Home » Language IDEs » ServerTools (WTP) » How to change syntax highlighting colors (for XML & XSD) ?
How to change syntax highlighting colors (for XML & XSD) ? [message #510964] Fri, 29 January 2010 10:36 Go to next message
Ben StoverFriend
Assume I currently editing an XML file.
How can I change the current highlighting colors schema?
How can I export this new XML color schema and import it in another Eclipse installation?
Ben
Re: How to change syntax highlighting colors (for XML & XSD) ? [message #510993 is a reply to message #510964] Fri, 29 January 2010 13:26 Go to previous messageGo to next message
Ian Tewksbury is currently offline Ian TewksburyFriend
Member
Ben wrote on Fri, 29 January 2010 05:36
Window -> Preferences -> XML -> XML Files -> Editor -> Syntax Coloring
Export:
1. File -> Export... -> General -> Preferences
2. Be sure 'Export all' is checked
3. choose a location and press 'Finish'
Import:
1. In your other workspace
2. File -> Import... -> General -> Preferences
3. Choose location from export
4. be sure box to 'Import all' is checked
5. Finish
Blue Skies,
~Ian
Ian Tewksbury
WTP JavaScript Tools
IBM Rational
“When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return.” ~Leonardo da Vinci
[Updated on: Fri, 29 January 2010 13:26]
Report message to a moderator
Re: How to change syntax highlighting colors (for XML & XSD) ? [message #511439 is a reply to message #510993] Mon, 01 February 2010 15:50 Go to previous messageGo to next message
Ben StoverFriend
Thank you.
two more related questons:
1.) But where can I setup editor (monospaced) font?
2.) Is the mentioned export+import procedure
suitable as well for migration of preferences from
Eclipse old to Eclipse new
E.g. from
v3.4->v3.5
or (in future)
v3.5->v3.6
Ben
Re: How to change syntax highlighting colors (for XML & XSD) ? [message #511479 is a reply to message #511439] Mon, 01 February 2010 16:57 Go to previous message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
On the Colors and Fonts preference page, under General/Appearance,
either with the Text Font or the Structured Text Editor Text Font. A
monospaced font should already be the default.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse Web Tools Platform
Previous Topic:Web Module Deployment problem
Next Topic:Archived Update Site?
Current Time: Thu Apr 26 05:59:32 GMT 2018
Powered by FUDForum. Page generated in 0.01807 seconds
