Home » Archived » MOFScript » [Help] How to change the local of generated files
[Help] How to change the local of generated files [message #509247] Thu, 21 January 2010 18:58 Go to next message
Fabricio Pellegrini is currently offline Fabricio PellegriniFriend
I use the mofScript editor on my aplication calling IWorkbenchPage page; page.openEditor(file, "org.eclipse.mofscript.editor.MofScriptTextEditor");
but I need to change de default dir of generated files.
How should i do that?
Re: [Help] How to change the local of generated files [message #512629 is a reply to message #509247] Fri, 05 February 2010 16:49 Go to previous message
Gøran K. Olsen is currently offline Gøran K. OlsenFriend
Hello Fabricio,
Not sure if this is what you are asking for but here is the Java code for
setting the output.
If you have the output dir, look at the bottom line.
public void setRootDirectoryProperty (IFile file) {
String rootDir = null;
try {
rootDir = file.getPersistentProperty(new QualifiedName("",
if (rootDir == null) {
rootDir =
MofScriptEditorPlugin.getDefault().getPreferenceString(MofSc riptPreferences.ROOT_DIRECTORY);
if (rootDir != null)
file.setPersistentProperty(new QualifiedName("",
MofScriptPropertyPage.OUTPUT_DIRECTORY_PROPERTY), rootDir);
} catch (CoreException xec) {
rootDir =
if (rootDir != null && !rootDir.equals(""))
ExecutionManager.getExecutionManager().setRootDirectory(root Dir);
Previous Topic:[Help] How to change the local of generated files
Next Topic:Find the Target for a message
Current Time: Mon Mar 19 20:45:12 GMT 2018
Powered by FUDForum. Page generated in 0.01300 seconds
