Home » Archived » M2M (model-to-model transformation) » [ATL] Cannot copy attribute types
[ATL] Cannot copy attribute types [message #513458] Wed, 10 February 2010 10:09 Go to next message
RJ is currently offline RJFriend
Hi all,
I'm still trying to do model transformations on metamodels, first starting by just simply copying a metamodel, through ATL. I have a very simple metamodel, with just one class, containing one attribute, with type EString:
<ecore:EPackage xmi:version="2.0"
    xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="test"
    nsURI="test" nsPrefix="test">
  <eClassifiers xsi:type="ecore:EClass" name="testClass">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="ID" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
  </eClassifiers>
</ecore:EPackage>
However, when I run my ATL transformation, the type of the attribute just seems to disappear:
<?xml version="1.0" encoding="ISO-8859-1"?>
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="testOutput"
    nsURI="testOutput" nsPrefix="testOutput">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="ID">
      <eType xsi:type="ecore:EDataType" href="http://www.eclipse.org/emf/2002/Ecore#//EJavaObject"/>
    </eStructuralFeatures>
  </eClassifiers>
</ecore:EPackage>
It looks like ATL cannot handle the ecore datatypes of something like that. What am I missing here. For completeness sake, here is the transformation I use. It may look long, but all it does is copy the source metamodel 1-on-1 to the target metamodel. (note that I removed the irrelevant parts of the transformation. I fact, I have a rule for all classes of the Ecore meta-metamodel)
-- @path MM=platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore
-- @path MM2=platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore
module merge;
create InstMM : MM2 from AbstMM : MM;
rule copyEPackage{
	from
		a : MM!EPackage
	to
		p : MM2!EPackage(
			eClassifiers <- a.eClassifiers,
			name <- 'testOutput',
			nsURI <- 'testOutput',
			nsPrefix <- 'testOutput',
			eAnnotations <- a.eAnnotations,
			eFactoryInstance <- a.eFactoryInstance,
			eSubpackages <- a.eSubpackages
rule copyEClass{
	from
		a : MM!EClass
	to
		p : MM2!EClass(
			abstract <- a.abstract,
			name <- a.name,
			eGenericSuperTypes <- a.eGenericSuperTypes,
			eOperations <- a.eOperations,
			eStructuralFeatures <- a.eStructuralFeatures,
			--eSuperTypes <- a.eSuperTypes,
			eTypeParameters <- a.eTypeParameters,
			instanceClassName <- a.instanceClassName,
			instanceTypeName <- a.instanceTypeName,
			interface <- a.interface
rule copyEGenericType{
	from
		a : MM!EGenericType
	to
		p : MM2!EGenericType(
			eClassifier <- a.eClassifier,
			eLowerBound <- a.eLowerBound,
			eTypeArguments <- a.eTypeArguments,
			eTypeParameter <- a.eTypeParameter,
			eUpperBound <- a.eUpperBound
rule copyEDataType{
	from
		a : MM!EDataType (a.oclIsTypeOf(MM!EDataType))
	to
		p : MM2!EDataType(
			name <- a.name,
			serializable <- a.serializable
rule copyEReference{
	from
		a : MM!EReference
	to
		p : MM2!EReference(
			changeable <- a.changeable,
			containment <- a.containment,
			defaultValueLiteral <- a.defaultValueLiteral,
			derived <- a.derived,
			eGenericType <- a.eGenericType,
			eKeys <- a.eKeys,
			eOpposite <- a.eOpposite,
			eType <- a.eType,
			lowerBound <- a.lowerBound,
			name <- a.name,
			ordered <- a.ordered,
			resolveProxies <- a.resolveProxies,
			transient <- a.transient,
			unique <- a.unique,
			unsettable <- a.unsettable,
			upperBound <- a.upperBound,
			volatile <- a.volatile
rule copyEAttribute{
	from
		a : MM!EAttribute
	to
		p : MM2!EAttribute(
			eType <- a.eType,
			name <- a.name,
			unique <- a.unique,
			volatile <- a.volatile,
			iD <- a.iD
rule copyETypeParameter{
	from
		a : MM!ETypeParameter
	to
		p : MM2!ETypeParameter(
			eBounds <- a.eBounds,
			name <- a.name
rule copyEFactory{
	from
		a : MM!EFactory
	to
		p : MM2!EFactory(
			ePackage <- a.ePackage
rule copyEObject{
	from
		a : MM!EObject (a.oclIsTypeOf(MM!EObject))
	to
		p : MM2!EObject(
Re: [ATL] Cannot copy attribute types [message #513471 is a reply to message #513458] Wed, 10 February 2010 10:38 Go to previous messageGo to next message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARDFriend
Comment :
in the Attribute rule and it will work
Re: [ATL] Cannot copy attribute types [message #513475 is a reply to message #513471] Wed, 10 February 2010 10:48 Go to previous messageGo to next message
Tnx for the suggestion, but unfortunately, it doesn't help. Then I get:
<xmi:XMI xmi:version="2.0"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
  <ecore:EPackage name="testOutput" nsURI="testOutput" nsPrefix="testOutput">
      <eStructuralFeatures xsi:type="ecore:EAttribute" name="ID"/>
    </eClassifiers>
  </ecore:EPackage>
  <ecore:EGenericType/>
</xmi:XMI>
It just leaves out the type entirely. Also note that for some reason, the layout of the EPackage changed.
[Updated on: Wed, 10 February 2010 10:51]
Report message to a moderator
Re: [ATL] Cannot copy attribute types [message #513480 is a reply to message #513458] Wed, 10 February 2010 06:16 Go to previous messageGo to next message
Alfons Laarman is currently offline Alfons LaarmanFriend
Member
Hi RJ,
This I got from an earlier post from William Piers:
When you use Ecore as metamodel, you have to mention in the launch
configuration that it is a metametamodel (using the ismetametamodel
checkbox near the Ecore metamodel declaration), in order to prevent
loading issues like yours which may happen if Ecore metamodel is loaded
several times.
The checkbox make ATL consider an unique instance of this Resource.
HTH,
Alfons
On 2/10/10 11:09 AM, in article hku0lm$463$1@build.eclipse.org, "RJ"
<r.j.bijl@gmail.com> wrote:
> Hi all,
> </eClassifiers>
> </ecore:EPackage>
> seems to disappear:
> </eClassifiers>
> </ecore:EPackage>
> meta-metamodel)
> module merge;
> rule copyEPackage{
> from
> a : MM!EPackage
> to
> p : MM2!EPackage(
> rule copyEClass{
> from
> a : MM!EClass
> to
> p : MM2!EClass(
> name <- a.name,
> from
> a : MM!EGenericType
> to
> rule copyEDataType{
> from
> to
> p : MM2!EDataType(
> name <- a.name,
> from
> a : MM!EReference
> to
> p : MM2!EReference(
> eKeys <- a.eKeys,
> eType <- a.eType,
> name <- a.name,
> unique <- a.unique,
> from
> a : MM!EAttribute
> to
> p : MM2!EAttribute(
> eType <- a.eType,
> name <- a.name,
> unique <- a.unique,
> iD <- a.iD
> from
> to
> name <- a.name
> rule copyEFactory{
> from
> a : MM!EFactory
> to
> p : MM2!EFactory(
> rule copyEObject{
> from
> to
> p : MM2!EObject(
Re: [ATL] Cannot copy attribute types [message #513561 is a reply to message #513475] Wed, 10 February 2010 15:06 Go to previous messageGo to next message
Dennis Hendriks is currently offline Dennis HendriksFriend
Member
RJ wrote on Wed, 10 February 2010 11:48
I'm trying to the same thing as the original poster, and have the same problem: references to types declared in different ecores (like EString from Ecore or Boolean from XMLType) are lost in the output, they remain Void (in ATL debugger), and end up being EJavaObject (which I suppose is some kind of default).
Setting the 'ecore' as metametamodel in the launch configuration is something I already did. It has no effect.
Does anyone know how to make ATL aware of the external ecores, so that we can include references to them, and thus not lose that information?
Re: [ATL] Cannot copy attribute types [message #513780 is a reply to message #513458] Thu, 11 February 2010 04:50 Go to previous messageGo to next message
William Piers is currently offline William PiersFriend
--------------030108010802030400050101
Content-Type: text/plain; charset=UTF-8; format=flowed
As Ecore datatypes are defined into the Ecore metamodel, what you do is
a reference between the Ecore output and the Ecore metamodel. So you
have to check the inter-model references checkbox in the launch
configuration (Advanced tab).
William
Le 10/02/2010 11:09, RJ a écrit :
> Hi all,
> type EString:
> </eClassifiers>
> </ecore:EPackage>
> </eClassifiers>
> </ecore:EPackage>
> module merge;
> rule copyEPackage{
> from
> a : MM!EPackage
> to
> p : MM2!EPackage(
> rule copyEClass{
> from
> a : MM!EClass
> to
> p : MM2!EClass(
> name <- a.name,
> from
> a : MM!EGenericType
> to
> rule copyEDataType{
> from
> to
> p : MM2!EDataType(
> name <- a.name,
> from
> a : MM!EReference
> to
> p : MM2!EReference(
> eKeys <- a.eKeys,
> eType <- a.eType,
> name <- a.name,
> unique <- a.unique,
> from
> a : MM!EAttribute
> to
> p : MM2!EAttribute(
> eType <- a.eType,
> name <- a.name,
> unique <- a.unique,
> iD <- a.iD
> from
> to
> name <- a.name
> rule copyEFactory{
> from
> a : MM!EFactory
> to
> p : MM2!EFactory(
> rule copyEObject{
> from
> to
> p : MM2!EObject(
Ne manquez pas notre prochaine formation ATL inter entreprises:
ATL - Paris - du 2 au 3 Décembre 2009
Pour plus de dates et pour le détail de cette formation:
http://www.obeo.fr/pages/formations/fr
Don't forget our next ATL training:
ATL - Paris - 2009 December from 2th to 3th
More dates and training program on:
Content-Type: text/x-vcard; charset=utf-8;
name="william_piers.vcf"
Content-Disposition: attachment;
filename="william_piers.vcf"
YmVnaW46dmNhcmQNCmZuOldpbGxpYW0gUGllcnMNCm46UGllcnM7V2lsbGlh bQ0Kb3JnOk9i
ZW8NCmFkcjoyIHJ1ZSBSb2JlcnQgU2NodW1hbm47O2xvdCAyNDtOQU5URVM7 OzQ0NDA4O0Zy
YW5jZQ0KZW1haWw7aW50ZXJuZXQ6d2lsbGlhbS5waWVyc0BvYmVvLmZyDQp0 aXRsZTpNREEg
Q29uc3VsdGFudA0KdGVsO3dvcms6KzMzICgwKTIgNTEgMTMgNTAgNTMNCnVy bDpodHRwOi8v
d3d3Lm9iZW8uZnINCnZlcnNpb246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------030108010802030400050101--
Re: [ATL] Cannot copy attribute types [message #513791 is a reply to message #513780] Thu, 11 February 2010 10:31 Go to previous messageGo to next message
Member
William Piers wrote on Thu, 11 February 2010 05:50
William
Thanks! This works perfectly!
Re: [ATL] Cannot copy attribute types [message #513810 is a reply to message #513780] Thu, 11 February 2010 11:37 Go to previous message
I second that.
Thanks a lot Smile
Previous Topic:[Announce] Eclipse/OMG Symposium 2010
Next Topic:[QVTO] editor locks up when code assist box should show
Current Time: Sat May 26 23:48:07 GMT 2018
Powered by FUDForum. Page generated in 0.02281 seconds
