Home » Newcomers » Newcomers » Edit readonly files(How to get rid of ...)
Edit readonly files [message #509932] Mon, 25 January 2010 19:36 Go to next message
Kitesurfer () is currently offline Kitesurfer ()Friend
Member
I've made a plugin with a custom editor (extends TextEditor).
When I open a readonly-file in this editor, and alter something, a messagebox comes up asking: "File is read-only. Do you wish to make it writable" ... I always click on "No" ... from that time on nothing can be altered in the editor.
How can I get rid of this messagebox and always have the editor in read-only mode when I open a read-only file ?
Re: Edit readonly files [message #541301 is a reply to message #509932] Sat, 19 June 2010 18:18 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
I'm having the same problem.
Did you or anyone else find a solution?
Thanks a lot!
Best regards
Michael
Re: Edit readonly files [message #541314 is a reply to message #541301] Sat, 19 June 2010 21:21 Go to previous messageGo to next message
Member
No I got no reaction at all ... a bit irritating as this is www.eclipse.org
[Updated on: Sat, 19 June 2010 21:22]
Report message to a moderator
Re: Edit readonly files [message #545512 is a reply to message #509932] Thu, 08 July 2010 06:39 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
The message comes from the default file modification validator which is
used for unshared files. The easiest way to change this for your editor
is to use overwrite
org.eclipse.ui.texteditor.AbstractTextEditor.validateState(I EditorInput)
and not call validateState(...) on the extension. Note that you should
only override the case where the file's project is not shared since for
those cases you probably want the validation done by the repository
provider.
HTH
Dani
Re: Edit readonly files [message #673463 is a reply to message #545512] Mon, 23 May 2011 17:47 Go to previous messageGo to next message
Member
I'm at the point implementing this ... so I coded beneath in the editor (which extends AbstractDecoratedTextEditor) :
protected void validateState(IEditorInput newInput)
MessageDialog.openInformation(
null,
"validateState", //$NON-NLS-1$
"in"); //$NON-NLS-1$ //$NON-NLS-2$ //$NON-NLS-3$
Now everytime I change something (f.e. type 'A') in the editor, or save it, I get the messagedialog ... so that's good.
I know how to check if the editted-file is read-only.
But now, how do I prevent that something is changed in the editor(text) (f.e. after typing the 'A') when I'm in validateState ?
Thx.
Re: Edit readonly files [message #673572 is a reply to message #673463] Tue, 24 May 2011 06:59 Go to previous messageGo to next message
Kiran  is currently offline Kiran Friend
I am new to eclipse world, I was using Carbide, which is based on eclipse. I was thinking of creating an extension for it.
Please let me know if there is any way where I can create an extension/plugin so that when I open a file which is readonly, I can handle it instead of the default behaviour? In my case, I should convert the file from readonly to writable, but should also mark it as edited by a source depot tool.
Kindly tell me if this can be done.
Kiran
Re: Edit readonly files [message #673708 is a reply to message #673572] Tue, 24 May 2011 14:12 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
Google is your friend.
You might try vogella.de for help in writing your first plug-in.
> Kiran
Re: Edit readonly files [message #1740562 is a reply to message #509932] Mon, 15 August 2016 17:50 Go to previous message
Abhishek Sharma is currently offline Abhishek SharmaFriend
I had the same issue, what worked for me is just closing and reopening the eclipse, then try editing the file-- it will ask again the messg -- if you want to make the file writable--hit ok and continue.
Previous Topic:CVS Forum/ CVS Question
Next Topic:Eclipse Neon constantly freezing
Current Time: Mon Jan 22 04:23:30 GMT 2018
Powered by FUDForum. Page generated in 0.04259 seconds
