| clause "implements" for a EMF generated class [message #510497] |
Wed, 27 January 2010 11:25  |
Carlos Messages: 52 Registered: September 2009 |
Member |
Hi.
I want to declare a clause "implements" for a class which is regenerated using EMF ecore.
If I change the tag @generated adding NOT, to get the "implements" untouched, the code of the class will not be generated...
But if I leave the tag @generated without NOT, when the code was generated, "implements" will be deleted.
So, have you got any suggestion about this issue?
Thanks in advance,
Carlos.
| Re: clause "implements" for a EMF generated class [message #622056 is a reply to message #510497] |
Wed, 27 January 2010 15:55  |
Ed Merks Messages: 24553 Registered: July 2009 |
Carlos,
There's an @implements tag you can add to the user-doc section to
specify things to be added to the implements clause.
Carlos wrote:
> Hi.
> Thanks in advance,
> Carlos.
FUDForum. Page generated in 0.01637 seconds
