Home » Eclipse Projects » Buckminster dev » [buckminster-dev] junit tests in headless buckminster
[buckminster-dev] junit tests in headless buckminster [message #509896] Mon, 25 January 2010 12:08
Originally posted by: dieter.cailliau.barco.com
------_=_NextPart_001_01CA9DE0.4F711C57
Content-Type: text/plain;
charset="iso-8859-1"
I was wondering how to integrate my junit tests in the headless build =
procedure.=20
Is this still up to date: =
http://code.google.com/p/buckminster-contrib/wiki/Buckminste rJUnit ?
If i do so, it stops with a NullPointerException:
x@x:/usr/local/hbm$ ./buckminster -data /tmp/x1 -L DEBUG -consoleLog =
junit -l /plugins/com.x.util/src-test.launch
!SESSION 2010-01-25 19:50:18.752 =
eclipse.buildId=3Dunknown
java.version=3D1.5.0_14
java.vendor=3DSun Microsystems Inc.
BootLoader constants: OS=3Dlinux, ARCH=3Dx86, WS=3Dgtk, NL=3Den_US
Framework arguments: -L DEBUG junit -l =
Command-line arguments: -data /tmp/x1 -L DEBUG -consoleLog junit -l =
!ENTRY org.eclipse.buckminster.runtime 0 293 2010-01-25 19:50:22.546
!MESSAGE junit '-l' '/plugins/com.x.util/src-test.launch'
DISCLAIMER:
Unless indicated otherwise, the information contained in this message is =
privileged and confidential, and is intended only for the use of the =
addressee(s) named above and others who have been specifically =
authorized to receive it. If you are not the intended recipient, you are =
hereby notified that any dissemination, distribution or copying of this =
message and/or attachments is strictly prohibited. The company accepts =
no liability for any damage caused by any virus transmitted by this =
email. Furthermore, the company does not warrant a proper and complete =
transmission of this information, nor does it accept liability for any =
delays. If you have received this message in error, please contact the =
sender and delete the message. Thank you.
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version =
6.5.7654.12">
<TITLE>junit tests in headless buckminster</TITLE>
</HEAD>
<BODY>
<!-- Converted from text/plain format -->
<BR>
<P><FONT SIZE=3D2>I was wondering how to integrate my junit tests in the =
headless build procedure.<BR>
Is this still up to date: <A =
HREF=3D" http://code.google.com/p/buckminster-contrib/wiki/Buckminste rJUni=
t"> http://code.google.com/p/buckminster-contrib/wiki/Buckminste rJUnit</A>=
?<BR>
If i do so, it stops with a NullPointerException:<BR>
<BR>
junit -l /plugins/com.x.util/src-test.launch<BR>
-----------------------------------------------<BR>
eclipse.buildId=3Dunknown<BR>
java.version=3D1.5.0_14<BR>
java.vendor=3DSun Microsystems Inc.<BR>
BootLoader constants: OS=3Dlinux, ARCH=3Dx86, WS=3Dgtk, NL=3Den_US<BR>
Framework arguments:&nbsp; -L DEBUG junit -l =
Command-line arguments:&nbsp; -data /tmp/x1 -L DEBUG -consoleLog junit =
<BR>
!ENTRY org.eclipse.buckminster.runtime 0 293 2010-01-25 19:50:22.546<BR>
!MESSAGE junit '-l' '/plugins/com.x.util/src-test.launch'<BR>
java.lang.NullPointerException<BR>
</FONT>
</P>
<p></p><p>DISCLAIMER:<br>Unless indicated otherwise, the information =
contained in this message is privileged and confidential, and is =
intended only for the use of the addressee(s) named above and others who =
have been specifically authorized to receive it. If you are not the =
intended recipient, you are hereby notified that any dissemination, =
distribution or copying of this message and/or attachments is strictly =
prohibited. The company accepts no liability for any damage caused by =
any virus transmitted by this email. Furthermore, the company does not =
warrant a proper and complete transmission of this information, nor does =
it accept liability for any delays. If you have received this message in =
error, please contact the sender and delete the message. Thank =
you.</BODY>
</HTML>
------_=_NextPart_001_01CA9DE0.4F711C57--
Previous Topic:[buckminster-dev] Buckminster Aggregator - mvn2 repo to p2 repo help
Next Topic:Re: [buckminster-dev] junit tests in headless buckminster
Current Time: Sun Apr 22 08:21:45 GMT 2018
Powered by FUDForum. Page generated in 0.01277 seconds
