Home » Eclipse Projects » SWTBot » TreeItem.pressShortcut() stopped working(TreeItem.pressShortcut() stopped working after build version 2.0.0.433)
TreeItem.pressShortcut() stopped working [message #513132] Tue, 09 February 2010 01:56 Go to next message
Brian Yu is currently offline Brian YuFriend
Hi all,
I had this piece of code with a TreeItem calling a shortcut key, but now I am getting an exception when working with build versions after 2.0.0.433.
What this code does is it selects a tree item from the Eclipse Properties view and opens up a property dialog by simulating the Enter key being hit on this property item:
MyBot.tree().getTreeItem("ParentItem").select("ChildItem" ).pressShortcut(Keystrokes.LF).pressShortcut(Keystrokes.LF);
After upgrading to a later version, I am consistently getting the following exception:
org.eclipse.swtbot.swt.finder.widgets.TimeoutException: Timeout after: 5000 ms.: The widget TreeItem with text {TreeItem {ChildItem}} was not enabled.
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:398)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:372)
at org.eclipse.swtbot.swt.finder.SWTBotFactory.waitUntil(SWTBot Factory.java:360)
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.waitFor Enabled(AbstractSWTBot.java:609)
at org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot.pressSh ortcut(AbstractSWTBot.java:856)
Any thoughts on what may be going on or workarounds?
Brian
Re: TreeItem.pressShortcut() stopped working [message #513143 is a reply to message #513132] Mon, 08 February 2010 22:28 Go to previous messageGo to next message
Ketan Padegaonkar is currently offline Ketan PadegaonkarFriend
Hi Brian,
This is a regression that slipped in because of bug 299201. I've fixed
this in trunk immediately.
Would it be OK if I push the next build this weekend, so that I can
spend some time on testing things.
Cheers!
-- Ketan
On 2/8/10 5:56 PM, Brian Yu wrote:
> Hi all,
> enabled.
> Factory.java:398)
> Factory.java:372)
> Factory.java:360)
> Brian
Re: TreeItem.pressShortcut() stopped working [message #513342 is a reply to message #513143] Tue, 09 February 2010 19:26 Go to previous messageGo to next message
Great sounds good. Thanks Ketan.
Brian
Re: TreeItem.pressShortcut() stopped working [message #515261 is a reply to message #513143] Thu, 18 February 2010 10:03 Go to previous messageGo to next message
Georgina Lindsey is currently offline Georgina LindseyFriend
Hi Ketan,
Could you let me know when a build including the fix for this issue will be available from the update site? I'm currently using r2.0.0.486 and getting the described errors for TreeItem.pressShortcut().
Georgina
Re: TreeItem.pressShortcut() stopped working [message #515291 is a reply to message #515261] Thu, 18 February 2010 10:49 Go to previous messageGo to next message
Sorry this completely slipped my mind, I'll do that tomorrow first thing.
Cheers!
-- Ketan
On 2/18/10 2:03 AM, Georgina Lindsey wrote:
> Hi Ketan,
> Georgina
Re: TreeItem.pressShortcut() stopped working [message #515803 is a reply to message #515261] Sun, 21 February 2010 04:13 Go to previous message
I've pushed the latest build out and it's available on the downloads
page on swtbot.
Enjoy!
-- Ketan
On 2/18/10 3:33 PM, Georgina Lindsey wrote:
> Hi Ketan,
> Georgina
Previous Topic:Renaming a node in a tree
Next Topic:SWTBotMenu
Current Time: Mon Jun 25 17:42:03 GMT 2018
Powered by FUDForum. Page generated in 0.02229 seconds
