Home » Eclipse Projects » Remote Application Platform (RAP) » UICallBack mechanism
UICallBack mechanism [message #512533] Fri, 05 February 2010 11:53 Go to next message
Erdal Karaca is currently offline Erdal KaracaFriend
I tried UICallBack.activate/deactivate, but that does not seem to work in this case:
// in a background job:
doSomething();
notifyListeners(display)
// the listener:
display.asyncExec( new Runnable() {
public void run() {
String uuid = UUID.randomUUID().toString();
UICallBack.activate(uuid);
updateUI();
UICallBack.deactivate(uuid);
A background job must notify its listeners that it has finished. Now, in the listener I want to update the ui. When using activate/deactivate, I have this problem: ui is not refreshed until I click somewhere.
Am I right, that I have to call UICallBack.activate before the background job starts and UICallBack.deactive when it has finished?
How to do this if I do not know where the background job is started or if the background job is started somewhere I have no access to?
Re: UICallBack mechanism [message #512880 is a reply to message #512533] Mon, 08 February 2010 04:42 Go to previous message
Rüdiger Herrmann is currently offline Rüdiger HerrmannFriend
> in this case:
> doSomething();
> // the listener:
> public void run() {
> updateUI();
You are right, the UICallback must be activated from within the
UI-Thread (i.e. while a "normal" request is running) *before* the
background thread needs to update the UI.
You could start the UICallback "well ahead" (e.g. at session startup) at
the cost of having an extra request that is blocked at the server while
the UICallback is active.
Another approach could be to write some custom Javascript that polls the
server for updates.
Depending on your actual use case there might be other options - feel
free to share...
Previous Topic:[ANN] RAP 1.3 M5 is available
Next Topic:[Dialog] L&F 1.3M5
Current Time: Fri Feb 23 16:46:24 GMT 2018
Powered by FUDForum. Page generated in 0.01544 seconds
