Home » Eclipse Projects » Eclipse 4 » Setting the input on a dynamically opened part.(First post was updated!)
Setting the input on a dynamically opened part. [message #511703] Tue, 02 February 2010 15:34 Go to next message
Jens Keller is currently offline Jens KellerFriend
Member
Updates:
- You don't need to define a variable in the Application.e4xmi, it also works without it
- Declare the variable as modifiable to change it multiple times
- You don't need to find the newly opened part because showPart() returns it directly
This time no question and instead a little tutorial on setting the input data on a newly openend part descriptor.
See this thread for a way to open a part descriptor at runtime.
First you need to define a variable in your Application.e4xmi which is used to pass the part input.
<variables>input</variables>
Then you can use the IEclipseContext to modify and read this variable.
PartToOpen.INPUT_VARIABLE_NAME = "input";
IEclipseContex.modify( PartToOpen.INPUT_VARIABLE_NAME, inputObject );
IEclipseContext.get( PartToOpen.INPUT_VARIABLE_NAME );
This means in detail:
Find and open the part descriptor and use the context of the newly
opened part to modify the variable. You need to declare it modifiable
if you want to change the variable multiple times (for changing the input
of the part):
for( MPartDescriptor partDesc : desc ){
if( partDesc.getId().equals( PartToOpen.ID ) ){
MPart part = servicePart.showPart( partDesc.getId() );
part.getContext().modify( PartToOpen.INPUT_VARIABLE_NAME, partInput );
part.getContext().declareModifiable( PartToOpen.INPUT_VARIABLE_NAME );
break;
And now the following method in the part should get called:
@Inject
@Optional
public void setPartInput( @Named( "input" ) Object partInput ) { ... }
For more information you can look in the e4 photo demo ( in Libray.java at line 117 the variable
is modified to promote the actual selected photo to the other parts which implement a setSelection() method)
or this eclipsepedia article.
[Updated on: Wed, 03 February 2010 08:43]
Report message to a moderator
Re: Setting the input on a dynamically opened part. [message #511724 is a reply to message #511703] Tue, 02 February 2010 16:29 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Maybe you want to start a wiki-page documenting little snippets with
code so that people can be pointed there always?
Tom
Am 02.02.10 16:34, schrieb Jens Keller:
> data on a newly openend part descriptor. See
> http://www.eclipse.org/forums/index.php?t=msg&th=160958& amp;start=0& thread
> IEclipseContex.modify( "input", inputObject );
> IEclipseContext.get( "input" );
> Open the part descriptor:
> EPartService.showPart( partDescriptor.getID() );
> Find the newly opened part and use it's IEclipseContext to modify the
> variable:
> Collection<MPart> col = servicePart.getParts();
> for(MPart part : col){
> if( part.getId().equals(
> partDescriptor.getID() ) ){
> part.getContext().modify( "input",
> partInput );
> break;
> @Inject
> @Optional
> at line 117 the variable is modified to promote the actual selected
> photo to the other parts which implement a setSelection() method) or
> http://wiki.eclipse.org/E4/EAS/Selection eclipsepedia article.
Re: Setting the input on a dynamically opened part. [message #511841 is a reply to message #511724] Wed, 03 February 2010 08:31 Go to previous messageGo to next message
Member
That's a good idea and we should ask in the forum if others also want to share their knowledge, because i'm also interested in practical tips on working with e4. Do you know a place to host the wiki-page?
Jens Keller
Re: Setting the input on a dynamically opened part. [message #511847 is a reply to message #511841] Wed, 03 February 2010 03:44 Go to previous messageGo to next message
http://wiki.eclipse.org/E4/Snippets and link it from
http://wiki.eclipse.org/E4#Tutorial
Tom
Am 03.02.10 09:31, schrieb Jens Keller:
> Jens Keller
Re: Setting the input on a dynamically opened part. [message #511855 is a reply to message #511847] Wed, 03 February 2010 09:10 Go to previous messageGo to next message
Member
I added the link to the snippets wiki and now i'm preparing my first snippet. But i'm not sure about the structure of the wiki. Should i just start adding snippets through links on the main page?
Re: Setting the input on a dynamically opened part. [message #511870 is a reply to message #511855] Wed, 03 February 2010 09:55 Go to previous messageGo to next message
Am 03.02.10 10:10, schrieb Jens Keller:
I would not create a new page for each snippet but create sections on
the Snippet pages.
With:
a) Description about the Snippet (2 - n sentences)
b) The Java-Code, EMF-"Code"
Similar to http://wiki.eclipse.org/Platform_Command_Framework
Tom
Re: Setting the input on a dynamically opened part. [message #511896 is a reply to message #511870] Wed, 03 February 2010 11:03 Go to previous messageGo to next message
Member
I added two snippets.
Re: Setting the input on a dynamically opened part. [message #512431 is a reply to message #511896] Fri, 05 February 2010 06:04 Go to previous message
Lars Vogel Unavailable until 15 August 2016 is currently offline Lars Vogel Unavailable until 15 August 2016Friend
Hello Jens,
thank you for sharing your experience. Very much appreciated!
Cheers, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Re: Setting the input on a dynamically opened part. [message #568317 is a reply to message #511724] Wed, 03 February 2010 08:31 Go to previous message
Member
Jens Keller
Re: Setting the input on a dynamically opened part. [message #568326 is a reply to message #568317] Wed, 03 February 2010 08:39 Go to previous message
Tom
> Jens Keller
Re: Setting the input on a dynamically opened part. [message #568347 is a reply to message #568326] Wed, 03 February 2010 09:10 Go to previous message
Member
Re: Setting the input on a dynamically opened part. [message #568361 is a reply to message #568347] Wed, 03 February 2010 09:55 Go to previous message
the Snippet pages.
With:
Tom
Re: Setting the input on a dynamically opened part. [message #568391 is a reply to message #511870] Wed, 03 February 2010 11:03 Go to previous message
Member
Re: Setting the input on a dynamically opened part. [message #568545 is a reply to message #568391] Fri, 05 February 2010 06:04 Go to previous message
Hello Jens,
Cheers, Lars
Previous Topic:Remote javascript debugger
Next Topic:New e4 snippets wiki-page
Current Time: Wed May 23 13:18:49 GMT 2018
Powered by FUDForum. Page generated in 0.01972 seconds
