Re: FindBugs [message #509010 is a reply to message #508506] |
Thu, 21 January 2010 06:11 |
maybe this helps: http://www.vogella.de/articles/Findbugs/article.html
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
On 19.01.2010 01:31, Jeebee wrote:
> Dear all,
> I have installed Eclipse Galileo under Fedora 12, and today I tried to
> install the FindBugs plugin using the update manager with url
> http://findbugs.cs.umd.edu/eclipse
> Checking the installed software I'm informed that FindBugs feature
> 1.3.9.20090821 is installed. Looks ok to me...
> However, after restarting Eclipse FindBugs does not show up in my
> project properties. Also not in context-menu on pacakges in project
> explorer.
> Maybe it is not able to load for some reason. Where can I find a plugin
> logfile or something?? My error log does not say anything about the
> FindBugs plugin.
> Jeebee
Re: FindBugs [message #509480 is a reply to message #509356] |
Fri, 22 January 2010 14:55 |
I would assume that Findbugs is then not installed correctly. You might
want to try the Findbugs mailing list for advice.
> JeeBee
Re: FindBugs [message #1719266 is a reply to message #1719192] |
Wed, 06 January 2016 16:49 |
On 01/06/2016 06:40 AM, Shruthi K V wrote:
> Hi I have installed FindBugs plug-in. I can see option FindBug in properties. Even code contains bugs, its not listing under Bug info.
> My code contains,
> String aString = "bob";
> b.replace('b', 'p');
> if(b.equals("pop")){
> System.out.println("done");
> where i should get error at line "b.replace();", I am not finding this in bug info window.
> javascript: insertTag(document.post_form.msg_body, '');
I don't think you should expect to get an answer in this forum. FindBugs
is a plug-in for Eclipse, but not by Eclipse. You'll want to look
elsewhere for support, maybe stackoverflow.com.
FUDForum. Page generated in 0.07971 seconds
