Home » Modeling » TMF (Xtext) » Xtext 0.8.0 M5 generates not compilable code
Xtext 0.8.0 M5 generates not compilable code [message #512557] Fri, 05 February 2010 08:31 Go to next message
Esteban Dugueperoux is currently offline Esteban Dugueperoux
Previously using Xtext M4, I have decided to update my target platform
to Helios M5 with Xtext M5 but when I reexecute my MWE workflow, I have
a compilation error. Indeed, "lastConsumedDatatypeToken = current;" is
generated in my InternalDSLParser but without the corresponding
lastConsumedDatatypeToken attribute.
My MWE workflow have been executed without problems and I have correclty
installed antlr plugin from itemis website.
Tested under Linux, with two grammars :
- the MyDSL example provided at Xtext project creation
- and with my grammar at
http://gforge.inria.fr/plugins/scmsvn/viewcvs.php/trunk/v1/p lugins/fr.inria.adam.calico.models.interface.edit.textual/mo dels/fr/inria/adam/calico/models/interface_/edit/textual/?ro ot=calico
Thanks and regards.
Re: Xtext 0.8.0 M5 generates not compilable code [message #512586 is a reply to message #512557] Fri, 05 February 2010 09:30 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian Zarnekow
Hi Esteban,
please ensure that you use the current version of the feature
de.itemis.xtext.antlr. The version qualifier of the plugin is a good
indicator if the Antlr feature matches the installed Xtext version.
Hope that helps,
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 05.02.10 14:31, schrieb Esteban DUGUEPEROUX:
> Thanks and regards.
Re: Xtext 0.8.0 M5 generates not compilable code [message #512852 is a reply to message #512586] Mon, 08 February 2010 03:15 Go to previous message
Hum I used the incorrect itemis update site. It works now with the
itemis milestone update site.
Thanks.
Sebastian Zarnekow wrote:
> Hi Esteban,
> Hope that helps,
> Sebastian
Previous Topic:[Xtext] How to add a quickfix for creating a referenced model which doesn't exist
Next Topic:Serialization of models and syncing with Eclipse GUI
Current Time: Fri May 24 21:18:26 EDT 2013
Powered by FUDForum. Page generated in 0.01619 seconds
