Home » Eclipse Projects » EGit » Importing projects
Importing projects [message #511395] Mon, 01 February 2010 09:21 Go to next message
Wim Jongman is currently offline Wim Jongman
Is it possible to import projects from an existing local repository. The
wizard is already there but it seems to be a page of the import repository
wizard.
Best Regards,
Wim Jongman
-- Press CTRL-ALT-DEL to continue ...
(Eclipse Old Skool Quote Service)
Re: Importing projects [message #511506 is a reply to message #511395] Mon, 01 February 2010 14:34 Go to previous messageGo to next message
Robin Rosenberg is currently offline Robin Rosenberg
Either clone the local repo. Enter a URL of the form file:PATH, or use the Import Existing Projects wizard.
Re: Importing projects [message #515235 is a reply to message #511506] Wed, 17 February 2010 23:32 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven Efftinge
I've cloned our git repository from http://git.softeys.de/p/tmf.xtext.git
It contains a couple of projects in the typical Eclipse layout (tests,
plugins and features are in dedicated folders). When importing that
repostiory no projects are found (I assume that's because they are
nested too deep within the repository).
When using the standard "Import Existing Projects" the imported projects
afterwards the imported projects are not connected to the repository.
Am I doing something wrong, or is it a known limitation?
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: Importing projects [message #515236 is a reply to message #515235] Wed, 17 February 2010 23:32 Go to previous messageGo to next message
We have a .project file in the root, which caused the described
behavior. Also using the share wizard after using the standard import
existing projects wizard worked well.
Sven
> Cheers,
> Sven
Re: Importing projects [message #577161 is a reply to message #511395] Mon, 01 February 2010 14:34 Go to previous messageGo to next message
Re: Importing projects [message #577646 is a reply to message #577161] Thu, 18 February 2010 04:12 Go to previous messageGo to next message
Sven
Re: Importing projects [message #577657 is a reply to message #577646] Thu, 18 February 2010 04:28 Go to previous message
Sven
> Cheers,
> Sven
Previous Topic:Sharing project on MacOS 10.5.8
Next Topic:Linux permissions issue
Current Time: Sat May 25 14:14:13 EDT 2013
Powered by FUDForum. Page generated in 0.01772 seconds
