Home » Modeling » TMF (Xtext) » Content assist and caracter encoding
Content assist and caracter encoding [message #512711] Sat, 06 February 2010 17:35 Go to next message
Michel Simeon is currently offline Michel SimeonFriend
I am working on content assist by defining a number of strings in <my language>ProposalProvider.
If the string includes say the word "données" , then upon ctrl-space the editor will display \u00E9 for the é.
Is there a way to change that?
Thanks for support
MS
Re: Content assist and caracter encoding [message #512731 is a reply to message #512711] Sat, 06 February 2010 20:28 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Michel,
I guess you have to override the STRING conversion in your value
converter. That should do the trick.
If you currently do not have an own value converter, please inherit from
DefaultTerminalConverters and bind your own implementation in you
runtime module to the IValueConverterService.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 06.02.10 18:35, schrieb Michel Simeon:
> Thanks for support
> MS
Re: Content assist and caracter encoding [message #513612 is a reply to message #512731] Wed, 10 February 2010 17:09 Go to previous messageGo to next message
[quote title=Sebastian Zarnekow wrote on Sat, 06 February 2010 15:28]Hi Michel,
Sebastian
I have created my own value converter ( i needed one anyway). I actually copied the STRING conversion from DefaultTerminalConverters, and called a modified version of convertToJavaString, where the default switch case does not recreate the \uxxxx notation as in the original.
So my question is: what is the rationale for doing it that way ? Also, why are Default Terminals so limited, would not it be usefull to include floating point numbers or negative integers ?
MS
Re: Content assist and caracter encoding [message #513802 is a reply to message #513612] Thu, 11 February 2010 11:17 Go to previous messageGo to next message
Hi Michael,
the value converter will automatically delegate to the EcoreFactory for
datatypes without an explicit conversion rule. Floats, Doubles, Dates
etc should work out of the box this way.
We decided to limit the default terminal rules to a reasonable set of
commonly used tokens. That's why there is no floating point number and
no signed integer rule. However, if you create your own data type or
terminal rule and do not create a converter for it, the default emf
based conversion will be used, e.g.
SignedInt return EInt:
('+'|'-')? INT;
should work. Note that this functionality has been added in the latest
milestone of the 0.8.0 stream.
Sebastian
Am 10.02.10 18:09, schrieb Michel Simeon:
> Regards
> MS
Re: Content assist and caracter encoding [message #513929 is a reply to message #513802] Thu, 11 February 2010 17:13 Go to previous messageGo to next message
[quote title=Sebastian Zarnekow wrote on Thu, 11 February 2010 06:17]Hi Michael,
('+'|'-')? INT;
Sebastian
Thank you for the clarification. I has indeed defined my own SignedInt and Float rules together with corresponding value converters, and checked that I could do without those value converters.
MS
Re: Content assist and caracter encoding [message #514017 is a reply to message #513929] Fri, 12 February 2010 07:40 Go to previous messageGo to next message
Hallvard Traetteberg is currently offline Hallvard TraettebergFriend
Follow-up question:
I need to define a rule for URIs and believe it can be done as follows:
- define URI datatype in my domain model
- generate and implement the createFromString and convertToString in the
factory
- define a terminal rule that return the datatype
Is this correct, i.e. will the parser use the factory methods? How
should I signal syntax errors in the createFromString method, so it is
picked up by the parser (in case the terminal rule isn't tight enough)?
Hallvard
Re: Content assist and caracter encoding [message #514024 is a reply to message #514017] Fri, 12 February 2010 09:03 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven EfftingeFriend
>> for datatypes without an explicit conversion rule. Floats, Doubles,
>> Dates etc should work out of the box this way.
> Follow-up question:
> factory
Yes, as long as you use 0.8.0 >= M4.
> How
Errors which occur during value conversion can be reported by throwing a
org.eclipse.xtext.conversion.ValueConverterException.
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: Content assist and caracter encoding [message #514127 is a reply to message #514024] Fri, 12 February 2010 09:16 Go to previous messageGo to next message
>> Follow-up question:
>> the factory
>> How should I signal syntax errors in the createFromString method, so
>> it is picked up by the parser (in case the terminal rule isn't tight
>> enough)?
The URI class throws an IllegalArgumentException, so from what you write
I need to wrap it in a ValueConverterException. It doesn't seem right to
do this in the Factory, after all it should be independent of Xtext.
Hence, I have to create an Xtext value converter after all? Wouldn't it
make sense to catch all RuntimeExceptions and treat them as
ValueConverterExceptions?
Hallvard
Re: Content assist and caracter encoding [message #514136 is a reply to message #514127] Fri, 12 February 2010 14:48 Go to previous message
Hi Hallvard,
you wouldn't like the error message "IllegalArgumentException: ..." in
your editor, would you? Furthermore, RuntimeExceptions usually indicate
programming errors and that's why we should not catch those.
Sebastian
Am 12.02.10 15:08, schrieb Hallvard Trætteberg:
>>> Follow-up question:
>>> the factory
>>> enough)?
>> a org.eclipse.xtext.conversion.ValueConverterException.
> Hallvard
Previous Topic:Referencing 'internal' objects
Next Topic:strange duplication check
Current Time: Mon May 21 17:15:22 GMT 2018
Powered by FUDForum. Page generated in 0.02371 seconds
