Scharf schrieb:
> Hi Sebastian,
> Michael
>> Hi Michael,
>> the test plugins.
>> Regards,
>> Sebastian
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: xtext expression language example for 0.8? [message #515068 is a reply to message #514878] Wed, 17 February 2010 10:48 Go to previous messageGo to next message
Hi Michael,
the test projects is org.eclipse.xtext.tests. The former
org.eclipse.xtext.generator.tests has been cleared.
Sebastian
Am 17.02.10 00:59, schrieb Michael Scharf:
> Hi Sebastian,
> Michael
>> Hi Michael,
>> the test plugins.
>> Regards,
>> Sebastian
Re: xtext expression language example for 0.8? [message #515121 is a reply to message #515068] Wed, 17 February 2010 13:41 Go to previous message
Hi Sebastian,
ah there it is!
It would be *very* helpful if there would be a
README.txt file inside the obsolete project saying
that it has moved...
Michael
> Hi Michael,
> Sebastian
Michael Scharf
Previous Topic:NPE in AbstractInternalContentAssistParser.createFollowElement
Next Topic:Newbie: Workflow doesn't generate for Model Root
Current Time: Sun May 26 04:13:29 EDT 2013
Powered by FUDForum. Page generated in 0.01799 seconds
