Home » Eclipse Projects » Linux Tools Project » C++ Unit Testing Framework( C++ Unit Testing Framework)
C++ Unit Testing Framework [message #513592] Wed, 10 February 2010 11:19 Go to next message
Rob  is currently offline Rob
I am investigating which C++ Unit Testing Framework to use in my project.
Is there a plan to add a C++ Unit Testing Framework to the Linux Tools Project?
If so, which one?
Rob
Re: C++ Unit Testing Framework [message #513621 is a reply to message #513592] Wed, 10 February 2010 12:27 Go to previous messageGo to next message
Jeff Johnston is currently offline Jeff Johnston
There are no current plans to release a C++ unit testing framework via the Linux tools project.
There used to be cppunit that was part of the CDT. It languished for a while and was later shipped in Fedora's eclipse-cdt but this was stopped as of release 5.0.0 (we are at 6.0.1 at the moment). If cppunit is what you are looking for, you might want to consider opening an RFE against the upstream CDT or Linux tools or if you use the Fedora eclipse-cdt package, against Fedora eclipse-cdt.
Re: C++ Unit Testing Framework [message #514030 is a reply to message #513592] Fri, 12 February 2010 04:01 Go to previous messageGo to next message
Eclipse User
Originally posted by: mikael.springer.clearit.se
Take a look at the ECUT eclipse plugin. I use it myself together with
CppUnit, it works fine.
Regards, Micke.
> Project?
> If so, which one?
> Rob
Re: C++ Unit Testing Framework [message #515414 is a reply to message #514030] Thu, 18 February 2010 12:30 Go to previous messageGo to next message
I tried using the ECUT pulgin with Eclipse 3.5.1 but I had trouble making it work and I could not find any documentation on it. Then I found the CUTE (Cute C++ Unit Testing Easier ) plugin that had examples and some documentation. So far I am leaning towards using CUTE. If you are interested you can find CUTE information at the following sites.
http://marketplace.eclipse.org/content/cute-c-unit-testing-e asier
http://ifs.hsr.ch/Projects/Projects/Cute
Rob
Re: C++ Unit Testing Framework [message #568385 is a reply to message #514030] Thu, 18 February 2010 12:30 Go to previous message
Rob
Previous Topic:C++ Unit Testing Framework
Next Topic:Using autotools & valgrind for compiling an R library
Current Time: Sat May 25 14:00:50 EDT 2013
Powered by FUDForum. Page generated in 0.02184 seconds
