Home » Newcomers » Newcomers » M2_HOME variable(setting variable for pre-existing project)
M2_HOME variable [message #510274] Wed, 27 January 2010 03:28 Go to next message
Brian is currently offline BrianFriend
I need to set a variable in a project that I've loaded into eclipse pointing to the project directory, called M2_HOME. How do I do that?
I read that it will correct this problem:
Description Resource Path Location Type
Unbound classpath variable: 'M2_REPO/junit/junit/3.8.1/junit-3.8.1.jar' in project 'jung-api' jung-api Build path Build Path Problem
Brian
[Updated on: Wed, 27 January 2010 03:55]
Report message to a moderator
Re: M2_HOME variable [message #510275 is a reply to message #510274] Wed, 27 January 2010 04:32 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
On 1/26/2010 8:28 PM, Brian wrote:
> Thanks
> Brian
Usually M2_HOME is an environment variable pointing at something like
~/.m2, C:\Users\brian on Windows 7.
I'm a Maven neophyte and am especially mystified so what I've just said
may not be helpful.
Russ Bateman
Re: M2_HOME variable [message #510549 is a reply to message #510274] Wed, 27 January 2010 19:28 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
On 1/26/10 10:28 PM, Brian wrote:
Most likely that's a Classpath Variable. Open the Preferences and type
"variables" (without the quotes) into the search field at the top.
Hope this helps,
Eric
Previous Topic:Update Login
Next Topic:Question about Combining eclipse versions
Current Time: Fri Jun 22 02:12:07 GMT 2018
Powered by FUDForum. Page generated in 0.02548 seconds
