Home » Modeling » EMF » Persisting loaded resources across two models - pathmap is lost
Persisting loaded resources across two models - pathmap is lost [message #513171] Tue, 09 February 2010 03:48 Go to next message
Johannes Gross is currently offline Johannes GrossFriend
This is an UML2 problem but it seems to adress the emf-resource plugins.
I have an UML-model and i load other UML-models via a pathmap-reference.
The problem occurs, if i have:
Model A Model B Model C
instance of inherits from
InstanceSpec. A -------- Class B --------------- Class C
if now Model A is persisted, the references in Model B to Model C
change from e.g.:
href=" pathmap://TEST/Case/C/Test100202C.uml#_PQ2FQBAYEd-Bf7DSqLsGu Q"
to
href="../C/Test100202C.uml#_PQ2FQBAYEd-Bf7DSqLsGuQ"
The URI-mappings (pathmap://TEST/Case/C/ = C:\data\home\ws\Test100202C)
are put to
SharedResourceSetUtil.getSharedResourceSet().getURIConverter ().getURIMap()
and
URIConverter.URI_MAP
for test reasons, but it doesnt help. (I m not sure which map is the
right one).
Any pointers on this are appreciated!
Johannes
Re: Persisting loaded resources across two models - pathmap is lost [message #513211 is a reply to message #513171] Tue, 09 February 2010 11:34 Go to previous messageGo to next message
--------------050604040205030104010907
Johannes,
Comments below.
J. Gro
Re: Persisting loaded resources across two models - pathmap is lost [message #513255 is a reply to message #513211] Tue, 09 February 2010 14:33 Go to previous message
Ed, thank you for your quick help.
I have now built my own URIHandler which doesnt deresolve the relative
paths. This seems to work quite well.
Ed Merks schrieb:
> Johannes,
> Comments below.
>> pathmap-reference. The problem occurs, if i have:
>> change from e.g.:
>> to
> If a resource X with absolute URI x contains a reference to another
> resource Y with absolute URI y, and it's possible to create a relative
> path between x and y, then a relative path will be serialized.
>> are put to
>> and
>> right one).
> URI mappings are used only to open a stream for the resource's actual
> URI x. They have no impact on the name used for serialization, which is
> determined purely from the actual URI of the resource.
> You could use this XMLResource option to gain more control:
> * A {@link URIHandler} value that will be used to control how
> URIs are {@link URI#resolve(URI) resolved} during load
> * and {@link URI#deresolve(URI) deresolved} during save.
> * @see URI
> * @see URIHandler
> * @see XMLHelper#resolve(URI, URI)
> * @see XMLHelper#deresolve(URI)
> * @see URIHandlerImpl
> String OPTION_URI_HANDLER = "URI_HANDLER";
>> Thanks,
>> Johannes
Previous Topic:[EMF CDO] Undo adding first object to a list throws ArrayIndexOutOfBoundsException
Next Topic:Appropriate to use XMI for persistence?
Current Time: Tue May 22 16:09:34 GMT 2018
Powered by FUDForum. Page generated in 0.01528 seconds
