Home » Archived » B3 » first builder job executed
first builder job executed [message #514722] Tue, 16 February 2010 13:24 Go to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
I am happy to announce that the very first b3 Builder job was just executed!
(And in case you wonder - no, it did not do much :)
- henrik
Re: first builder job executed [message #514738 is a reply to message #514722] Tue, 16 February 2010 13:50 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Henrik, hello builder,
that's great news!
Can you provide some more information about this builder job? What did
you have to do? What did you achtually build?
- Sebastian
Am 16.02.10 14:24, schrieb Henrik Lindberg:
> executed!
> Regards
> - henrik
Re: first builder job executed [message #514794 is a reply to message #514738] Tue, 16 February 2010 11:34 Go to previous messageGo to next message
Hi Sebastian,
Short answer - the builder that was executed was just test code - it
returned a fixed build result (a .txt file).
Longer answer - B3 has the notion of BuildUnit (the thing you are
building), and Builder the thing that operates on a BuildUnit to produce
some result.
A Builder is an asynchronous function with declarative dependencies on
other Builders (i.e. other build results from other BuildUnits).
When calling a Builder, it returns an Eclipse Job. When this job is run,
it collects the result of all the declarative dependencies and executes
its specific build step.
My first run (using a toy example) managed to run one of these builders.
Here is (part of) the toy model in b3 DSL:
unit fruitsallad version 1.0.0 {
builder make {
input {
unit/apple/1.0.0#dice;
unit/banana/1.0.0#dice;
unit/orange/1.0.0#dice;
unit apple version 1.0.0 implements Fruit {
builder peel {
output { applepeel.txt; }
builder seeds {
output { appleseeds.txt; }
builder pulp {
output { applepulp.txt; }
Will write a lot more about how this all works once I have it working...
- henrik
> that's great news!
> - Sebastian
>> executed!
>> Regards
>> - henrik
Re: first builder job executed [message #596246 is a reply to message #514722] Tue, 16 February 2010 13:50 Go to previous messageGo to next message
that's great news!
- Sebastian
> executed!
> Regards
> - henrik
Re: first builder job executed [message #596249 is a reply to message #514738] Tue, 16 February 2010 16:23 Go to previous message
Hi Sebastian,
some result.
builder make {
input {
builder peel {
builder seeds {
builder pulp {
- henrik
> that's great news!
> - Sebastian
>> executed!
>> Regards
>> - henrik
Previous Topic:first builder job executed
Next Topic:Aggregator documentation on wiki
Current Time: Mon May 21 09:18:15 GMT 2018
Powered by FUDForum. Page generated in 0.02049 seconds
